Question about GE APN08AA Portable Room Air Conditioner
E4 error on my ge air conditioner THE FIX IS EASY
I had the E4 error and my portable air conditioner wouldn't cool. the drain line wasn't pushed in enough and wasn't draining outside and it was filling up the container inside, I just emptied the container and it works fine, I also pushed in the drain hose in more
My arctic king air conditioner and humidifier shows e4 ,what to do
Posted on Jul 02, 2018
    New Friend:
HOW LONG IS DEFROST
Posted on Jul 18, 2013
4 Suggested Answers
  • 57 Answers
SOURCE: I get a E4 errror code.
The broken water tank flipper will directly cause the unit to not function and the E-4 message will appear on the display screen.
Posted on Jul 16, 2010
SOURCE: E4 ERROR MESSAGE ON SCREEN OF GE PORTABLE AC MODEL APE08AJM1
WATER BUCKET IS THE FAULT
the switch is more likely the cause try removing bucket and pressing lever manualy by hand then start it up again if it works you know the prob as this was mine the plastic connection aint the best
Posted on Mar 02, 2009
SOURCE: E4 error message on Dimplex portable air
Ensure water emptied
Posted on Nov 02, 2009
I have a portable air conditioner that has started beeping and shutting off. Then I drain it and turn it back on. It lasts maybe an hour and then I have to do the same thing again.
Helen, your air conditioner should drain by itself. Your a/c should
tilt slightly to the outside of the house but not tilt to the inside. Check your drain and your drain tube and make sure they are open.
Jul 18, 2017 | Heating & Cooling
Eurodib Portable AC E4 Error code
Make sure the condenser and evaporator fins are clean, and that there are the condensate drain hole or hose is not clogged. Also, check the blower or fan bearings to make sure they turn freely without grinding or noticeable sideways slop.
Jul 03, 2017 | Heating & Cooling
Unit is 12000 btu and leaking water
it has a hook up on the back,there is supposed to be a plug covering it and also supposed to be able to hook a hose onto it to drain the water,you have to drain them every day or 2
May 27, 2015 | Haier HPRD12XC5 Portable Room Air...
My SoleusAir portable air conditioner has an "e4" code.
Here are the SoleusAir error codes...
e2 Room temperature outside of working range of unit (too cold).
e3 Faulty coils - Repairs needed.
e4 Internal frost in the unit - Defrost.
e5 General failure - repair needed.
e7 Reservoir full - Empty the reservoir.
If the unit is freezing up (frosting) you may want to check (clean / replace) the filters.
Sep 13, 2014 | Heating & Cooling
I have a portable roam air condition i dont know where to add the water
You don't account unit takes out humanity in th he air to cool house or rooms you need to drain the water to outside
Apr 12, 2014 | Amcor PLM-14000E Portable Air Conditioner
Unit stopped, displayed E4
the unit is not draining properly. unplug it from the current outlet, check behind there should be two places to drain the machine. unplug the two drain plugs in the back and let the water empty out. the e4 error message comes up when the unit is filling up with water.
Sep 04, 2011 | Royal Sovereign Portable Air Conditioner
I have a highlander portable air conditioner..it does'nt run probaly on cool nor doe's it drain water..it keeps switching off showing message on screen E4 fault..please advise..did not recieve manual in...
E-4 Abnormality of out door unit or overload in compressor. Check condenser coil, if dusty clean it. F.motor struck, replace it.
Running amps gradually increasing means weak capacitor. Replace capacitor.
Thanks.Hope helpful?
Jan 22, 2011 | Heating & Cooling
Whirpool h8 error
I'm not a technician, but I'll share how I solved my problem. My portable whirlpool a/c wasn't working and had the H8 error code. I drained the water that was accumulated inside it and it started working again.
Dec 29, 2010 | Whirlpool ACP102PS Portable Air...
Water droping
Your drain pan is not draining. Use a wet vac to **** the drain line from the outside. This will pull out the blockage and you're back in business. Do not blow compressed air into the drain. This pushes the blockage back up into the drain pan.
Oct 02, 2009 | Friedrich M18YE Air Conditioner
No cooling
May have burnt wire or bad capacitor to compressor.When running incool can you here the compressor running or is it maybe just the fan outside running?
Jan 08, 2008 | Fujitronic FH-797 Portable Air Conditioner
GE APN08AA Portable Room Air Conditioner Logo
6,434 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
