Every time i watch a movie using my usb it doesn't have a problem with the video formats except .mkv (it can play the video but it doesn't have sounds) but when i switch on the subtitles it cannot read .sub but it can read .srt but it is very small and its font is almost not readable i can't figure out how to change its font and size :(
SOURCE: how can I active the subtitle and caption for tv programs
My Sharp TV manual says there should be a "CC" button near the upper right corner of your remote control. Keep pressing the button to go through the different options.
Not every TV program has closed caption, so it may not every time.
I hope I answered your question. Please rate me. :)
SOURCE: I can't get rid of the teletext subtitles
go into your cutomer menu and trun off close caption
SOURCE: TV Sharp Aquos LC-32D44E/S
Good day to you and welcome to fixya..
That problem is usually have 2 causes..Its either power supply board or main board..
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
You have a better chances if you have failing capacitors on the power supply board..
Please watch this videos about capacitors..
Hope this solution will be helpful..
Thanks for using fixya...
SOURCE: how do i turn off subtitles on my sharp lc 32 le 600e
Look for jammed buttons on remote and/or on control panel of TV. Kindly go through operation manual of every device and follow guidelines step-by-step.
SOURCE: no sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
