Question about Digi Televison & Video
Standby button flashing and not coming on - Digi Televison & Video
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
On/Standby light flashes red four times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 27, 2012 | Sony VPL-EX100 3LCD Projector VPLEX100
Hi iv got a hinari steam generator iron hin001 that comes on and heats up but no steam comes out when you press the button and theres a standby sign flashes on the display can you help me please
don't spend your money on a calc cartrage it will not get it out of standby.
the controll unit carnt tell if it needs replaceing!
if the standby light is flashing it means it carnt heat the steam tank. if the iron is not heating as well it is a buggerd control pcb!
if you live near Newcastle I could fix it for 20 pounds
Paul@rochy.com
Feb 03, 2011 | Maytag MLI7500A Iron
Samsung 55" flat panel lcd tv is not coming on the standby button light stayes on but no picture coming on it doesn't come on with the switch only by plugin it to the outlet.
Does the backlight come on? or even flash on and off when the TV is switched on? I presume the standby light is showing 'blue' then. Do you have any sound? Also, when the TV remote is pressed, does the standby light flicker?
Feb 22, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Standby button flashes i have sound but n o picture it just flashes the standby button for the sony big screen 57 please help
Its possible that the CRTs have shutdown due to a vertical failure. Have you tried pressing menu to see if the onscreen menu will come up, as often the menu will operate when the crts go into blanking for protection. You can also try turning up the CRTs slightly to see if they will turn on.
Nov 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Same thing
More Info please, it will usually go to standby if camera turned off or after the meter shuts down after a predetermined time (nikon default setting in camera is usually 6 secs.).
So if you switch camera back on or push shutter release to wake up metering system flash should automatically come out of standby.
Or you can push the on / off button for approx 1 / 2 secs. this will wake it up , then turn it off. Hope this may help Ian
Aug 08, 2009 | Nikon Speedlight SB-600 TTL Flash
Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Jul 30, 2009 | Pioneer Audio Players & Recorders
Shows STBY
STBY means 'Standby'. This is to conserve the batteries. It will come out of standby mode as soon as you press the shutter release button halfway down.
May 29, 2009 | Nikon Speedlight SB-800 TTL Flash
Televison & Video Logo
Top Digi Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Digi Televison and Video Expert? Answer questions, earn points and help others
