Question about Samsung Cell Phones
Samsung galaxy note I having trouble with hearing outgoing calls and incoming calls but not all the time, any help please :D
Sometimes if I pop the battery out it will work again, but not always. I have recently purchased a new battery and am still having the same trouble. Please help. Thanks :D
    Producer:
    Uploaded 30 video answers.
  • Samsung Expert
  • 309 Answers
Try it to hard reset Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap the Power button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Posted on Jul 04, 2014
Raysagem
  • 1017 Answers
SOURCE: incoming or outgoing calls no sounds
Turn up the volumes on Ear piece -during- a call (on the side of the phone <===>) and on the speaker at any time. The joy stick does it I think.
Posted on Jan 01, 2008
joemxavier
  • 342 Answers
SOURCE: I have i mate ultimate
This is be fixed by resetting your mobile or You have to give your mobile phone for servicing.
Posted on Aug 14, 2010
  • 84 Answers
SOURCE: How do I asswer an
Answering a call:
When a call is received the phone rings and displays the caller's
phone number, or name if stored in the Address Book.
1. At the incoming call screen:
• Touch and slide to the right to answer the call.
• Touch and slide to the left to reject the call and send it to
your voicemail.
• Touch and slide the Reject call with message tab upward and tap
a predefined text message to send to the caller.
- I'm driving
- In a cinema
- I'm in class now
- I'm in a meeting
- Sorry, I'll call later
- or -
- Tap Create new message to compose a new message.
You may also click on this link to download the user manual for complete instructions with photos:
http://www.samsung.com/us/support/downloads/SGH-I897ZKAATT
Note:
"Answering a Call" portions is on Page 46
Posted on Jan 05, 2011
SOURCE: i cant my internet work on my new samsung galaxy y duous
save the proper gprs settings of internet service provider and switch ur device off and again turned on and enjoy
Posted on Dec 15, 2012
  • 113 Answers
SOURCE: Recover Samsung Galaxy S II lost photos videos
You may try a mobile phone data recovery software, recommended asoftech data recovery which helped me before. You can download trial for free
http://www.asoftech.com/adr/
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Posted on Jan 26, 2013
Hoe I do disable outgoing call FDN restricted
Fixed Dial Number (FDN), allows you to restrict outgoing calls to a limited set of phone numbers on your Samsung Galaxy Note 2.
How to enable FDN on Samsung Galaxy Note 2
  • From the Home screen, tap Phone icon.
  • Press Menu key and then tap Call settings > Additional settings > Fixed Dialing Numbers.
  • Tap Disable FDN.
  • At the prompt, enter your PIN2 code and tap OK.
Mar 10, 2015 | Samsung Galaxy Note II GT-N7100 16GB Gray-...
Accessing my bellsouth email account on samsung galaxy
Set your mail settings as below, but do it while you're connected to WiFi rather than cellular data.
Incoming mail server type: POP3
Incoming (POP): pop.att.yahoo.com
Incoming User Name: Full AT&T email address, including domain (e.g. yourname @ bellsouth.net, but without the spaces... the forum won't let me type it correctly because I'm new here)
Incoming mail port #: 995, secure connection (SSL) checked
Outgoing (SMTP): smtp.att.yahoo.com, with authentication (same user and password as POP)
Outgoing User Name: Full AT&T email address, including domain (e.g. yourname @ bellsouth.net)
Outgoing mail port # 465, secure connection (SSL) checked
Jan 05, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
I have samsung galaxy duos gt s 7582 having problem of no sound during incoming and outgoing call sometime
now i m in roming and my outgoing call is off but incoming is on..and software is also update but no soulation ...
Dec 11, 2013 | Samsung Star GT-S5233 Cell Phone
Can't make calls on Note 2
I have accidentally did something with the settings and suddenly i can't make outgoing calls. i've checked the default network its ok.A white screen appears and thats all. Please help.
Jun 23, 2013 | Samsung - Unlocked - Galaxy Note N7000...
My outgoing calls are barred how to deactivate it on my Samsung galaxy s duos
  1. Go to Apps through Home screen.
  2. Tap Phone.
  3. Tap the Menu key.
  4. On pop up menu select Call settings.
  5. Tap Additional settings.
  6. Tap Call barring.
  7. Tap Voice call.
  8. To disable call barring, tap each of the barrings types that you've enabled before.
  9. Enter your barring password. When you never change your barring password, then the default is 0000.
Apr 09, 2013 | Samsung Mobile Phone Galaxy Duo S S6102...
Samsung galaxy note 2 all outgoing voice calls are disabled- how to enabled it
I bought Samsung galaxy note 2. I can send SMS and receiving incoming call. But outgoing can't make it. Could you please tell me the reason and solution?
Mar 18, 2013 | Samsung GALAXY Note Smartphone Unlocked
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device
2.press& hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
Apr 11, 2012 | Samsung HM1000 Bluetooth Headset
RIM Blackberry Pearl Can't hear incoming/outgoing calls
After receiving a message with sound, push the button on the side that activates voice dialing. It sometimes takes activating it twice, but it will turn the sound back on.
Mar 05, 2009 | RIM BlackBerry Pearl 8100
Incoming or outgoing calls no sounds
Jan 01, 2008 | Samsung SGH-E900 Cellular Phone
Cell Phones Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
