Question about Vacuums
Boom on vacuum truck does not rotate left or right all other functions on vacuum truck work
  • 45 Answers
Only two parts involved .The contact behind the switch or the actuator himself not working. Take it to a mechanic to check the circuits.
Posted on Jun 25, 2014
How do i fix the brush on my babyliss rotating hot air brush as it has stopped working after two goes..
you need to replace the drive belt look for screws on bottom and access plate left or right.
Jan 21, 2015 | Filter Vacuums
My brush is not rotating
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC33's brush bar is not rotating. This is likely to be because the brush control on the cleaner head has accidentally set to 'Hard floors'. In this mode, the brush bar will not rotate. Please recline your machine into the vacuuming position, turn it on, and make sure the brush control is set to 'Carpets'.
I'm confident this will resolve the issue, as using and replacing the wand will not have any effect on the function of the brush bar. It's also important to note that the brush bar will never rotate when the machine is standing upright.
If you would like further assistance after you've checked the brush control is correctly positioned, please get in touch with us directly. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jul 21, 2013 | Dyson DC-33 MultiFloor Upright Vacuum...
When in the center needle position is selected, the needle is not centered, it is left of center. When the right needle position is selected, the needle sits only slightly to the right of center. How can...
Make sure machine is set for regular zigzag stitch and not a fancy zigzag stitch, and rotate it by hand at least two full revolutions in the normal direction of rotation to make sure it is settled in to the regular zigzag stitch. Now set the stitch width to maximum width and slowly rotate it by hand, watching the needle. Does the needle strike the top of the foot at the extreme left or right? (and this is the slotted zigzag foot, right?) If not, you are good to go. If the needle does hit the top of the foot squarely, do make sure that the foot is mounted correctly and change the needle, making sure it is the correct size and that it is inserted all the way and facing the right direction. It is somewhat unlikely that the left to right position of the needle bar needs adjusting.
Sep 09, 2011 | Vacuums
While operating machine, brush does not rotate. Button is pushed in, all hair cleaned off brush. Is there a reset button? Where is it located?
Likely the wires are broken under the left hand cover not a difficult fix. Unplug the machine and remove the 4 torx screws and an access panel at the side of the ball. replace wires with new or re-connect with a splice. ensure wires are long enough to allow movement and you don't trap the wires when you replace the covers. about a 20 min job with the right tools
Sep 26, 2009 | Dyson DC15 All Floors - The Ball Bagless...
My Eureka Optima vacuum handle broke right at the metal tube.
I have exactly the same problem. I plan to drill a hole in the handle through plastic and metal, and then pass a metal pin to hold them together. I don't rotate the handle much, so the loss of handle spin functionality will not be a major issue for me.
Aug 05, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Just need to know how to change the belt on my vacuum cleaner
Step 1: Lower handle to floor to change belt
Step 2: Remove the two screws from the top hood on the foot
Step 3: Lift hood to remove
Step 4: Lift right end of brushroll (the belt end)
Step 5: Remove and discard belt.
Step 6: Place new belt around motor shaft.
Step 7: Place new belt around brushroll pulley.
Step 8: Align left end cap with base. Push end cap securely into
place. Make sure the square on the brushroll cap is in
place
Step 9: Pull right side of brushroll to stretch belt. Secure right
end cap into base.
IMPORTANT
Step 10: Rotate brushroll by hand several full rotations to properly
position belt.
Step 11: Place hood back on cleaner. Replace and tighten
two screws.
Step 12: Return vacuum to upright position.
Dec 09, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Changing belt Please advise how to change the belt. I wasn't the person who took the belt off, didn't watch. Now it's just me and the belt. I had 2, but 1st one burnt right off. Apparently I didn't have...
place
end cap into base.
IMPORTANT
position belt.
two screws.
You can also download your user manual here which has instructions on how with diagrams
Bissell proheat 2x
Yes, there are belts for both sides, but if they look ok, then the brush motor may be bad. Brush motor part # 2036757 , right side belt # 2036804 left side belt # 2036688
Nov 10, 2007 | Bissell 3522 PowerForce Bagged Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
