Question about Bruder MAN TGA Container Service Truck
What could be the problem, when i drive my man26.480 truck over 60km/h the truck shakes and vibrates
What could be the problem? when i drive my 26.480 truck over 60km/h it starts to shake and vibrate.
    Problem Solver:
  • 6 Answers
More than likely it will be the balancing. ask your local garage to balance the front wheels :-)
Posted on May 18, 2014
  • 23 Answers
When you drive the truck at lower speeds, the weight of the truck neutralizes the vibrations. As you speed above 60km /hour, the tires start to vibrate, the circular motion of the tires create a force away from the center of tires, imagine a roulette, that like dice wants to stay away from the center, until the wheel slows down.To compensate for this force, tires are checked for balance. So balancing your tires, hopefully wlil solve your issue.
Vehicle shakes
check the bushes may be worn
Dec 16, 2013 | 2003 Mitsubishi Outlander
96 dodge caravan has drivetrain vibration at approx. 60km per hour let off gas it stops or give it more gas pettle it stops
Have the u-joints checked for serviceability. Check rear engine mount is in good condition check that the rear springs are still at the right height. You appear to have a harmonic vibration that is cause by worn u-joints or incorrect drive line operating angles from the angle between the rear of the gear box and the diff pinion having changed . Check the drive shaft for balance as sometimes the balance weight can throw off.
Sep 29, 2013 | 1994 Dodge Caravan
While driving something made a popping noise and truck started shaking
sounds like a bad u joint or swing bearing or just something loose in thr drive train
Nov 22, 2011 | 1992 Dodge Dakota
Hello my steering wheel shakes braking from 60km/h
If I understand your question, it appears to be shaking only while braking and no other time. If this is correct, then you have warped brake rotors and/or rotors that are improperly torqued (which may result in warping). If the rotors are not either worn or warped excessively, they MIGHT be brought back into spec by turning them on a brake lathe, otherwise you will have to replace them.
Jun 24, 2010 | Cars & Trucks
Front end vibration at between 70-80kms
A common solution is the tires. I know that sounds too easy but I had the exact same problem. My Dad told me tires. That was hard to swallow since all 4 tires were less than a year old. It was the style of tire on the car. He is a mechanic and I did what he said and it went away. O it could be a bent rim or a bad front wheel bearing. I've seen both
Jun 07, 2009 | 2006 Dodge Ram 1500
4Runner vibrates very roughly at 60km
it could be a number of things if nothing looks bent then it could be a wheel bearing,or a flat spot on one tire or could need a front end enlinement
Mar 30, 2009 | 1990 Toyota 4Runner
Car vibrating on highway
Hi! Your wheels need balancing or your steering ends are bad.
Dec 20, 2008 | 1992 Ford Club
Bruder MAN TGA  Container Service Truck Logo
80 people viewed this question
Top Bruder Toys Experts
MarK
Level 1 Expert
ptpumpman
Marc Taylor
Are you a Bruder Toy Expert? Answer questions, earn points and help others
