Question about Seagate Expansion 1 TB USB 2.0 Portable External ST910004EXA101-RK Hard Drive
How to toubleshoot Seagate Expansion 1TB external Desktop Hard Drive (9sf2A4-500)
  • 265 Answers
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
Posted on Feb 20, 2009
bob_computer
  • 3153 Answers
SOURCE: seagate 1tb external hd just beeps
You may want to open the drive and check the internal connections first to make sure none came loose after you have powered it down.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care. this is a real hard drive and knocks and bumps can quite literally kill them.
If a drive is CLICKING after an accident there is a very strong possibility that it is dead or dying. This is known as the "click of death".
Posted on Sep 07, 2009
bschilz
  • 2049 Answers
SOURCE: Data Recovery from Seagate Desktop Expansion 500GB External Hard
This is a solution I have used in the past and it has worked. It's a Seagate Recover utility for end users.
https://services.seagate.com/diysoftware.aspx
If the data is absolutley critical and very valuable, you can send it to Seagate and they are very good at recovery as well. It gets a little pricey at $800, but I too have had to use that as well for mission critical data I could not afford to lose.
https://services.seagate.com/consumer_standard_services.aspx
Posted on Nov 06, 2009
  • 126 Answers
SOURCE: Formatting my Freeagent 1tb external hard drive for my Mac?
the problem is that your western digital operates using the NTFS (New Technology File System) which is the standard file system of Windows. Apple macs is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Posted on Jul 30, 2010
  • 285 Answers
SOURCE: My Lenovo laptop won't recognize my seagate
i think its because its usb 3 usb 2 how old is your ibm laptop if its really old they only have usb 1
Posted on Mar 28, 2011
Seagate Expansion 1TB Portable External Hard Drive USB 3.0
Try with proper USB 3.0 drivers obtained from Intel, must work with original cable on the USB 3.0 computer port.
Feb 13, 2014 | Seagate Expansion Computers & Internet
Unexpected turn off
Can you navigate to the external drive via Windows Explorer?
Did you try restarting your computer? Unplug the external completely, then reconnect it?
Oct 21, 2013 | Seagate FreeAgent Pro 1TB External USB...
Seagate Expansion 1TB external Desktop Hard Drive (9sf2A4-500) not detected.em?
Sounds like driver problem to me. Re install the driver by using installation disc, or if you have lost your CD, than use this Driver Update Software to update. I hope this helped.
Brian
Oct 24, 2012 | Seagate Expansion 1 TB USB 2.0 Portable...
Claire,
Have you tried connecting the drive to another computer using Windows 7 or later. You could try chkdisk /f at a command prompt or get the testdisk app to identify deeper issues with the drive.
Chappo07
Oct 24, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Install seagate expansion
New drives have to be readied for use. Try Start > Run (aka Search in Win 7) type dskmgmt.msc. Look for your drive there. It should be without a drive letter. Right clicking will give you the options of initializing, creating disc partitions, and assigning logical drives. If this seems a little daunting. A wizard should load. If not there is refresh icon on the tool bar. You may want break down the 1TB down to a few partition because of the large size.
Aug 30, 2012 | Seagate 1TB Expansion External Desktop USB...
I have a 1TB seagate expansion external hard drive and i was wondering if i had to plug it in to a power source other than my computers usb port. My teacher has has some really small one and that didn't...
Some do and some do not. if there is no power input jack for DC input then you don't need external power. The 5 volt supply to the USB will power it fine.
Jan 18, 2011 | Computers & Internet
Cannot safely remove my Seagate Expansion Hard Drive...
download ccleaner from google for free and install it whenever u want the drive to be safetly removed use ccleaner before remove of the drive. if this doesnt work format the disk and the try as it may occur due to virus.
Feb 20, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
Seagate Expansion 1 TB USB 2.0 Portable External ST910004EXA101-RK Hard Drive Logo
63 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
