Question about Russell Hobbs Coffee Makers & Espresso Machines
WHISK ON RHMF3 MILK FROTHER IS NOT ROTATING. IT IS MAKING A HIGH PITCH WHINE.
MILK FROTHER RH MF3 WHISK IS NOT ROTATING. HIGH PITCH WHINE.OUT OF WARRANTY.WHAT IS THE CAUSE? IS IT REPAIRABLE???
  • 37 Answers
SOURCE: Frother not working
The frother does not have a vacuum, it uses venturi pressure to draw up milk through a venturi at the top of the steam feed. The milk side is clogged from not cleaning enough. soak in boiling water for a few minutes and try to run it in steam mode for a while... if that doesnt work, a light lye solution will dissolve the milk residue clogging it. neutralize the lye with vinegar drawn through after the clog is gone.
(lye will dissolve you as well as milk... use gloves and don't put your face near it while it's working.)
Posted on Apr 19, 2009
  • 109 Answers
SOURCE: the milk frother is making the milk spit out of
Check the end of the frother,ensure the center is protruding.
If not remove the lower end of the frother and push the center towards the end and click it into place.
This is a very common problem.
Posted on Feb 05, 2010
SOURCE: Lost my Nespresso Aeroccino Milk Frother Hot Milk Whisk
Call Nespresso customer service at 800-562-1465. Replacement set of 2 wisks were $2.95 + shipping
Posted on Jul 01, 2010
  • 128 Answers
SOURCE: the milk frother is not
it is clogged with dried milk. Remove the frothing wand from the machine. now press milk froth. you should get a ton of steam blowing out of the hole where the frother used to be. Your frother comes apart for cleaning. pull the chrome tip off, pull the 90 degree fitting and the black milk suction tube off, if it is really dirty you can soak the disassembled frother in hot water with a cleaning tablet. ( the small ones you drop in the brew unit, not the big descaling tab.) also, there is a clear tube with a point on the end of it sticking out of the frothing wand. this is an air admittance oriface. it allows air to enter the hot milk stream and make it frothy and bubbly. if it gets clogged, you will get hot milk but no froth. Your machine came with a spare one in the parts kit.
Posted on Jul 19, 2011
SOURCE: the milk frother has stopped
The solution to rotation issues with the frother have been soved finally by myself after reading all the suggestion. The fix is simple... Your attachments have been magnitised and need to be demagnetized. It works a beauty. Run a magnet around the metal rings. Hint. Never leave them on the the frother when not being used.
Posted on Jan 06, 2013
Frother overflows even though I add correct amount of milk, or even less than called for
There are two milk amount markings in the Aeroccino - one (less) for use with the wire whisk attached, and one (more) for use when the wire whisk is detached. I had the same problem when I first used the Aeroccino, but with the correct amount of milk you shouldn't have the problem.
I hope this helps, Carole.
May 20, 2015 | Nespresso Aeroccino Automatic Milk Frother
What are the parts of the central ''spinner'' of a milk frother?
There are no moving parts in the frother other than the whisk assembly. The whisk assembly is spun magnetically. I am not sure if it is possible to have the magnet in the whisk assembly in the wrong orientation, but if so, be sure that it is reassembled with the magnet side down. Additionally, if I haven't removed the whisk in a while (I normally just immediately rinse and wipe the interior with a cloth) then the metal stem can build up with milk solids... and cause the whish to "stick"... the magnetic force is not exceptionally strong and it could be that the plastic assembly is "sticking" on the metal post... pull off the whisk and give the post a good wiping with a wet cloth to remove any possible residue.
Jul 24, 2014 | Nespresso Aeroccino Automatic Milk Frother
My nespresso aeroccino automatic milk frother is spinning and heating up but not frothing milk
I found that switching to a different milk solved my issue. It worked well with whole milk, but when I used Trader Joe's two percent organic it would not froth after .multiple tries. I borrowed a neighbor's creamer and it worked again.
Oct 13, 2012 | Nespresso Aeroccino Automatic Milk Frother
Where can I find a replacement or spare wisk attachment for an Aeroccino milk frother?
Contact the Nespresso Club at 800.562.1465. The replacement frothing/steaming whisk set, item number 13192/6, is currently available for sale at $2.95. .Shipping is flat fee of $6.95
Nov 30, 2010 | Nespresso Aeroccino Automatic Milk Frother
The wireless whisk jumps off the port shortly after starting. The container is clean, dry, and I have tried different amounts of milk; but the whisk still flips off.
If the frother is less than a year old - or even if it isn't and you buy pods regularly - call up Nespresso. They will send you out a new piece because your piece isn't magnetic enough. This happened with my friend and she had the new parts within two days.
Oct 18, 2010 | Nespresso Aeroccino Automatic Milk Frother
Lost whisk. how can I get a replacement?
They sell the parts at the Nespresso.com, I also saw the frother for sale on ebay
May 04, 2010 | Nespresso Aeroccino Automatic Milk Frother
Wisk popping off
I have this same problem!
frother works fab, black whisk pops off every time i try to steam milk
Mar 31, 2010 | Nespresso Aeroccino Automatic Milk Frother
Feb 02, 2009 | Nespresso Aeroccino Automatic Milk Frother
Need replacement frother part for Nespresso Aeroccino
both parts can be found on amazon for about 9.99$. take a look here: Secura Automatic Electric Milk Frother and Warmer Whisk Set. I hope this was helpful. cheers
Sep 02, 2008 | Nespresso Aeroccino Automatic Milk Frother
Coffee Makers & Espresso Machines Logo
46 people viewed this question
Top Russell Hobbs Coffee Makers & Espresso Machines Experts
Paul Bade
ray gallant
Tom Chichester
Are you a Russell Hobbs Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
