A
Anonymous Posted on May 18, 2014
What is 10stone in lbs - Office Equipment & Supplies
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Office Equip... Master 102,366 Answers
  • Posted on May 18, 2014
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443521
Points
622693
What is the Mitsubishi 4D56 2019 model Main bearing tightening torque
camshaft sprocket bolt 58-72 ft. lbs. crankshaft pulley bolts 108-132 ft. lbs. crankshaft pulley center bolt 80-94 ft. lbs. cylinder head bolts cold engine 65-72 ft. lbs. warm engine 73-80 ft. lbs. cylinder head rear cover bolts 69-86 in. lbs. flywheel/Driveplate bolts 94-101 ft. lbs. intake/Exhaust manifold nuts/Bolts 11-14 ft. lbs. jet valves 13-16 ft. lbs. main bearing cap bolts 36-39 ft. lbs. oil pan bolts 51-69 in. lbs. oil pan nuts 43-60 in. lbs. oil pan drain plug 33 ft. lbs. oil pump cover bolts 72-84 in. lbs. oil pump relief valve plug 29-36 ft. lbs. oil pump sprocket nut 25-28 ft. lbs. Rear oil seal retainer bolts 84-108 in. lbs. rocker arm shaft bolts 14-15 ft. lbs. rod bearing cap nuts 23-25 ft. lbs. silent shaft sprocket nut 22-28 ft. lbs. spark plugs 15-21 ft. lbs. thermostat housing-to-Engine bolts 86-114 in. lbs. timing belt tensioner bolt 32-40 ft. lbs. valve cover bolts 43-61 in. lbs. water pump-to-Engine bolts alternator brace bolt 14-20 ft. lbs. all others 9-11 ft. lbs. water pump pulley bolts 72-84 in. lbs.
Please can you help with all the torque settings for the cylinder head on Hyundai Accent 1.5 1995"
Nissan Frontier, Xterra 1998-05
Torque Specifications
Fig.
TORQUE SPECIFICATIONS
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1998 2.4 (2389) KA24DE
1A Step 1: 22 ft. lbs.
2B 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
4C The cylinder heads and the lower intake manifold are installed together
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1999 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 3.3 (3277) VG33E
1A The cylinder heads and the lower intake manifold are installed together
3C Step 1: Tighten the cylinder head bolts to 22 ft. lbs.
4D Step 1: Tighten the connecting rod bearing bolts to 10-12 ft. lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1998 KA24DE
1- Step 1: 22 ft. lbs.
2- 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
3- The cylinder heads and the lower intake manifold are installed together
4- 10-12 ft. lbs. +60-65 degrees
5- Step 1: 72 ft. lbs.
6- Step 1: bolts 11-22 19 ft. lbs.
7- Step 1: 20 ft. lbs.
8- Step 1: 31 ft. lbs.
9- 83 inch lbs.
10- Stud bolt: 11 ft. lbs.
11- Step 1: 72 ft. lbs.
12- Bolts: 17-24 (M8) 16 ft. lbs.
13- Step 1: 33 ft. lbs.
14- Intake manifold collector:
15- Intake manifold:
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1999 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2000 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2001 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2002 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2003 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2004 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2005 QR25DE VQ40DE
9- 83 inch lbs.
