Question about Camping, Backpacking & Hiking
Valve reassembly for a coleman 321 lantern i need the dieagram
I took the valve assembly a part i need to know how it goes back together.
SOURCE: Need to reassemble Powershot 5700 stapler and need schematic
how to put the stapeler back together after fell apart
Posted on Jan 23, 2009
joboo1
  • 257 Answers
SOURCE: how to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
Posted on Mar 16, 2009
  • 97 Answers
SOURCE: reassembly of trimmer blades to motor body
Put the ware plate on the support bar.
On top of that install one blade facing up.
Then install the other blade facing down.
Put the bolts up through the support bar
Install the little rubbing blocks on bolts in slots in blades.
Place top stiff plate on top and install nuts.
Replace grease in gear box with stihl hedge trimmer grease onyy
Posted on Mar 19, 2009
  • 3 Answers
SOURCE: took unit apart to clean and need reassembly diagram please
the thick racket sit on top of the lil gold bracket
Posted on Jun 20, 2009
SOURCE: crosman c11 airsoft gun assembly
best bet exploded view. i did the same thing
http://www.shans2003.ru/Article/pi_Crosman_C11_EVP.pdf
Posted on Aug 02, 2010
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
I have a dual fuel, two mantles, coleman lantern. I have changed the mantles several times and they keep getting holes almost every time i light the lantern.
Make sure that the vapourised fuel is coming through the mantle before lighting up. You should hear a hissing sound when the flame adjusting lever is turned to high. If not it is possible that the generator is clogged up and that vapourised fuel is not getting through to the mantle. So when you light up you are essentially just burning the mantle. If the generator is knackered it will need to be replaced. One way to check it to remove the generator, primed the tank and turn the valve on. If fuel spurts out when the generator is removed (DON'T LIGHT IT U)P THOUGH) but there is no hissing sound when the generator is intact then it is a sure sign that the generator is clogged up. In the UK a replacement generator should set you back £10-15. Hope this helps, Bandit
May 23, 2011 | Coleman Cable Coleman Twomantle Dual Fuel...
Acts like a check valve is stuck open below the plunger assembly. It lets all the pressure out while im trying to pump it up..is this something i can fix? the lantern is relatively new.
It sounds like you are correct. While I don't know much about the new lanterns I have worked a lot on older ones. My first suggestion is the easiest. Try putting some 3 in 1 oil on it. First relieve any pressure in the tank- open the valve then slowly loosen the fill cap- watch out as it will likely spill fuel so do this outside Remove the plunger, there is a black plastic piece that holds it in it will come of either by a push and twist, or by removing a little metal bail across it. (you remove the metal bail (small wire loop) by gently pulling it outward with a small pliers.) then the plunger should come right out look into the hole and you will see a check valve at the bottom, try a bit of oil or wd40 on this, let it sit for a while, it may just be rusted open, and will take some time for the oil to work. Make sure it is working well before you light the lantern. you Do Not want this to fail when the lantern is going. Do this outside and away from any flames. Pump it up and see if it can hold pressure overnight
Jan 02, 2011 | Coleman Cable Coleman Twomantle Dual Fuel...
I have a Coleman 228F model lantern. When I go to light it, it barely produces any gas. I have made sure it is pumped adequetly and full of new fuel. I can hear gas coming out very faintly and sometimes...
It's likely that it was left away with fuel in it. This causes gel to form which blocks the fuel getting through. The blockage could be anywhere between the tank and the mantles. The order I would check in are;
  1. The feed tube assembly
  2. The generator
  3. The Burner
It's possible to get these parts from coleman or coleman suppliers. To find which needs replacing you'd need access to another similar lantern and try replacing one at a time. Otherwise it's going to be trial and error or just replace all.
There's a manual which shows the assembly and the order number for parts at http://www.coleman.com/coleman/images/pdf/220f_228F.pdf
I hope this is of some help.
Dec 16, 2010 | Coleman Sport & Outdoor - Others
In reference to the Coleman Lantern/fan/radio #841-321 .....where is the battery compartment located? where can I purchase an adapter since this one is missing?
Type this URL in the box- http://www.fixya.com/support/t955738-coleman_lantern_fan_am_fm_radio. As for the adapter, you should probably check the camping section or electronics section of Wal-Mart or, you can call customer support for Coleman. Their phone number is 1-800-835-3278. Ebay, Amazon or other online shopping companies might have the adapter in stock. Hope this helps.
Oct 08, 2010 | Coleman Lantern Fan Radio (841.321) AM/FM
How to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
Aug 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Coleman lanterns as collectibles
Coleman Collectors Guide 1903-1954.
Tucker & Ebebdorf
ISBN 0-9651407-0-9
This is an excellent reference with lots of pictures etc., it does not give the prices, however.
You can check Ebay for completed prices if you need an idea of value.
I have not found a book yet with accurate values on Coleman lanterns.
Apr 21, 2009 | Coleman Sport & Outdoor - Others
Camping, Backpacking & Hiking Logo
414 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
