Mitsun mit 1950 ic CV2653 equilant
CV2653 ic equilant
Mitsun mit-1980u 5.1 display not working
I'm sorry. Could you please try to restate your problem. I can't understand you.
Feb 03, 2014 | Audio Players & Recorders
MITS VS-60609 HAS NO POWER AT ALL (DEAD)
Possible convergence IC loading power supply. Common. Big IC(s) with #s starting STK392(3).
Apr 17, 2010 | Mitsubishi VS-60609 60" Rear Projection...
No display lights on bose lifestyle 8 home theatre. System works though.
Displays die quite often on receivers just one of those things that happens.
Bose is pretty good about repair cost and timely in their turnaround. Here is a link to the support page
I would guess a replacement display would run about $150 installed plus you will have to ship your unit to them.
They like to do "flat rate" service plans which is one of those 50/50 deals most of the time you are better off just paying for the repair versus dealing with a service contract but you will have to find out whats available for your model.
Hope that helps
Feb 12, 2010 | Bose Lifestyle 8 series II System
The picture on my tv (mit. 1080) is made up of
Convergence ICs Two of them STK392-570 ,they are big black ICs,Replace with same Number on ICs.You can order them at MATS 1-800-628-1118.
Aug 07, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Tv won't stay on
2 of 3 circuit boards in your Mits can give your symptom...
1)Center power supply board = open fuse & bad IC's
2)HV scan board defective.....
A qualified Mits tech with parts in stock can fix it.......T.
Dec 13, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Receiver
I have the same problem.
Is there a solutions besides replacing it?
May 22, 2007 | Mitsubishi M-VR700
No output to the speakers from any source
It seems to me that u have an output problem. ckeck the output components (either IC or transistor)and change them. good luck
Dec 19, 2006 | Mitsubishi M-VR900 Receiver
46 people viewed this question
 Grubhead
Grubhead
