Question about Sub-Zero 642
There is a code EC 20 ice, what does that mean?
Ice is not being made
EC error code meaning
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
Aug 28, 2014 | Frigidaire Heating & Cooling
What do you mean by EC?
i do not know if i got it correctly but it seems that there is a code after this right? it Error Code..
Jun 17, 2014 | Heating & Cooling
EC ERROR CODE
It means the unit is low on gas
May 19, 2014 | Midea Heating & Cooling
What is Ec code on disply mean dreammaker spa
check recirculation pump and heater element if ok temp sensor
Mar 29, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a sub zero 690 series refrigerator. The display shows codes 34 01 and then EC 24 Any idea what this means? Thank you
DEFROST UNDER HEAT IS THE CODE DESCRIPTION. IF YOU HAVE A BELL BUTTON HOLD IT 15-20 SECONDS TO CLEAR. IF THERE IS NO BELL BUTTON POWER OFF THEN POWER ON TO REST AND SEE IF CODE COMES BACK AND THEN CALL FOR SERVICE. 1-800-222-7820
Apr 24, 2010 | Sub-Zero 690 Side by Side Refrigerator
Sub Zero model # 695 is flashing EC-40 error message. No ice.
When our Sub-Zero Model 650 quit making ice, and the SERVICE ICE lights started flashing, we called our technician who said, "You can pay me $178 for a service call or have another option - you have 2 seconds to decide. Oops, your time is up, I will decide for you!"
"Open the door and push the REFRIGERATOR UNIT ON / OFF message button; wait 30 seconds and push it again. About 95% of the time, the unit creates the glitch, and you are simply rebooting the computer. If that doesn't work, call me. I hate to take your money to come out to push a button."
IT WORKED! The warning message turned off and the freezer started cranking out ice.
Dec 18, 2008 | Refrigerators
the hot thing is normal be alarm when is not hot the condenser coils run on side of walls so is normal the ec means the board under the unit is not comunicating with the display on door it means error comunicating 2 things could be wrong 1 the board is bad need to be repl 2 there is a broken wire inside door. lastime i fix this i order both door and board but i tried the board first and it work so take a chance unles you have any type of warranty then call a tech
Sep 15, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Sub-zero 632 error code 24
clean out auger bucket ec-24 is defrost underheat,to clear press and hold bell on/off key for 15 seconds.
ALL APPLIANCE REPAIR L.L.C
HOT SPRINGS
Feb 28, 2008 | Sub-Zero 632 / S
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Refrigerators Logo
50 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
