Question about HTC Velocity 4G Smartphone 3G 850MHz AT&T Unlocked Import
Htc velocity isnt charging
So I've got a HTC Velocity and I bought a new battery a few days ago and a new cable for the charger. All it does is flash a light blue colour on and off for about 3 minutes then the screen stays black. Anyone have any idea what's wrong and how to fix it? Thanks
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 61 Answers
Seeing as you've replaced all of the charge components, you have narrowed down the list of things that could be causing your problem considerably.
Basing my professional opinion strictly off of the information provided, your device is no longer able to render a charge from your battery. The port that actually holds your battery must not be accepting a charge from the battery.
Thanks,
Dish Guy
Posted on May 19, 2014
Testimonial: "Thanks for your answer. So there is no way I can charge my phone at all now?"
270rexton
  • 762 Answers
SOURCE: HTC TOUCH HD charging problem
Well hope so you didn't damaged the sensors! try this : use the phone until battery is empty and switches off. then put it on the charger for 4 hours. If no joy,try different battery to make sure that device is not damaged and get a new battery.
Posted on May 12, 2009
SOURCE: HTC Hero is running very sluggish! Need Help!!
Things which might cause a fresh HTC Hero to run slow:
1. Numerous concurrent connections (sync'ing with GMail e-mail, contacts, calendars) 2. Running WiFi 3. Running GPS 4. Running Bluetooth 5. Large number of contacts 6. Numerous browser windows open
Of course, it could just be the bloatware from the carrier. For a lean machine, start with a clean Android kit. If it's still not moving fast enough, you can overclock with Overclock Widget. Again, you'll need a rooted phone to use this.
Posted on Jan 06, 2010
jerseymark
  • 358 Answers
SOURCE: My battery does not charge
Hello, why the phone is not charging is because the cell of the battery is weak and can power on the phone for to long, that's why it shots down so quick,
You will need to replace battery with a new one for longer talk hours.
Make sure you charge battery for 6hours before use.
And also if the battery still doesn't work that means the phone memory is weak and it will need to be flashed to restore back the phone memory.
What you will need to do is this,
You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Posted on Sep 12, 2010
shibuda
  • 1812 Answers
SOURCE: My HTC Desire HD has just frozen. The screen is
Please reset the mobile ,
Resetting Your Device Soft reset Occasionally, you may need to reset your device. A soft(or normal) reset of your device clears all active program memory and shuts downall active programs. This can be useful when your device is running slower thannormal, or a program is not performing properly. A soft reset is also necessary afterthe installation of some programs. If a soft reset is performed when programs arerunning, unsaved work will be lost. To perform a soft reset 1. Remove theback cover. 2. Use the stylustip to press the RESET button located between the SIM card and the storage card slots. Your device restarts and displays the Home screen. Hard reset You can also perform a hard reset (also known as a fullreset). A hard reset should only be performed if a normal reset does not solve asystem problem. After a hard reset, the device is restored to its defaultsettings-the way it was when you first purchased it and turned it on. Any programs youinstalled, data you entered, and settings you customized on your device will be lost.Only Windows MobileĀ® software and other pre-installed programs will remain. Warning! Your device will be set back to factory default settings. Make sure thatany additional installed programs and/or user data have beenbacked up before you perform a hard reset. Managing Your Device Important IfEncrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset,or updating the ROM system software. Otherwise you will no longer be able toaccess the encrypted files on the storage card. Use ActiveSync or WindowsMobileDeviceCenter to transfer files between your storage card and computer. After theprocedure, copy your files back to the storage card. To perform a hard reset 1. With thedevice turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button. 2. Continuepressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen: This operation will delete all your personal data, and reset all settings to the manufacturer default settings. Press VolUp to restore manufacturer defaults, or press other keys to cancel. 3. Release theVOLUME UP and VOLUME DOWN buttons. 4. Press theVOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Posted on Jan 26, 2011
  • 128 Answers
SOURCE: HTC Hero won't charge. I
U can call your service provider they might be able to help ifthey cant assist you contact the phone manufacture either way you will get ananswer to your problem.
Posted on Sep 01, 2011
Htc wont charge and turn on
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
May 02, 2013 | HTC Flyer 7 inch 32GB Android Tablet PC...
Htc velocity 4g touch screen problems
3afd13ca-3b2c-496a-a53e-97d5b2c0b4ff.png 3e069d44-a10c-4b8e-8e66-1b3e49acaf0b.png
Sometime my touch acts like in screen one ... and sometimes this dead area work perfect and some other get dead ... these are two places that keeps rotating .. help
Feb 22, 2013 | HTC Velocity 4G - 16GB - Black Unlocked...
Velocity cruz not charging
The charger can be tested for proper voltage coming out in most cases- either the battery is bad, the charger, or the connection where the charger connects to the unit.
Nov 06, 2012 | Velocity Micro Black Cruz T301 2gb Wi-fi...
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
Htc chacha wont turn on and orange light flashing
The battery is completely dead, charge for about 1 hour; if flashing light continues then you need a new battery, I've just done this to my phone..
Mar 29, 2012 | HTC Chacha Smartphone
Manual for HTC Velocity 4G
http://manualcentre.blogspot.com/2012/01/htc-velocity-4g-manual.html
Feb 17, 2012 | Cell Phones
HTC Hero won't charge. I bought a new battery...still won't charge. I've tried a wall charger and a car charger and neither of them work.
Sep 01, 2011 | HTC Hero Smartphone
May 12, 2009 | HTC Touch HD Smartphone
Helppppppppppppp
well u pronobley need a new battery
Nov 05, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
HTC S710 - Battery issue
it could be either battery or charger, If the charger isn't supplying enough power it will fool the phone..
some 3rd party batteries and cheapo chargers can cause all sorts of problems like this.
best way to test is charge your phone by usb, it takes longer but will give you some idea of weather its the battery or charger.
Make sure that the box at the bottom of the power management window (dont charge by usb) is set to off. Also for best results remove any other usb devices from the computer this will leave more power for the phone.
Best of luck
Jun 05, 2008 | HTC S710 Smartphone
HTC Velocity 4G Smartphone 3G 850MHz AT&T Unlocked Import Logo
65 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
