Question about NRS Hoveround MPV 5 - Used Power Wheelchair
Can the MPV 5 be disassembled for transport? I can't find anything on the subject.
  • 175 Answers
The MPV is not designed to break-down easily for transport. The only "simple" thing that comes off is the seat which will make it about 40 pounds or so lighter, so you still have over 150 pounds to lift without taking the batteries out, which would get it down under 100 pounds...still a lot of weight to tote around. To take off the seat, first disconnect the joystick control cable, then unlatch the seat and lift off the base. This is safer and easier with two people.
The cheapest way to transport is using a ramp. Here's where I buy mine for our clients, and they are the strongest and the lowest priced ramps I have found. http://www.pviramps.com/
You can go with an electric lift, but the cost is going to be a few thousand dollars when all's said and done. If you install one on a car, you'll need at least a class II hitch, and I have found that usually you will also have to get air-shocks to compensate for the extra weight on the tail end. Even some vans, like the Honda, sag too much in the rear with a lift and chair on the rear end.
Posted on Jul 08, 2009
  • 37 Answers
There is no way to disasemble this chair without the possibilty of causing problems that are expensive to fix. You can unlock the chair from the base of the chair, BUT with out taking the housing cover off and disconnecting all the power cables etc it would still be some what connected to the chair. Sorry
Posted on Jun 23, 2009
I need to move my bowflex treadclimber. how should i disassemble it.
Examine the section on transporting the treadclimber. It well may be you don't want to do an entire disassembly.
http://download.nautilus.com/supportdocs/AM/Bowflex/BFX_TM3-5-7_AM_RevD_web.pdf
Sep 27, 2017 | Bowflex Exercise & Fitness
Disassemble bowflex treadclimber
There are several versions of this unit. If you do not have the manual for this model, I recommend performing a search and downloading it. The manual is an assembly manual. It details the parts. It also has a section on getting the treadclimber ready for transport. Rather than trying to tear down the treadclimber and reducing it to its pre-assembly form, I suggest you examine the transport section.
Identifying subjects verbs
A simple test is to apply an pronoun in front of the word to see if it makes sense. For example, "We officer" is nonsense but "We transported" obviously works
Aug 26, 2014 | Computers & Internet
Steps to replace water pump mpv 3.0
Remove the battery and battery tray.
Drain the engine coolant.
Remove the water pump drive pulley.
Remove thermostat case
Remove water pump tensioner
Remove water Outlet pipe
Remove water pump
Reverse disassembly order to install water pump.
Fill and bleed cooling system
Aug 14, 2011 | 2004 Mazda MPV
How to lower the seat for transport
Mur What are you putting the chair in to transport? If it is a van then you can move the seat back forward or backward (using the seat back release lever on the chair) enough to get it in the van or SUV. I used to transport them in a 98 Jimmy but had to tilt the back all the way back to get it in. Lowering the seat I don't think will give you enough clearance to do that cause it will only lower about 3 inches. Hope this helps
Oct 08, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
A man left a couple of nuts loose on the top of the starter motor would that cause the hole in my heater hose they say the hose was worn my car over heated and cost 3800 to fix its maza 95 mpv if so how i...
heater hoses are NOT subjected to any wear/tear other than perishing,so any mechanical parts that have gone are normal wear and tear or bad/irregular maintenance or driving after a fault developes.(i.e. engine siezing after overheating)
Jun 14, 2010 | 1995 Mazda MPV
How do i disassemble my ws-65313 for transport
Good Day,
To disassemble this TV follow these directions:
1). Pull front speaker grill off
2). Unplug the 2 cables connectors in front
3). Remove 4 screws on both sides of cabinet (might have plastic covers)
4). Carefully lift cabinet top until the support tabs clear the bottom cabinet
5). Carefully rotate the cabinet top and place back side on floor ( the mirror is on the top side)
6). Pack/wrap properly with blankets and transport in this manner.
Good Luck and Move, Big Irish.
Dec 02, 2009 | Mitsubishi WS-65313 65" Rear Projection...
2002 mazda mpv 3.0 cylinder 2 misfire
For the 2002 Mazda MPV 3.0L V6 DOHC:
Firing Order:
1-2-3-4-5-6
Cylinders:
4..........6...........5
3..........2...........1
Ignition Coils:
4..6..5
3..2..1
Mar 13, 2009 | 2002 Mazda MPV
NRS Hoveround MPV 5 - Used Power Wheelchair Logo
645 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
