Question about Electrolux EIMED55IIW 8-0 cu- ft- Electric Steam Dryer - IQ-Touch Cont
Why is the countdown timer not working?
It will not show the amount of time remaining in the dry cycle only the initial time.
  • Official Brand Answer
  • 2,267 Answers
Good Morning Ray, this is Z. Thank you for your question!
From what you have described it sounds like your Electrolux dryer may either have a communication error from the main control board or the timer itself may not be operating correctly. You can attempt resetting your dryer by unplugging it or flipping off the breaker for about ten minutes. If the problem still persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Posted on May 21, 2014
My Electrolux EDV 605clothes dryer is turning but not heating, heating element is ok possible faulty thermistor, dryer heats up when thermistor is unplugged but has an error code of 5 beeps
I think you're absolutely right exhaust sensor is faulty.
The buzzer will give 5 beeps, all program LEDs will flash for 5 seconds and the dryer will continue with the cycle. The warning beeps and flashing LEDs will occur every 30 seconds.
On Timer Drying programs it will run for the time remaining and in Sensor Drying programs it will run for 90 minutes. As the exhaust air temperature can not be sensed the element will be cycled on and off at a preset amount. The cycling time of the element will vary depending on the amount of time remaining.
NOTE: When this fault exists the dryer can still be used but regardless of the Sensor Drying program selected the dryer will use the 90 minute Timer Drying program, Timer Drying programs will use the selected program, and with both types of programs the element will cycle as above. The buzzer will also still be sounding.
If an exhaust sensor fault is detected the buzzer will beep and the Reminder Clean the Filter LED will flash. The LED flashes at different rates depending what is wrong with the sensor -
Fast (4 per second) = open circuit senor, broken wiring or multi pin plug not correctly fitted to the control board.
Slow (2 per second) = Short circuit in sensor or wiring.
The sensor resistance at different temperatures is as shown below.
Temperature (Celsius) Resistence (Ohms)
55 2960
50 3570
45 4330
40 5280
35 6490
30 8030
25 10000
20 12555
15 15880
10 20260
5 26080
0 33870
As you can see this is NTC thermistor with Negative Temperature Coefficient , means if temperature increasing the resistance decreasing.
Dado
Jul 06, 2015 | Electrolux Dryers
Countdown timer not working
Good Afternoon Friend,
I understand that the timer on your Electrolux dryer, model#EIMED55IIW, is not advancing to show you how much time is left on the dry cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Restore power and restart your dryer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
-Best Regards-
WP
May 18, 2014 | Electrolux EIMED55IIW 8-0 cu- ft- Electric...
What is the countdown timer in stopwatches?
The "countdown timer" in stopwatches allows you to set a specific amount of time and once you press the start button the timer counts down until it gets to zero. This is beneficial in numerous of cases where you want measure how much can be done in specific amount of time. For example, if you want to measure how many sit ups you can do in 2 minutes, you can measure it with this feature.
Aug 29, 2012 | Coleman Exercise & Fitness
Despite the fans working on a plain Jane single pole switches, I can't get these 6515M switches to work for my 1.3 ceiling fans. The fan hums and all I get on the timers are red LEDs. These timers...
1) Leviton 6515 is incandescent only:
http://www.amazon.com/Leviton-6515M-I-2-5-10-15-Electronic-Incandescent/dp/B0007NOZDI
2) Below is list of countdown timers with horsepower rating so they work for fans:
GE15088 countdown timer is rated 3/4 hp
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay
Intermatic spring wound countdown timers are rated for 2 horsepower
http://www.intermatic.com/products/timers/in-wall%20timers/decorator%20spring%20wound%20timers.aspx
Woods spring-wound countdown timer says bath/ ceiling fans, but doesn't give horsepower
http://waterheatertimer.org/pdf/Wood-59700-series--spring-wound.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#countdown
Woods push-button countdown is 1/4 horsepower
http://www.amazon.com/Woods-59014-Decora-12-8-4-2-12-Hour/dp/B002C54GH4
Wattstopper RT50 at Grainger shows 1/6 horsepower rating
http://www.grainger.com/Grainger/WATT-STOPPER-Time-Switch-2HTE1?Pid=search
3) Following timers are NOT rated for fans:
Lutron MA-T51 countdown timer specifically says it cannot be used for motors.
http://www.amazon.com/Lutron-MA-T51-WH-Maestro-Countdown-Timer/dp/B001EFV1DA
http://www.lutron.com/TechnicalDocumentLibrary/0301041A.pdf
Pass and Seymour RT1 countdown does not show rating for horsepower, so this timer will probably not work for fan motor
http://www.homedepot.com/Electrical/h_d1/N-5yc1vZ1xg8Zarcd/
Feb 26, 2011 | Leviton 6515M-W Timer Switch, 2-5-10-15...
