Question about Dell Inspiron 1464 Notebook
Why my laptop(dell inspiron 1464) stuck while working? with continuous sound & displays one color for whole display. can't do anything except pressing power off button. Pls help me regarding this.
Why my laptop(dell inspiron 1464) stuck while working? with continuous sound & displays one color for whole display. can't do anything except pressing power off button. Pls help me regarding this..
  • 1 more comment
  • Buddhika Prasad
    Buddhika Prasad May 19, 2014
    when play a game on facebook or long time browsing internet using 3G modem mostly raise this issue. i think cooling fan RPM issue. how to verify it?
  • Mansour May 19, 2014
    The modem is 3G, the modem just provides you with internet. gaming is another issue. When you are using the computer to play games,, the games require interfaces that use your main memory, and also memory on demand. RAM. That is the reason that you see in high demanding games, the processors, they get hot due to electrons movements. and also RAM the same way. So cooling has an important part. To test, just close the bents on your computer, and you will see that your computer gets so hot, at first , it gets stuck, then the processors shut down the computer in order to avoid damage . using cooling fans under your lap top, or inside your desktop has a great role.
    correction: Just close the vents.
    New Friend:
  • 23 Answers
First check that your memory ( RAM) are firmly seated.Press on the memory sticks to make sure they have good contact.
Also The issue could be related with the operating system, as for instance in some cases the OS causes computer turns on, and turns off again. what I can suggest is that you re install the operating system again, or reboot computer to the factory defaults from the rescue CDs that you made. If the problem still exists , then there must be some hardware issue. In which I recommend you contact Dell support.
Posted on May 18, 2014
  • 998 Answers
SOURCE: Laptop won't boot (display problems)
If the diagnostics displays on the LCD screen but you get no display when Windows starts to load, it sounds like you have a video software driver problem. Try tapping the F8 key when you power on your laptop and boot in Safe mode. If it works in safe mode then you need to check you driver. You can also try connecting the laptop to an eternal monitor and see what happens.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
SOURCE: Dell Inspiro 6400 not starting up
If the Num lock is lit constant, and the Caps Lock and Scroll Lock keys are flashing, the system is reporting a memory error. Power off the system, remove the battery, and follow the user manual from support.dell.com to reseat the memory module(s). If the error persists, you may need to replace the memory and/or the system board of the portable.
Posted on Mar 18, 2009
  • 157 Answers
SOURCE: RE:Dell inspiron 6400 problem in switching on
in that case, Try boting in safe mode by tapping F8 key as soon as u see Dell and it will give u advance boot option, when u get that , select Safe mode, and if you are able to boot to desktop , Go to device manager by Start>right click on MY COMPUTER>manage > on right Device manager.
Check under Display Adapter and uninstall whatever is under it, by making a right click on it and uninstall ,
But in case you are not able to see Desktop in safe mode aswell,  Only option is to do OSRI.
As your screen is fine as you can see Dell.
Hope this will work
Cheers!!!!
Posted on Jun 02, 2009
SOURCE: Dell Inspiron 1300 - When I re-open the lid,Screen stays Black !
Your laptop either goes to hibernate or sleep mode when you close the lid. Then, when you open the lid up, the screen is still off because your pc already hanged/froze and could not wake up at all (usual problem in vista). Off course, hard shutdown would fix it. But actual fix is under power options on your control panel. Check your current scheme and edit it. There are options there that you can select to "do nothing when closing the lid"
Hope this helps
Posted on Oct 01, 2009
  • 113 Answers
SOURCE: dell inspiron 1464 webcam driver for windows 7
use 32 bit vista for it
Posted on Mar 05, 2010
Wifi direct on my dell laptop
Is your dell laptop wifi direct capable?
Aug 29, 2013 | Dell Inspiron 1464 Notebook
My dell 1464 no display when on off agine
No Display? If the laptop seems to boot up except the screen is black try this:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 02, 2012 | Dell Inspiron 1464 Notebook
I have a dell inspiron 1464 laptop i3 processor n windows 7. when i turn it on it makes beep beep sound with nothing on screen totally black screen. what is the problem
there are a few possible issues with the unit. it is definitely a hardware failure. 2 tips the beep indicate 2 different issues:
1. long beeps may indicate an issue with the motherboard.
2. short beeps that is continous as if saying sos is for the memory card
either way you would need to have your laptop serviced since it is already a black screen.
Jul 15, 2011 | Dell Inspiron 1464 Notebook
Dell 6000 Inspiron Screen will not display anything...has a green hue....tried hooking external lcd and it would not display
power system on holding the letter D while pressing power button, (see if you have 4 solid colored screens displayed) if you do, then the LCD is ok, and this issue is likely a problem with the motherboard
Jan 15, 2011 | Dell Inspiron 6000 Notebook
Dell Inspiron 1464 XP Drivers
download the latest drivers from dell.com
Jul 07, 2010 | Dell Inspiron 1464 Notebook
Dell Inspiron D530 - Screen Malfunction - Rainbow colors?
Reseat the display cable (under the keyboard) and while you have the lcd hinge cover off, inspect the cable where is goes thru the hinge assembly for chafing and possible broken wires.
If reseating doesn't help, RUN DIAGS
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=E3FE44D4AAF58D13E0301E0A5517246B&doclang=en#1
If they fail then replacing the LCD display cable and or the LCD would be next.
Dec 09, 2009 | Dell Latitude D530 Notebook
Screen wont turn on , i have a inspiron 6400 .. I rang dell & my extra 3yr warranty ran out just 6 weeks ago & * They WONT HELP*
when you say screen will not turn on it means we do not have display right? now, try this. turn off laptop, press and hold D key then press power button, check if the LCD will display colors if yes then it might be your video card causes the problem which needs motherboard replacement. if no colors appear then LCD needs replacement.
Oct 15, 2009 | Dell Inspiron 6400 Notebook
Display area is "shrunken" on Dell Inspiron 4000 display
Go to Control Panel - Display - Settings - Advance - Monitor, set it to Default monitor and click OK.
Does the display now fill the screen?
If this doesn't work, go to the DELL WEB site and see if there a driver for the display. To ensure you get the correct driver for your model laptop, use the Service Tag number (which is printed on the label on the bottom of the laptop) to the download page for your model laptop, download the correct Windows XP or Vista version of the driver from :-
www.dell.com
Apr 08, 2009 | Dell Inspiron 4000 Notebook
I have Dell laptop inspiron 630m. I formated the laptop then the display driver is missing. Its showing all the things except its display got more wider
just check your video card model, then go online to download the video card driver.
in case you have a build-in-video card like intel .....somethings, just go back dell.com and check your model , and download the video card driver.
Jan 14, 2009 | Dell Inspiron 630M Notebook
Dell Inspiron 1464 Notebook Logo
52 people viewed this question
Alun Cox
