Question about Sunbeam Heating & Cooling
My room is not cool
My room is not getting that cold
    Novelist:
  • 166 Answers
If your room is not getting cold enough when your A/C is turned on, It is time for a good cleaning. There are a variety of factors that may cause your A/C to not cool your house. With that said, here is a diagnostic article that provides the most probable causes of your A/C's failure to cool your house, and from there you can read it and then, step by step, rule out each possible cause listed in the article:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Of course, a low level of Freon/refrigerant may be the problem, but there may be other problem causes as well, as noted in the article---it may just be that debris is obstructing your AC as well. Read the article, and, if need be, take advantage of the link for free four (4) quotes and "pick the brain"--seek the advice--of these technicians who offer you a free quote to discern what could be the problem.
Posted on Jun 24, 2009
I have my brand new frigidaire window ac unit set at 60 degrees Fahrenheit, so why does it only cool and keep the room at 65 to 68 degrees Fahrenheit?
if you have it set at 60 F and it is working at 65 to 68 F then that would be about right
as the air is cooled the cold air falls to the floor and out under the door, open window or anywhere else it can escape
the unit has to be at 80% room height so if it is set in a window then when the cold air gets up to the thermostat or ac level in the window then it will stop cooling
So if the ac unit is say 4ft from the floor and the ceiling height is 8 ft then the ac will only cool the bottom 4 ft
cold air does not rise but falls down
if you are using a ceiling fan then the cold air is stirred up and the 65F sounds about right
remember that the setting temp ( what you set it at) is the lowest temp that it will go down to before it stops cooling and if that is not reached it will keep working to attain that temp and if the room is too big, air leaks under door . around the fit in the window , no insulated walls , hot exterior wall,etc then maybe 65 F is the best you will get
May 09, 2016 | Frigidaire Heating & Cooling
Remove exhaust hose
U need that hose to direct the warm air outside the area to be cooled. If you remove it, the hot exhaust will stay in the room being cooled and negate the cold air being directed into the room.
That is why regular room AC units are mounted on window sill. Cold air in, hot air out.
Oct 08, 2015 | Haier Commercial Cool 8,000 BTU Portable...
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Blows very cold air during dehumidify mode.
se this fact: God bless you
air conditioning system cools but does not dehumidify the room. The most common cause of inadequate dehumidification by an air conditioning system is the installation of a cooling unit which has too much capacity, or is "over-sized" for the space it is being used to cool. What happens is simple:
If an air conditioning compressor unit is oversized (too many BTUH of cooling capacity) what happens is it cools the room so quickly that the system does not move enough total volume of air across the cooling coil to remove much moisture before the room temperature has dropped to the A/C cut-off point.
In other words, an air conditioner needs to run longer, and move more total volume of air through itself to drop room humidity than it does to just cool the air. So "bigger" cooling capacity or higher BTU capacity for an air conditioning system is not necessarily better, and it can actually be a problem.
Sep 30, 2012 | Heating & Cooling
Airconditioner won't cool room off.
The unit,has it cooled the room before?Check the evaporator coil,the one inside the house,where the filter goes,put your hand on the coils gently,and place it all around and feel if the coil is cold,and is it cold all over,if it is not getting cold,all over the front of the coil,then it most likely needs freon.
Jun 04, 2010 | Samsung AW0501M Air Conditioner
Hi.. we'll feel cold after taking bath from? 1. cold water 2 water at 40 c 4 water at room tempreature 3 water at 50c
"we'll feel cold after taking bath from?"
(Let's assume room temperature of the bathroom is 25 c.)
1. cold water
Assuming cold water means below room temperature, for example, 22 c. One taking a bath in water at this temperature would probably feel cold DURING his bath at least at first. However, a cold bath would tend to bring blood to the capillaries under your skin and create a warming sensation. But after you get of the bath tub, you would definitely feel cold unless the room were heated!
3) water at 50c
Most folks would feel quite hot while in the water at this temperature. And after exiting the tub, since the layer of water on his skin would probably still be well above body temperature (37 c), a chill would not set in until the water on his skin cooled down to below body temperature. So if he quickly dried off, he would avoid feeling cold.
2 water at 40 c
While almost completely immersed in the bath water, one would certainly feel warm unless there were a draft in the room, because 40 c is 3 degrees above normal body temperature. For the same reason as stated above (#3), he could escape feeling cold outside the tub if he dried off quickly.
4) water at room temperature
- If I had to select only answer, I would choose this condition that would make one feel cold after stepping out of the bath tub, because:
Upon exiting the tub of water at room temperature, one would certainly feel cold if there were a draft in the room. Even if there were no draft, one would still feel cold, because the water on his skin would be cooler than his body heat (37 c), and cause a finite evaporation of the thin layer of water on his skin, which is a cooling process. The skin's heat would be lost, because its energy would be used to evaporate the water.
Mar 30, 2010 | Scientific Explorer My First Chemistry Kit
Our air conditoner is throwing out cold air but the room is very hot the fan is blowing out cold air too it is not cooling the room down.
sounds like it does not have enough BTUs
so many BTUs can cool somany cu-feet if sealed space
Like leaving the freezer door open too seal that room
Jul 31, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Heating & Cooling Logo
95 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