Main Bearing Torque Sequence
Fig. Main bearing torque sequence-2.4L engine
Fig. Main bearing torque sequence-2.5L engine
Fig. Main bearing torque sequence-3.3L engine
Fig. Main bearing torque sequence-4.0L engine
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Torque spec's for the fly wheel
2answers
Rebuilding 4.2 v6 ford need torque spec for main bearing
V8 Engines Component Torque Camshaft Sprocket Bolt 40-45 ft. lbs. Camshaft Thrust Plate-to-Engine Bolts 9-12 ft. lbs. Crankshaft Pulley-to-
Vibration Damper Bolts 35-50 ft. lbs. Cylinder Head Bolts All Except 1993 Flanged Bolts Step 1 55-65 ft. lbs. Step 2 65-72 ft. lbs. 1993 Flanged Bolts NOTE 1 Exhaust Manifold Bolts All Except 1993 HO Cobra 18-24 ft. lbs. 1993 HO Cobra 26-32 ft. lbs. Flywheel/Driveplate-to-
Crankshaft Bolts 75-85 ft. lbs. Intake Manifold Bolts Note 2 Upper Intake Manifold-to-
Intake Manifold Bolts 12-18 ft. lbs. Main Bearing Cap Bolts 60-70 ft. lbs. Oil Filter Insert-to-Engine Adapter Bolt 20-30 ft. lbs. Oil Pan 1979 Step1 Large Bolts 11-13 ft. lbs. Small Bolts 7-9 ft. lbs. Step 2 Large Bolts 15-17 ft. lbs. Small Bolts 10-12 ft. lbs. 1980-87 9-11 ft. lbs. 1988 and up 6-9 ft. lbs. Oil Pick-up Tube-to-Main Bearing Cap Nut 22-32 ft. lbs. Oil Pick-up Tube-to-Oil Pump Bolts 1979-87 10-15 ft. lbs. 1988 and up 12-18 ft. lbs. Oil Pump Bolts 22-32 ft. lbs. Rocker Arm Fulcrum Bolts 18-25 ft. lbs. Thermostat Housing-to-Engine Bolts Through 1987 9-12 ft. lbs. 1988 and up 12-18 ft. lbs. Timing Chain Cover Bolts 12-18 ft. lbs. Valve Cover Bolts 10-13 ft. lbs. Water Pump Mounting Bolts 12-18 ft. lbs. NOTE 1 Step 1 Tighten bolts in sequence to 25-35 ft. lbs. Step 2 Tighten bolts in sequence to 45-55 ft. lbs. Step 3 Tighten bolts in sequence an additional ¼ turn. NOTE 2 Step 1 Tighten bolts in sequence to 23-25 ft. lbs. Step 2 After assembly, retorque all bolts in sequence to 23-25 ft. lbs.let me know if this helps and how about a rating.
5helpful
2answers
Torque Specs for Head Bolts on 1997 GMC Sierra V8 5.0 Vortec?
.0L Torque Specs Belhousing to engine bolts 28-38 ft/lbs Camshaft sprocket bolt 40-45 ft/lbs Camshaft thrust plate to engine block bolts 108-144 in/lbs Crankshaft pulley to vibration damper bolts 35-50 ft/lbs Cylinder head bolts -1979-1992 --Step 1 55-65 ft/lbs --Step 2 65-72 ft/lbs -1993-up --Step 1 25-35 ft/lbs --Step 2 45-55 ft/lbs --Step 3 75-85 ft/lbs Differential shaft lock bolt 15-30 ft/lbs Driveshaft U-joint to pinion flange bolts 70-95 ft/lbs Exhaust manifold bolts 26-32 ft/lbs Flywheel mounting bolts 75-85 ft/lbs Front engine mount nuts 72-98 ft/lbs Intake manifold to head bolts --Step 1 96 in/lbs --Step 2 16ft/lbs --Step 3 23-25 ft/lbs Intake manifold (upper intake to lower) 12-18 ft/lbs Oil filter insert to engine block adapter bolt 20-30 ft/lbs Oil pan mounting bolts -1979 --Step 1 (Large bolts) 11-13 ft/lbs --Step 1 (Short bolts) 7-9 ft/lbs --Step 2 (Large Bolts) 15-17 ft/lbs --Step 2 (Short Bolts) 10-12 ft/lbs -1980 to 1987 9-11 ft/lbs -1988 to 1993 6-9 ft/lbs -1994-up 110-144 in/lbs Oil pickup tube to main bearing cap nut 22-32 ft/lbs Oil pickup tube to oil pump bolts -1979 to 1987 10-15 ft/lbs -1988-up 12-18 ft/lbs Oil pump mounting bolts 22-32 ft/lbs Pinion bearing preload 8-14 in/lbs Pressure plate to flywheel bolts 12-24 ft/lbs Rocker arm fulcrm bolts 18-25 ft/lbs Spark plugs 7-14 ft/lbs Timing chain cover bolts 12-18 ft/lbs Vibration damper to crackshaft bolt 110-130 ft/lbs Wheel lug nuts 85-105 ft/lbs
Torque for head bolts and related torquefor 2001 chevy calveler 2200 moter
Torque Specifications TORQUE SPECIFICATIONS All readings in ft. lbs.
