Question about Hotpoint Ultima WF860 Front Load Washer
No water it shows h20 on the dail
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 40 Answers
Check the valve on the back of the machine where the hoses connect. there should be a screen in the opening if it is clogged - remove it and try again.
Posted on May 18, 2014
Why is my indesit washing machine displaying H20 and not opening
• The water container must be emptied? The "Empty water container" indicator light flashes and the message appears "H2O" (see Maintenance).
Dado
Jun 29, 2015 | Indesit Washing Machines
Indesit washing machine showing H20
code showing h20 is the clue water is also known as h20,so your problem is the inlet valve letting the water into the back of your machine needs replaced or water pipe is kinked and no water is at the supply,. these valves are cheap at 10 dollars,adrian.....
Dec 20, 2014 | Indesit W 123 Front Load Washer
The ariston washing 125 show h2o on the scrim
The washing machine fails to load water (The wording H20 is displayed).
  • The water inlet hose is not connected to the tap.
  • The hose is bent.
  • The water tap is not turned on.
  • There is a water shortage.
  • The water pressure is insufficient.
  • The START/RESET button has not been pressed.
Dado
May 29, 2014 | Ariston Technologies AW125NA 13 lbs. Load...
H20 is showing on the display screen of my hotpoint washing machine. I'm aware this means water but I'm wondering why this is displayed?
Possible that there is no INLET pressure or water flow to the machine, check the inlet filter and valve, check for good flow to the valve if the hose is disconnected. If not it needs to be checked if the panel board is showing error due to memory fault..
Jan 23, 2013 | Washing Machines
Hi i have a hotpoint washin machine and it kepp showing H20 on the csreen can you please help th model number is WT740
H20 indicates a problem with water supply.
Check the inlet hose/s for restrriction or kinks, ensure water supply pressure is o/k, also check the filter screens in the inlet valves, you will have to turn the water off to do this.
Dec 06, 2010 | Hotpoint Aquarius WD63 Front Load...
H20 ERROR SPIN DRYING
The error indicates a problem with the incoming water supply.
Check for restricted or kinked inlet hose/s, check that tap/s are fully turned on and that you have adequate water pressure.
Mar 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
H20 is showing on my display on my indesit
H20 means not filling with water properly.
Check hoses and that taps are fully turned on , make sure water pressure is o/k, no kinks in hoses
Mar 13, 2010 | Indesit Washing Machines
Hotpoint qualtis washing machine spin display showing H20 and won't start. model AQXXF 149PM
H20 means a problem with the water inlet supply.
Check the inlet hose/s for a kink or restriction, make sure it is turned on fully at the supply..
If it is cold fill only, could be a frozen pipe.
Hope this helps.
Jan 07, 2010 | Washing Machines
WR480 ERROR CODE H20
h20 fault code means you have a water supply problem.
check you have suficiant water pressure coming into your appliance,and also check that you have no blockages at the sump of the apliance and if plunbed to the sink check for blockages there.
f08 code means that the heater relay is stuck or open curcuit,check connections on your module and check your heater is not open curcuit,if these are ok you will require a module.
May 09, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
14 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
