Question about Kobo K107-KBO-64W - Arc Digital Text Reader
6201usb r005 need a charging flex cable 6201usb r005
How do i charge up my fitbit?
      To charge your tracker:
      1. Remove your tracker from the wristband:
      2. Insert your tracker into the charging cable. ...
      3. Insert the charging cable into a USB port or UL-certified USB wall charger.
      4. Your Flex's LED indicator lights will pulse to show the battery level every few seconds.
      More items...
      Help article: How do I charge my tracker? - Fitbit Help
      https://help.fitbit.com/articles/en_US/.../How-do-I-charge-my-tracker Fitbit
    Feedback
    https://help.fitbit.com/articles/en.../How-do-I-charge-my-tracker
    FitbitDec 12, 2015 - To charge your tracker: Remove your tracker from the wristband: Insert your tracker into the charging cable. Insert the charging cable into a USB port or UL-certified USB wall charger. Your Flex's LED indicator lights will pulse to show the battery level every few seconds.
    Fitbit Help - Getting Started
Jan 21, 2016 | Exercise & Fitness
Kobo problems
...back to the company you bought it from, perhaps?
Nov 28, 2013 | Kobo eReader
Samsung brightside will not turn on.
If the phone lights up when you plug in the charger it is probably the ribbon cable that flexes every time you open the keyboard. About 25 bucks from cellphonerepairshop.com. Be sure to flip up the little latches on the flex cable ends before attempting to plug or unplug the cable ends.
May 26, 2012 | Samsung Verizon Brightside Sch-u380 Black...
Screen not responding
I would remove the battery, reinsert the battery after a few seconds, and then charge it. If you have nothing on your screen, it could be either the screen is damaged or the flex cable that connects it on the inside is damaged. the flex cable is a tiny bus cable that's flexible, and is not able to be repaired, only replaced. They are usually around 20 dollars for either the LCD screen or flex cable, depending on the model.
Sep 04, 2010 | Samsung Star GT-S5233 Cell Phone
I can't charge iPhone, I got power surge warrning on my computer
hello friend,
maybe your cable of charging is nit genuine,
if warning displays in your phone then there is the problem in cable
and if the error displays in computer then the problem should be in battery or main board
Apr 22, 2010 | Apple iPhone Smartphone
Battery won't charge after replacing flex cable n95 8gb
Re-check the connections between the flex cable and board. Your problem may be a cause of a shorted pins... Good Luck... ^_^
Dec 11, 2009 | Nokia N95 Cellular Phone
How do I find and change the flex cable (patta) on the RAZR v3i?
try turn ur phone to bootloader moder by press all key together *#power and connect ,,,don't for to charge your phone using ur fren phone.let me if it connect
Jan 12, 2008 | Motorola Mobility RAZR V3i Cellular Phone
White screen
okay you need to change both the LCD and flex cable
Jan 03, 2008 | Motorola Mobility RAZR V3
SideKick Needs Repair
Change the flex cable the flex cable is the silver thing you see when you fold the screen half way
Oct 19, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Kobo K107-KBO-64W - Arc Digital Text Reader Logo
1,138 people viewed this question
Top Kobo Computers & Internet Experts
downhille
 Mikey
Mikey
Mark Schmit
Mark Schmit
Are you a Kobo Computer and Internet Expert? Answer questions, earn points and help others
