Question about Whirlpool GHW9200L Front Load Washer
Low water level
I purchased a used (thus no warranty) Duet washer and notice that even though the clothes get wet, there is no visible water in the basket and thus there is no splashing during tumbling to even begin to create suds. Is there supposed to be any visible water in the bottom of the basket during wash and rinse?
I hope this is just a sensor replacement or adjustment (like how I fixed my erroneous low water flow H/T shutdown problem by turning the water flow sensor exactly vertical so that the paddle wheel is directly above the hose).
Is there supposed to be any visible water in the bottom of the basket during wash and rinse, and if so, what do I do on my own to correct for too low water level?
  • Anonymous Dec 27, 2007
    The same problem with my NEW machine. Is this the correct way the machine works?
    It just seems strange not to have some water showing in the basket
  • eyelovett Jan 10, 2008
    I also just purchased a used duet and am noticing the same issue. Have you gotten any answers? Is this how it is supposed to be? I can't imagine how the clothes will get clean with so little water.
  • 249 Answers
It depends on how old the machine is, the newer machines by law,take in way less water but still wash ok. TIP.try it with out load and check water level Ire bye
Posted on Nov 24, 2007
Lg intello WD1243FH low water level? My Lg will not fill with water properly. It only lets in enough water to get the clothes wet then stops filling. I tried filling it manually through the drawer but as...
Try adjusting the water lvl going into the washer. Adjust accordingly. If you have a meter, just the resistance of the valves. Unplug of course. It should read about 1.4k ohms ish. Could be higher or lower but roughly that.
Apr 28, 2010 | LG Washing Machines
Whirlpool Duet 9150.. should I be able to see water in the tub when it is washing? There is no visible water level. The clothes are wet but how do they get clean?
water is drawn THROUGH the clothes. There is a BIT of water in the drum - however the water sprays on the clothes during the wash cycle and draws the dirt/water/detergent THROUGH the clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water level too low. clother wet. No water visible or suds. What is wrong.
Your expectations are based on top load washers.
Front load washers use only a very little water, and suds are an enemy. (HE soaps are designed to clean without suds. Suds are really for show and cause drag on the wash tub during spin.) If you start a load with no clothes, you will see that the water level never gets above a couple inches in the tub. That is the correct water level for front loading machines. PS. Because of the low water use, make sure you use very little soap. (one to two tablespoons per load only!)
Aug 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
Not enough water per load and suds
if you use washer without cloth you will some water and it is normal..use different detergent and use less you will be ok..hope that help you.
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Not enough water per load the cloths get wet but there is no water floating in the drum should there be water visible on the door?
not really...that's the point of these washers..low water usage. the clothes fall into a small puddle in the bottom over and over and rinse often.
Jun 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9400 Water Level Seems Too Low
Believe me, if the water level were ever several inches above the glass, you'd know about it 'cause it would flood your laundry room. Seriously. See? That rubber door boot/seal is not water tight (like a submarine) when the door is closed and locked, it's water "resistant".
Front loaders often appear as though the level is low, but they are designed this way. The clothing actually tumbles through the water as opposed to soaking in water like a top loader.
All of that to say that you have nothing to be concerned about. Your water level is fine.
p.s. If your water level switch had failed, as you suspected, the water level would be too high and leak out the door.
Apr 03, 2009 | Whirlpool GHW9400 Duet Washer
Can i adjust the water level on my Duet?
Sorry there is no way to adjust the water level. the washer decides how much water by how much clothes are in the washer .
Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leak where water enters drum
I would say you havda inlet valve. With the washer not in use and empty after about 2-4 hours do you notice that you have a semi full tub? If it is filling with water by itself you have a bad inlet valve all you have to do is take the top panel off you will see the valve it's what is attached to the fill hoses. When you have dirty lines the dirt goes through the solinoids and keeps them open causeing the water to come in when not in use.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wash cycle water level
the water needed needs to just come up right under the door this is how much water they use cause they use a tumble wash to clean the clothes
low water preasure is a problem but also make sure both water inlets are being used (hot and cold) even if you dont have hot attach a y hose the machine needs both inlets in use
these machines use very low water usage but they still need a fill up point
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9200L Front Load Washer Logo
240 people viewed this question
Dan Webster
Dan Webster
Sal De
