Question about Dryers
How to open a Seville classics 10177 - Dryers
Seville classic fan was cleaned and now it will not come on.
Dry out!!!!! Why would you get it wet? Anyway, check the reverse switch to make sure it's in the correct position.
Feb 24, 2015 | Seville Classics Dryers
My seville classics tower fan no longer oscillates - how can that be fixed?
Throw it away and buy a new one for 20 box at Wal-Mart. It's as simple as that cause to fix it, it'll take a new machine which cost twice the price. I think they made it to last one summer max. Friendly yours
Jul 01, 2014 | Seville Classics MSC10166 Tower Fan
The voltage regulator 74711-08 fits on HD XR 1200?
In the 2013 sportster parts manual it fits ALL models and it comes with PN 10177 strap
Oct 23, 2013 | 2010 Harley Davidson XR1200
HOW DO YOU CLEAN THE INSIDE OF THE SMALL PERSONAL SEVILLE
Put it in the dishwasher, leave it in the sun for 2 days to dry out.
Apr 15, 2010 | Dryers
The fan fuse 1.5A/250V is keep blown up as soon as
Unplug the fan.
Open it up carefully.
Look at the the wiring for damage or shorts.
Check that the fan impeller is free to turn.
If all of the above is OK then possibly the motor has gone? If so then it will probably be cheeper to buy a new one.
Jul 02, 2009 | Seville Classics MSC10166 Tower Fan
How to open tower fan to clean it
Use compressed air to blow the dust etc. out of the unit.  You can purchase a  can of compressed air from Home Depot or Lowes, or Google "compressed air in a can."  Just make sure you clean the unit outside to keep the dust etc. out of your home.
Mar 22, 2009 | Dryers
To take apart: see solution #1 (not a complete disassemble but helps)
Aug 15, 2008 | Seville Classics MSC10166 Tower Fan
Possible Solution :
Taken From :
http://www.fixya.com/support/t193631-am_trying_fix_oscillating_tower_fan
"Most fan motors for fan over running have an internal overload. once it trips, it will not reset. it is a solid state device. it looks like a flat device or a small bullet device. if you've figured out how to take the fan apart, you could just remove the device and connect the two wires together and the fan will run. you won't have any protection on the motor however. the windings run warm, but if the bearings run dry the motor will slow down and the windings will get hot. this is the reason for the overlaod device - protection. its your call what you want to have."
Aug 14, 2008 | Seville Classics MSC10166 Tower Fan
Seville classics model 10166
bottom stand was broken. how to get new bottom part.
Dec 06, 2007 | Seville Classics MSC10166 Tower Fan
Dryers Logo
24 people viewed this question
Top Dryers Experts
