Question about Frigidaire FRS23H5AS Side by Side Refrigerator
Ice machine is not getting water. changed the filter. water works still no ice
  • 396 Answers
Check your manual, there is a wire or device to shut off icemaker when the ice bin is full it is pushed up to stop the ice making process. Make sure it is not stuck in the up position (off) and is pushed down so it can freely move up and down. If that is not the problem it could be a bad micro switch for the shutoff device or a bad water valve.
Posted on Jul 14, 2009
Why is my ice dirty
There are two ways to get dirty ice - dirty water or a dirty machine.
If the water that the machine is processing is dirty, you'll get dirty ice. Check that your water filter is working properly, and that the filter core is in good condition. If the water supply to your machine is really dirty, consider a double filter.
Also, check inside your machine for deposits of silt, minerals or other undesirable materials. Clean out the inside of the machine thoroughly, but don't use any household cleaning products or acids - they will damage your machine or leave an undesirable perfume which will contaminate the ice - Just use water. Also don't use anything abrasive on the internal surfaces. If there are mineral deposits, you can dissolve them with household vinegar by soaking them or spraying them continuously, and then rubbing with a non-abrasive sponge. There are also commercial solvents especially for icemakers. Rinse the machine thoroughly to remove any odours, and throw away the first harvest of ice.
Nov 05, 2013 | Kitchen Appliances - Others
Ice machine making cloudy ice
ice maker may need cleaning, filter and/or scale collector changed. IF there is no water fiter you should add one.
Jan 23, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
Ice machine not getting water
Change the dual water control valve if not getting water during cycles.
Sea Breeze
Jun 08, 2012 | Kenmore Refrigerators
I have a Daewoo FRN U20DA type american fridge freezer. The Ice maker has sropped working. There is no water getting into it. There is water getting through to the water dispenser in the front door. the...
The water filter should be changed every six months, not two years.
The water lines may still be frozen even though you turned the unit off, but most likely you are not getting water flow due to a clogged filter. Change it.
Feb 26, 2011 | Daewoo Freezers
My ice machine no longer produces any ice cubes? the machine is about 3 years old. Got it from Home Depot. Is this under warrenty? who should I call for repair service or what can I do to determine a...
If the filter is really bad it won't make ice becuuse the water can't get to it. A way just to check to see if the icemaker is working is to pour a small cup of water into the icemaker and see if runs through the cycle a makes a batch of ice, try the cup of water before you call anyone. If it makes ice then either you need to change the filter(which you should do anyway) or you have a bad water valve. If it doesn't make a batch of ice then your icemaker is bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Oct 31, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
LG SIDE BY SIDE - REPLACED FILTER BUT WATER VERY SLOW
You may have ice building up inside the fill tube that is slowing the water flow.  You will have to remove ice maker to see inside the tube.  If the tube has ice buildup, use a hair dryer to melt the ice.  Then is should work fine.
May 23, 2008 | LG LRSC-26922 Side by Side Refrigerator
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice maker not getting water
check your water valve you have 2 located at lower back of refrig.
Dec 11, 2007 | Whirlpool GD5SHAX Side by Side...
Frigidaire FRS23H5AS Side by Side Refrigerator Logo
127 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
