Question about HP PhotoSmart 1215 InkJet Printer
My printer will not work, What should I do to make
My printer will not print off what i am trying to print. What should I do to make it print off exactly what i am trying to print?
It keeps printing one line of small size symbols and letters. It is really wasting my ink and i would like to fix the problem immediately.
    President:
  • HP Master
  • 1,996 Answers
If you can, use the HP toolbox to print a test page and see if you recognize the output as the same as you are seeing, and confirm that the printer is correctly communicating with your computer.
If you are using a parrallel port cable, please work through this document.
If that doesn't work, try resetting the printer, according to these instructions.
Sometimes these issues are caused by driver conflicts. Run windows update and see if your system is offered any optional updates for your hardware or printer drivers. To manually update or reinstall the drivers, see here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 24, 2009
I can not get the printer to print
I am assuming you are trying to print from a computer, not a photo memory card (SD Card).
Try the following things:
- get the manual and install CD if you have it
- use the manual or the menu on the printer to print a test page (if that works then it is probably not the printer)
- make sure the USB-B cable is connected
- Start the Print Manager software on your computer (install it from the CD if it is not installed already, download the drivers from on-line if you do not have the CD)
- Use the Print Manager to print a test page (If this works, then we know the cable works)
- in Control Panel under Printers select the Epson Stylus as the DEFAULT PRINTER
- from the application (MS Word, Photoshop, etc.) try printing and verify that the Epson is the selected printer
If this does not work please provide further details about what hardware and applications you are using and what you are trying to print.
Good luck. Bry
Jan 01, 2011 | Epson Stylus RX580 InkJet Photo Printer
How to i clear the queue with jobs waiting to print when the printer says printing but is not printing
Try pressing cancel on the printer first. Then, open the print queue by opening the printers folder, and double-clicking the printer icon for your printer. Try to select the jobs there and cancel them. If that doesn't work, turn off the printer, and wait for the title bar of the print queue to say "use printer offline". If it doesn't change on the title bar of the queue, then select "use printer offline" from the file menu of the print queue. Then try to delete the print job. If this still doesn't work, leave the printer off and reboot the computer, then try to delete the print job again if it is still in the queue. If none of these work, remove and then reinstall the printer as a last resort.
Sep 30, 2010 | HP Officejet 5510 All-In-One Thermal...
Network printer printing rubbish when printed from Vista
The problem with dot matrix printers is that these are very old printers and you may not find a printer driver for them that run with Vista. If the incorrect printer driver is installed, the printer will print rubbish.
The only suggestion I can offer is to try various generic printer drivers until you find one that works. Connect it to the LPT1 printer port first and when you get it to work then set it up on the print server.
Also try Panasonic support and ask if they have a printer driver for this model printer that works with Vista.
Oct 22, 2009 | Panasonic Office Equipment & Supplies
Cant print text but prints headers, footers and pictures
try to make a copy ...if success
try to disconnect the power cable from the back of the printer and reconnect it after 20 seconds
try to print from the notepad ...............if success great
or else
uninstall the printer from the computer and reinstall the printer as a fresh
it should work and it has worked in most of the issues ................. thank you
HAMID
Oct 20, 2009 | HP DeskJet F4280 All In One Printer InkJet
Printer stopped working after I cancelled a print job
Turn off your printer and completely unplug the USB cable (from both the printer and the computer). Next check if the stopped document or the later documents are in the print spooler queue. If you can cancel all documents from the queue, do so. Otherwise: from Start Run (or the command prompt)
type: net stop spooler [enter]
then type: net start spooler [enter]
This works in XP and older MS Operating Systems but I've never tried it in Vista.
If you only enter the first command, you need to reboot the computer and then take a long coffee break after logging in before trying to print again.
May 06, 2009 | HP Deskjet D1455 InkJet Printer
Received the following message when I tried printing - "System Error. The printer failed to print due to a system error. Try printing again. If unsuccessful turn Windows off and reprint." Can you sugg
Turn it off and unplug it for about 30 seconds. Plug it back in, turn it on and try printing a Self-Test (Setup, 2, 5). If this works, try printing your document again.
Apr 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP1018-After pulling the plug in the middle of printing it dies..
YOU HAVE TO RESTART THE SERVER OF PRINTER AND RESTART YOUR PRINTER AFTER THAT YOUR PRINTER MUST BE WORKING
Feb 10, 2009 | HP LaserJet 1018 Printer
Will not print after turning printer off
I used to have that same problem what i suggest doing is restarting not only the printer but your computer aswell. That seemed to solve the problem for me
Oct 15, 2007 | HP LaserJet 1020 Printer
HP PhotoSmart 1215 InkJet Printer Logo
81 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
