Question about iRobot Roomba Discovery SE Bagless Robotic Vacuum
Why don't my robot brushes turn? - iRobot Roomba Discovery SE Bagless Robotic Vacuum
    New Friend:
  • 3 Answers
Remember that at least every week you need to take out the brushes, and pretty much everything else that is removable and thoroughly clean them, including the brush hubs. If you have access to compressed air, gently blow out dust/dirt from all the sensors. Regular cleaning is mandatory to keep your Roomba running correctly. In my experience, a good cleaning solves most Roomba issues. Regular cleaning prevents most issues.
Posted on Jul 19, 2014
2 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: robot runs for about 5 min. then says clean
The dust build up in these Roomba's do create a problem in all operating phases
Keep in mind if taken apart every 6 months and cleaned inside they will operate like they should
Posted on Jul 03, 2010
Discover irobot brushs womt turn
Are they wrapped up with hair, thread, dental floss? If so clean them. Were the brush and beater bar replaced incorrectly in the past? The square end has to fit on the square side, etc.
May 13, 2014 | iRobot Roomba 560 Robotic Vacuum
IRobot rumba 4000 seems to run ok and then starts making a kinda hi pitched growling noise and slows way down. it is very clean(blown clean with air compressor)sensors are clear ,newly installed well...
It sounds like your Roomba's brush gears are not working. Run the robot without the dust bin to see if the brushes are turning. If they are not, the robot will need to be replaced. Contact iRobot CS for support at (877) 855-8593.
Dec 05, 2010 | iRobot Roomba 4000 Bagless Robotic Vacuum
Robot runs for about 5 min. then says clean brushes. brushes do not turn
Jul 03, 2010 | iRobot Roomba 560 Robotic Vacuum
Discovery brushes won't turn. All bearings clean.
usually fibre jammed in wheel / brushes. try small hook run around spaces in unit toremove usuall human hair
Sep 14, 2009 | Roomba Robotic Floor Bagless Vacuum
Brushes won't turn
the mechanisam that makes the brushes spin are broken. take it into a shop dont fool with a roomba
Sep 11, 2009 | iRobot Roomba 560 Robotic Vacuum
Can not charge thr battery
bbaker58,
When you press the "clean" button after charging, does the Roomba give you any audible tones? Those tones are the key to understanding failures in the 400 series. See chart below to decode those tones
If you get no tones at all, then either (1) you're not getting power from the battery to the main circuit board or (2) the main circuit board is dead. You really have to open the unit up to figure out which it is. Circuit board replacement is a pretty involved procedure since it requires disassembly of almost the entire robot. If you are brave and want to try it, replacement PCAs are available from places like www.RoboticVacParts.com. They are my favorite shop because they sell parts tha iRobot refuses to sell to consumers and they're prices always beat what iRobot charges.
Roomba Says
What It Means
What You Should Do
Plays 4-note song as Power button blinks RED
Play sound The battery is low and needs recharging
• Connect the robot to the charger or Home Base® and recharge the battery. “Ehh”
Play sound The Cliff Sensors are dirty or malfunctioning
• Pick up your robot and turn it over.*
• Check for any debris that might be caught underneath the front bumper, around the Cliff Sensors.
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out.
"Uh-oh"
A wheel is stuck or is not touching the ground
• Lift the robot and place it down again.
• Press the Clean button to restart the cycle. “Uh-oh” plus 1 beep
The robot's main brushes are stalled
• Pick up your robot, turn it over* and remove the wire guard.
• Look for something blocking the brushes; you may need to remove and reinstall the brushes to remove the obstruction. “Uh-oh” plus 2 beeps
The robot's Side Brush is stalled
• Pick up your robot and turn it over*
• Check to see if something is wrapped around the Side Brush.
• Remove the Side Brush with a screw driver and check for string or hair wrapped under it.
• Replace the Side Brush, place Roomba in the center of the room and press Clean to resume cleaning. “Uh-oh” plus 3 beeps
The robot's vacuum is stalled
• Remove and empty the Dirt Bin.
• Use a flat-head screwdriver to remove the grill at the back of the Dirt Bin.
• Spin the Vacuum Impeller around, shaking out any debris that may be stuck.
• Replace the grill and the Dirt Bin. “Uh-oh” plus 4 beeps
Play sound
The robot's Drive Wheels are stalled
• Your robot may be stuck, or something may be caught in a wheel.
• If it's stuck, place it in the center of the room and press Clean. It should resume cleaning.
• If it is not stuck, lift the robot, turn it over* and look for something caught in the wheels. Test the wheels by pushing them in and out and making sure they rotate freely. Place robot in the center of the room, press Clean, and it should resume cleaning.
If this continues to happen every time you clean, you may need a software upgrade. Contact iRobot Customer Support.
“Uh-oh” plus 5 beeps
The robot's Cliff Sensors are obstructed
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out. “Uh-oh” plus 6 beeps
The robot's Wheel Drop Sensors are overloaded (robot is stuck in a bumpy area)
• Pick up your robot, place it in the center of the room, then power it off and then on again.
• Select the cleaning cycle you prefer and let it go to work.
“Uh-oh” plus 9 beeps
The robot's Wheel Drop Sensors have failed at startup
• This failure requires you to contact iRobot Customer Support. Click here to send us an email. “Uh-oh” plus 10 beeps
The robot's bumper is not registering obstacles
• If the robot travels for a long distance without bumping into anything (which would be unusual), it might think it’s stuck and can’t move; press Clean again and it should resume cleaning.
Jun 02, 2009 | Roomba Robotic Floor Bagless Vacuum
IRobot not picking up dirt
try to replace the filter, that should work.
Feb 23, 2009 | iRobot Roomba 530 Robotic Vacuum
Trilobite robot Frozen beater brush continual running error
If you can't find proper service from your country, please send your Trilobite to Finland
So have done some other people around europe too! :)
I am a professional with Trilobite robot's.
No service manual available, even for me...
For error 10 (power failure) there is several possible "burned" component's. 8 to 10 can be in same time faulty
Different in every time
After two weeks investigation I usually put totaly new prosessor card.
Address for service is:
Oy JVV Tekniikka Ab
Mestarintie 43
SF-28800 PORI
tel. int +358 400 126597
remember add your return address with short description of fault and put the charged in the parcel
Dec 14, 2008 | Electrolux Trilobite Vacuum
4296 Robotic Vacuum _ Brush quit spinning
i had the same prob. i contacted i-robot and was told the motor that turns the brush is shot. there is no replacement part. they offered to replace my i-robot with a new one from the 400 series. at about 60% of a new one. that's the only option that i know of.
Apr 09, 2008 | iRobot 4296 Robotic Vacuum
iRobot Roomba Discovery SE Bagless Robotic Vacuum Logo
71 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
