Question about Kurzweil Music Systems Kurzweil SP3X 88-Key Stage Piano 886830131288
Tell me some tips and tricks about using the Kurzweil sp3x stage piano
How can I fully utilize the the Kurzweil sp3x stage piano so I can get the best sounds to use on stage?
    Top Expert:
  • Kurzweil Mus... Master
  • 3,107 Answers
The place to get the best help for Kurzweil gear is Sweetwater Sound.
Other than that, always use it in stereo mode with a decent sound system. Always use speakers with at least a 15" woofer and a horn to get the full range of sound it's capable of.
Posted on Aug 06, 2014
Cuts out on me while playing
If you';re sure it's the instrument, rather than your amp cutting out or the cord being intermittent, do a factory reset. Beyond doing a reset, it's doubtfull this will be a user servicable problem. You need to contact Kurzweil Support. Here is a link to their page
Support Kurzweil
Feb 08, 2015 | Kurzweil SP3X 88-Key Stage Piano
It doesn't turn on
check if the adaptor is ok, if ok you got to call a technician and check the piano.
Apr 08, 2014 | Kurzweil SP2X Stage Piano
Gets whacky and freezes up every 2-3 minutes
Is this the correct sustain pedal for this unit? It sounds like it should be a momentary button type. I would look into that. Some have a push to work type of switch and some use momentary. If it is, I would open that pedal and clean the switch with contact cleaner, as it appears to be sticking.
May 22, 2012 | Kurzweil SP3X 88-Key Stage Piano
I just got this keyboard and want to hear the program # 110 Upright Bass 1 and its Ride Cymbal; I hear the bass, but not the cymbal. The sound is listed in Appendix B on B-14 in the manual. Thanks!
Verify the sound in headphones directly from the unit. The cymbal MAY be panned to one side or the other and will require higher frequency response than some of the piano notes.
Sep 20, 2011 | Kurzweil SP3X 88-Key Stage Piano
Hello, My KURZWEIL start but it only blinking a rectangel on display to the left. There is no other lights, all other is dead Morten Lauritz
It could be your internal battery. Do a search on keyboardforums.com for additional support or Kurzwil website. good luck!
Sep 15, 2011 | Kurzweil SP3X 88-Key Stage Piano
Hi, my key F3 (Fmin) has nonfunctional dynamic on my Kurzweil SP2XS. It is still in full loud, only when I really use minimum press - it is quiet (undertone - pianissimo). I never strike on this key more...
The keys have TWO contacts. One closes before the other as you press the key. The processor in the piano MEASURES the time it takes between these closures and uses that as a "key velocity" which is used to control the loudness much like an acoustic piano. When one of the two contacts associated with that key fails, then the key velocity is set to MAXIMUM. The actual failure of the contact can be MECHANICAL or just contamination. The contacts are actually CONDUCTIVE RUBBER "pills" that are pressed onto circuit board traces to complete the circuit when the key presses down on them. The pills are usually in flexible silicone rubber "domes" that also act as springs to help restore the keys when released. Accessing these contacts to clean them is NOT for the DIY person normally. One cleans the pills AND the circuit board GENTLY with 99% isoprophyl alcohol and Q Tips cotton swabs. Opening the piano takes great care and is best left to a repair shop unless one is electronically adept.
Aug 15, 2011 | Kurzweil SP2 Keyboard Stage Piano
When i turn the sp3x on, the screen just blinks
That happened to mine. All I did was hard reset it.
May 25, 2011 | Kurzweil SP3X 88-Key Stage Piano
I brought my kurzweil sp 3X to a store to have them installed a new board on it, but after they installed the new board in, the character displayed on the screen are all in a weird organize and messed up....
It sounds like the new board and firmware has gone to abbreviations instead of fully spelling it out.
I would complain to the store since they should warrant it if it is a problem... but be prepared to accept that the firmware has been changed and displays differently now.
Mar 23, 2011 | Kurzweil SP3X 88-Key Stage Piano
After transport the keyboard,half of the keyboard below c4 not work.
Probably a cable has come loose inside the unit. The keys are scanned by the internal processor as a matrix of two contacts per key. Often the keyboard is divided into two sections.
You will need to have it repaired or if you are electronically adept, open the case and look for obvious problem.
Mar 17, 2011 | Kurzweil SP3X 88-Key Stage Piano
Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
Sep 17, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Kurzweil Music Systems Kurzweil SP3X 88-Key Stage Piano 886830131288 Logo
103 people viewed this question
Top Kurzweil Music Systems Music Experts
rhodesworks
John Potter
Joe Ball
Joe Ball
Are you a Kurzweil Music Systems Music Expert? Answer questions, earn points and help others
