Question about Car Audio & Video
Ford laser kh what size speakers - Car Audio & Video
  • 4 Answers
SOURCE: radio code
I had the same prob. you will have to take it back to dealer to get a new code. Can be expensive. Shop around for a fiesta radio / 6 CD stacker unit already with a code. Mines out of a '98 fiesta into my '85 Bronco ! Stacker unit fits under passengers seat, cable back to dash via under carpet. Mine was cheaper to buy (from a wreckers) and install my self than the dealers costs to get the new code for an old unit. on-line wiring diagrams avalible.
Cheers !
ozzy
Posted on Feb 22, 2009
  • 7 Answers
SOURCE: horn wiring on kh laser
It could be that the horn needs to be replaced or a fuse or a relay not working also check the horn button on steering wheel, but start with the fuse first then check the horn by wireing it directly to battery [this willbe noisey]
Posted on Apr 19, 2009
  • 54 Answers
SOURCE: Need Valve clearance for '93 kh ford laser
0.10 - 0.15mm inlet
0.18 - 0.23mm exhaust
but you must be carefull because the top of the valve seat becomes concave from wear, a feeler guage will not give the most accurate reading, hope i have been of some hel
Posted on May 14, 2009
  • 4874 Answers
SOURCE: battery flat and have no
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove the radio from the dashboard.
Then post the SERIAL NUMBER found on a label on the etal casing
Posted on Aug 21, 2010
alicantecoli
  • 22246 Answers
SOURCE: I need a wiring diagram,
alicantecoli.jpgprobally no good but here is a wiring diagram layout for a window switch ,if you do not know the colours then use a test meter to find out what wires go where
Posted on Nov 03, 2010
How do you change a timing belt in a ford laser kh 1992 model car?
so fortunately for you the ford laser and the mazda 323 are one in the same. i would refer to this video to see if you can get a full walkthrough of how the process works. below are two links the first is the video the second is a google search with multiple links may be helpful to you as well.
Water Pump Timing Belt Replacement Mazda 323 Google
Nov 04, 2015 | Ford Laser Cars & Trucks
I need a diagram of an ignition control module for a 1994 kh ford Laser
there should be a ford website that you could look up this information. you could also visit a dealership or local auto parts store.
Apr 19, 2013 | Cars & Trucks
94 kh ford laser has no spark, I changed the coil, still no spark
check high tension cable for it's resistance, if found faulty, replace.
Sep 22, 2012 | Ford Laser Cars & Trucks
Where can I get a wiring diagram for a 1992 Ford laser KH 1.6lt
It seems the Ford Laser is the same vehicle as the Mazda 323. You can get a manual online here for $15:
http://seo.chiltonsonline.com/Pub/DIY/Product.aspx?ca=Repair&b=17598
May 27, 2012 | Ford Laser Cars & Trucks
Battery flat and have no security code for car radio. ford laser hatch KH 1991.
Aug 21, 2010 | Car Audio & Video
I have a 93 Ford Laser hatch back and I need to know the radio wiring color codes for the wires that plug into the back of the radio-cassette. 1)Orange-green tracer 2)Orange-black tracer 3)Grey-green...
OK this is what I did: First I soldered a wire each end of a 1.5v battery. I then bared the other ends of the two wires and tinned them. Then I touched the wires coming from under the dash in pairs until I heard the resultant sound coming from a speaker. This then told me the position of each speaker in the car. From there it was just a matter of noting the color codes for each pair of wires and from which speaker they came. My Gregory's Laser KH manual had wiring codes, but entirely different to my vehicle. Also there is no indication of what color matches what letter code! Cheers. Gerry
Dec 19, 2009 | Philips Car Audio & Video
0.10 - 0.15mm inlet
May 14, 2009 | 2006 Ford Laser
Horn wiring on kh laser
Mar 01, 2009 | 2006 Ford Laser
Water leaking into KH laser Hatchback
It could be coming in through the rear door as the rubber might not be sealing properly the easiest way to find the leak is to remove your seats and carpet sit inside get someone to squirt the car round the doors and windscreen air vents.
Feb 25, 2009 | 2006 Ford Laser
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
