Question about HP LaserJet 4 plus Printer
HP PSC 1610 MAKES A CLICKING/CLANKING SOUND WHEN STARTING TO PRINT STILL PRINTS
  • HP Master
  • 1,121 Answers
Mechanical clutch fault, availability of this spare & replacing is very difficulty.., This mechanism is very delicate & complecated.. Better go for new printer..
Posted on Jun 11, 2014
agnelkj
  • 210 Answers
SOURCE: Printer HP PSC 1610 All-in-one Driver
I dont understand about the term DVD driver.
however if you are looking for the printer drivers then following are the link.
for windows xp:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-30256-1&lc=en&cc=us&lang=en&os=228&product=390315&dlc=en
for windows vista:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47767-1&lc=en&cc=us&lang=en&os=2093&product=390315&dlc=en
once you click on any of the above links according to the operating system that you are using, scroll down to step 3 and then click on download only button. once the download is finished, unplug the usb cable from the printer and then run the file.
Posted on Mar 14, 2008
myob247
  • 1342 Answers
SOURCE: makes noise
Click HERE for HP troubleshooting for your printer.
Posted on Jun 07, 2008
SOURCE: Installing HP PSC 1610 on Vista
Hello, I have a new computer that's running Vista. How can I install my HP PSC 1610, given that the software for the printer is designed for Windows XP?
Posted on Nov 22, 2008
SOURCE: HP SSC 1610 scanning
INSTALL HP CD
PL CHECK MEM MIN 256 WIN XP RECOMMEDNDED
Posted on Mar 16, 2009
  • 3600 Answers
SOURCE: hp psc 1610 all of a sudden won't print
Most likely it ran out of ink open the ink door and pull out one of the cartridges and tap it to see if it has ink, if it does not replace the cartridges. If there is ink then log on to http://www.hp.com choose trouble shoot your printer then input your model, once you do this it will ask if you want to install the troubleshooting program in and run it do so now. then follow the prompts to find the problem, if it can't find the problem go to the chat box and chat with an hp agent, this is free and they can help you if the troubleshooter does not detect the work, also yo may have a warranty on it and would not know about it. hope this helps.
Posted on Apr 16, 2010
Testimonial: "Went to hp.com & it mentioned using the printer diagnostic tool (which I already had on my computer). Went through the steps & is now working."
WHY DOES MY HP PSC 1610 MAKES A CLICKING/CLANKING SOUND WHEN STARTING TO PRINT STILL PRINTS
I think your printer required maintenance, because printer time all parts working then your printer print. I gas you some points link printer belt, printer header, printer roller..so any one damage or this types of issue create, so i suggest you contact HP printer technician and check it.
Thanks,
HP Printer Support
May 18, 2014 | HP PSC 1610 All-In-One InkJet Printer
My printer started making loud clanking noises immediately before printing the document. The document prints fine, but that loud noise sounds like a machine gun. After manually moving the carridge to the...
jim@bigdork.net
Thanks fixya.com
You helped me CLEAN the HP PSC 1610
it had MASIVE amounts of waisted ink
in the area that it WANTS to waste ink
to keep the cartridges FLOWING...
BUT... NOW ... HERE IS A SOLUTION TO
THE CLICKING NOISE
THE RATCHIT NOISE
HP PSC 1610 NOISE
It seems that HP (as with most all manufacturers)
has DESIGNED-IN A PART THAT WILL BREAK ! ! !
PICTURE ATTACHED
explanation...
opened the mid section of the printer
moved the ink holder module to the far left
pushed the cleaning tray
(it moves to you and away from you)
away towards the rear of the machine
used masive amounts of isopropyl alcohol
and an old toothbrush
to clean most of the gunk ink buld-up
(started with q-tips but it was not enough)
After cleaning ... the machine worked again...
BUT
that noise was still there
after carefull inspection
I saw the problem
there was a hairline crack in a small plastic part
above a rotating gear
when the carriage came to the right
it was suposed to move that part
off or away from the gear
but because it was cracked
it did not move properly
SOLUTION
crazy glue or super glue
and shim to hold in place while drying
(maby heat with a light bulb while drying)
SEE ATTACHED PHOTO WITH NOTES....
May 19, 2010 | HP PSC 1610 All-In-One InkJet Printer
The black prints as grey. The only time it will
Go into Printer "Properties" look for "Print in Greyscale" set it to OFF, OR set to color,either way
Mar 05, 2010 | HP PSC 1610 All-In-One Printer, Scanner...
My printer prints pages
The print job properties screens vary depending upon your OS and the version of your printer software. When you click "Print..." from the File menu in an application, the current job properties come up. You need to look for a box that you can tick or un-tick that has to do with reversing the print order of the resulting pages.
Dec 12, 2009 | HP PSC 1610 All-in-One Printer, Scanner,...
Prints a information sheet after every print i do how do i stop ?
Go to printer under control panel and view properties for that printer, click anything that says default settings.
Is this on one document and application only. Is it the print settings of the document?
Nov 17, 2009 | HP PSC 1610 All-In-One InkJet Printer
Black re-mfg for psc 1610 prints unreadable
your black print cartridges has been dried, these need to replace.
Aug 22, 2009 | HP PSC 1610 All-In-One InkJet Printer
Can't get psc 1610 to print on new macbook wirelessly
If you install the Hp wireless driver on your Mac, that should do it.
Aug 18, 2017 | HP PSC 1610 All-In-One InkJet Printer
Only Prints in Black and White
hello friend u have problem in logice card of the printer so u need to replace the logice card of the printer .
Sep 09, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP LaserJet 4 plus Printer Logo
Seeker5211
Seeker5211
