Soniq I can't find screws to fit thread on TV
How can I use headphones wit a Soniq S55UV16B-AU Smart TV?
You have to use wired headphones and plug them in.
https://www.jbhifi.com.au/tv-home-entertainment/hd-televisions/soniq/soniq-s55uv16b-55-uhd-smart-led-lcd-tv/316772/
Component Inputs - 1
RCA Inputs - 1
RF Input - True
Headphone Output (3.5mm) - True
Energy Star Rating - 3.5
Product Height with Stand (mm) - 782.7
Product Width with Stand (mm) - 1240.6
Soniq S55UV16B
Sep 23, 2017 | Televison & Video
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
I have lost the screws to my 50" soniq tv base. What size screws do I need
Buy an inexpensive screw hole size template (used for inserting screws of unknown size into it, and reading what size hole it fits into, and then going to buy that screw) at Home Depot (HD) or Loews. If there is room to lay the template over one of the holes, you can eyeball which hole on the template is about the same diameter of the screw hole on the base. Then go to the store and look for that size screw (machine screw Vs wood screw), and purchase one of each of three sizes (the one that appears to be the one, and one that is the next size down, and one that is one size larger. Then see which one fits in the base (this will be a bit of trial an error). This should work until the right size is identified.
Sep 19, 2014 | Televison & Video
What type of screws are used to secure the TV to the base
Although the base is plastic the holes where screws go are normally always metal fixed thread like grub screws, most tv use similar fixtures to fit tv to base , I would pop along to a electrical store and try and look at the screws used to fix the tv that are on display and compate a few, then try buying a set of 1/4 inch pan head metal thread screws from DIY store
Dec 07, 2012 | Hitachi P50H401 50 in. Plasma HDTV
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
I have a Soniq LCD 42" Television (I believe its a QSL400XT model) and I have removed the black base of the stand but I can't remove the white cylinder part. How can I remove this part?
For Soniq 42" LCD TV - there's a series of screws on the rear panel underneath the plug sockets, remove the screws and the base will pull right out.
Sep 04, 2010 | Televison & Video
I cant remove the base from the L42S10A soniq tv. i need to wall mount it but i cant seem to remove the circular base. how do i remove it
Hi. On the back panel just above the inputs and in the centre of the unit you will see 5 X phillips head screws (4 in a square pattern and 1 in the center of these). If you remove these screws completely the base will withdraw from the unit. Note that the washers will be a tight fit when removing and only just fit through the rear panel so use a magnetic driver or blue tack to help. Cheers. Slavious.
Aug 24, 2010 | Televison & Video
No screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Remote code for Soniq TV
Only code I could find is: Soniq 1497 1328
Nov 28, 2008 | Directed 434MHZ Remote Control
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
