Question about Refrigerators
Tech sheet for kenmore model 10670962990 refrigerator
4 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: Tech sheet is missing- serviceman needs it
www.appliancejunk.com
Posted on Apr 08, 2010
rickead1
  • 1998 Answers
SOURCE: I need a tech sheet for a kenmore refrigerator mod # 50594000 ser
go on searsapplaince site type in your model number and it will bring up a parts list for you unit hope this helps they also have the tech sheets available there also
Posted on Jul 13, 2010
  • 586 Answers
SOURCE: I have a kenmore refrigerator freezer workng ok
Hello there,
You can as well check up on it yourself, or have a friend who is technically able to help you carry out the information in the tips below in order to be able to solve the problem.
Do you have ice build up at the back of the unit? If so, unplug it and leave it to thaw before you start the testing.
The problem with the refrigerator that is causing the freezer to be working okay, but the fridge not to be working lies within the defrost thermostat, defrost heater and the defrost timer.
Here are the links to testing the components and replacing the faulty one amongst them.
Defrost thermostat http://www.fixya.com/support/r10513592-test_defrost_thermostat http://www.fixya.com/support/r10513650-replace_defrost_thermostat defrost heater http://www.fixya.com/support/r10523771-test_defrost_heater http://www.fixya.com/support/r10523754-replace_defrost_heater defrost timer http://www.fixya.com/support/r10523722-test_defrost_timer http://www.fixya.com/support/r10523742-replace_defrost_timer
You can have some to assist you if you are not familiar with sich technical activity.
Hope this helped. All the best Elect_Comp
Posted on Sep 23, 2011
Kenmore bottom freezer 795.78309.804 codes er/ff what do they mean? is food going bad?
Model number 795 it's an LG fridge. Even if it says Kenmore on it. LG is the manufacturer of that fridge. If it's a newer fridge & or your the original owner. Take the kick plate off the bottom front of the fridge. Either in that kick plate or looking in were that kick plate was on the top wall of the bottom of the fridge you'll see a plastic envelope with sone folded up papers in it. Those white pages are called tech sheets for the tech that comes to your house to fix your fridge. They are best left under the fridge or in the kick plate but alot of the time they aren't put back. Why I asked if yiur the original owner. If you are able to locate those tech sheets. They should list the trouble codes and what the code stands for. I don't remember what it stands for. Taking a guess it means error fresh food or er/ff. Don't quote me on it I'm not sure of my answer but I think it's a faulty thermistor in the fresh food section. Fresh food section is the refrigerator section. Please check to make sure you have the correct problem before doing anything. I'm taking a guess just from memory as to what the error code is. At least with the tech sheets, hope they are there. You'll be able to find out what the code means.
Hope that helps you a little or alot. Thanks
Oct 17, 2016 | Kenmore Refrigerators
Looking for keypad combo to reset control board
the tech sheet for my refrigerator was found under the plastic cover over the top hinge. my model # is kbrs22kwms5
Mar 03, 2012 | KitchenAid KBFA20ER Bottom Freezer French...
My refrigerator is making beeping noise even when the door are completely closed, nothing else is wrong with it, how do I stop the noise? Serial # 512KR00185 Model@ 795.78843401
look behind the toe panel and there may be a tech sheet ther .. it will tell you what the beeps are informing you of and how to reset the control to stop it mm hope this helps ..
Sep 19, 2011 | Kenmore Refrigerators
Jul 13, 2010 | Kenmore 50522 / 50524 Side by Side...
I am trying to find the model of my Kenmore Dryer... Its an old HE3 going on 7 years old.
Hi, The model number is always located on the inside of the door jamb for Kenmore's. If for some reason it's not there you can remove the panel under the door, Normally 3 screws along the bottom lip. Behind this panel there should be a tech sheet. The model number should be on the tech sheet. If you have any additional questions please feel free to comment. Mike
Dec 10, 2009 | Kenmore Dryers
I have a Kenmore model `06.51552104 Refrigerator and the ice make quit producing ice. When I open the door the red light flashes twice, then pause, then flashes twice etc. Does this code mean anything?...
Look behind the grill on the bottom for the tech sheet. It will tell you what the flash means and provide a diagnostic sequence to test it out.
Eric
Jun 29, 2009 | Kenmore Refrigerators
Clothes washer won't drain - digital display shows LD
looking at the tech sheet for this, it appears to be a standard whirlpool top load but with electronic controls, correct? normalling with this type a lid switch is the issue but the electronics would have a different code for this, LD is Long Drain for this model. suspect a transmission but this should help you troubleshoot. go to www.servicematters.com and click technical reference - tech library - tech sheets, enter model minus 110.prefix. this will show tech sheet with diagnostics. this book can also be found inside your console.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Need schematic Kenmore bottom freezer model # 79565002401
you can pull off the kickplate(underrthe freezer door, and if you reach up under theright hand side there will be( if no one has removed it) a tech sheet/ wire diagram for you r machine
Mar 10, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