Year Engine Displacement Liters (VIN) Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Intake Exhaust Spark Plugs Oil Pan Drain Plug 2001 2.2 (4) ① 70 38 77 ② 55 ③ 10 13 18 2.4 (T) ④ ⑤ ⑥ ⑦ ⑧ ⑨ ⑩ 13 18 NA: Not Available ① Step 1: Long bolts: 46 ft. lbs. Step 2: Short bolts: 43 ft. lbs. Step 3: Long bolts an additional 90 degree turn Step 4: Short bolts an additional 90 degree turn ② Center bolt spec shown; Pulley-to-hub bolts: 37 ft. lbs. ③ Bolts: 17 ft. lbs. Nuts: 17 ft. lbs. Studs: 9 ft. lbs. ④ Step 1: bolts 1-8; 40 ft. lbs. Step 2: bolts 9-10: 30 ft. lbs. Step 3: An additional 90 degree turn ⑤ 15 ft. lbs. plus 90 degrees ⑥ 18 ft. lbs. plus 80 degrees ⑦ 129 ft. lbs. plus 90 degrees ⑧ 15 ft. lbs. plus 45 degrees ⑨ Nuts: 18 ft. lbs. Studs: 97 inch lbs. ⑩ Nuts: 31 ft. lbs. Studs: 97 inch lbs. ⑪ Step 1: Long bolts: 2 ft. lbs. Step 2: plus an additional 155 degrees ⑫ 15 ft. lbs. plus 70 degrees ⑬ 18 ft. lbs. plus 100 degrees ⑭ 74 ft. lbs. plus 125 degrees ⑮ 39 ft. lbs. plus 25 degrees ⑯ Bolts: 89 inch lbs. Nuts: 89 inch lbs. Studs: 53 inch lbs. ⑰ Bolts: 89 inch lbs. Studs: 12 ft. lbs.
What is the torque settings on the head bolts for 2002 nissan x-terra 2.4litre?
① Step 1: 22 ft. lbs. Step 2: 59 ft. lbs. Step 3: Loosen completely then retorque to 22 ft. lbs. Step 4: 18-25 ft. lbs. Step 5: Plus 86-91 degrees ② 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs. ③ The cylinder heads and the lower intake manifold are installed together Step 1: Tighten the cylinder head bolts to 22 ft. lbs. Step 2: Tighten the cylinder head bolts to 43 ft. lbs. Step 3: Loosen the cylinder head bolts completely Step 4: Tighten the cylinder head bolts to 84 inch lbs. Step 5: Tighten the intake manifold fasteners to 35 inch lbs. Step 6: Tighten the intake manifold fasteners to 13 ft. lbs. Step 7: Tighten the intake manifold fasteners to 12-14 ft. lbs. Step 8: Loosen all intake manifold fasteners completely Step 9: Tighten the cylinder head bolts to 22 ft. lbs. Step 10: Tighten the cylinder head bolts 60-65 degrees Step 11: Tighten the cylinder head sub-bolts to 80-105 inch lbs. Step 12: Tighten the intake manifold fasteners to 35 inch lbs. Step 13: Tighten the intake manifold fasteners to 78 inch lbs. Step 14: Tighten the intake manifold fasteners to 70-84 inch lbs. ④ 10-12 ft. lbs. +60-65 degrees ⑤ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 75 degrees clockwise Step 5: Plus 75 degrees clockwise ⑥ Step 1: bolts 11-22 19 ft. lbs. Step 2: bolts 1-10 29 ft. lbs. Step 3: bolts 1-10 Plus 60-65 degrees ⑦ Step 1: 20 ft. lbs. Step 2: loosen to 0 ft. lbs. Step 3: 14 ft. lbs. Step 4: Plus 85-95 degrees ⑧ Step 1: 31 ft. lbs. Step 2: Plus 60 degrees ⑨ 83 inch lbs. ⑩ Stud bolt: 11 ft. lbs. Nuts: 31 ft. lbs. ⑪ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 90 degrees clockwise Step 5: Plus 90 degrees clockwise ⑫ Bolts: 17-24 (M8) 16 ft. lbs. Install rear main seal Bolts: 1-16 (M10) 26 ft. lbs. Bolts: 1-16 (M10) Plus 90 degrees clockwise ⑬ Step 1: 33 ft. lbs. Step 2: Plus 84-90 degrees clockwise ⑭ Intake manifold collector: Bolts and nuts: 8 ft. lbs. Stud bolts: 61 inch lbs. ⑮ Intake manifold: Bolts and nuts: 5 ft. lbs. and than to 21 ft. lbs. Studs: 8 ft. lbs.
Setting up suspension rider 10stone
stock settings should be spot on for 10 stone. if you are a good too fast rider , go 2 clicks harder on compresion. shock and forks.
2helpful
2005 Tucson
k24674
ADMIN Andrew
ADMIN Andrew