I have the H5CR-B 100 to 240 V AC digital timer. How do I change the timer from minutes to seconds?
You have a DIN panel mount SPDT (single pole double throw) timer.
This is input ON delay timer that receives input that causes timer to start a delay countdown, or signal off delay timer that receives input that causes timer to turn on for specified countdown, or a cycle timer that repeats same program pattern over and over in a set amount of time like every 5 hours and 12seconds, or an ordinary interval timer.
Apparent manuals:
http://www.servodrive.ru/dynamic/managers/manage_15/files/L035E14B_H5CR_datasheet.pdf
http://www.omron247.com/doc/pdfcatal.nsf/04769EAAF1D7005686256B8100629A62/$FILE/D19H5CR0302.pdf
Manual says: Field-selectable time ranges from 0.001 second to 9999 hours.
My impression is that this means timer can be set for durations ranging from .001 seconds to 9999 using the 1-4 keys
Manual says: Change the timing range with the increment keys (1 to 4).
Use keys 1-4 to change data when setting timer when in the set mode.
It looks like you set seconds or milliseconds with #1 key
Manual shows contact information
Measuring and Supervisory Controls Department
Shiokoji Horikawa, Shimogyo-ku
Kyoto, 600-8530 Japan
Tel: (81)75-344-7108/Fax: (81)75-344-7189
OMRON CANADA, INC.
One East Commerce Drive
Schaumburg, IL
1-800-55-OMRON
http://www.omron.com/oei
885 Milner Avenue
60173 Scarborough, Ontario M1B 5V8
416-286-6465
Feb 02, 2011 | Omron Hardware & Accessories
I am installing the timer for a whole house fan. I hooked red up to load, black to hot and white to neutral per instructions...confirmed with meter....the timer does not seem to work..I can turn on and...
A) GE 15069 image at Amazon
http://www.amazon.com/60-minute-Automatic-Shut-Off-Timer-Switch/dp/B002DNAE7Q
15069 manual
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/In-Wall-15069-Manual-eng.pdf
Manual shows GE 15069 countdown timer is rated up to 1/2 horsepower
Whole house fan is likely 3/4 horsepower >> check nameplate on fan motor.
B) work around:
Hook timer up to a contactor/relay.
Timer turns on 120 volt, 7 watt contactor coil.
Contactor turns on fan motor
http://waterheatertimer.org/H230A.html
Square D contactor at Grainger
http://www.grainger.com/Grainger/SQUARE-D-Compact-Contactor-5B132?Pid=search
http://www.pexsupply.com/Furnas-Controls-45EG20AF-2-Pole-30-Amp-120V-Contactor
I buy these contactors at local HVAC supply for $15
add a comment if you need help wiring this device.
C) List below shows countdown timers with horsepower rating:
Lutron MA-T51 countdown timer specifically says it cannot be used for motors, which says the electronics inside each device is Load specific
Dec 12, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Program a timer
You posted under Paragon 2606 Panel-mount countdown timer.
If this is not your timer, add a comment.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
2600 series is mechanical interval timer.
26006-00 can handle 10 amp loads.
Interval timer is a countdown timer that keeps Load turned on for set amount of time.
You set the time by rotating dial
To start timer, Rotate dial from 1 minute to 30 minute.
Rotating dial turns on Load and begins countdown.
Timer turns OFF Load after set amount of time expires.
Nov 26, 2010 | Electric Paragon 2606-00 Timer
16820 dryer not working
I suggest checking the moister sensor and or cycling thermostat. the hi limit thermostat as well, with a meter for continuity. other wise you may have a bad timer
Mar 20, 2017 | AEG Lavamat 16810 Front Load Washer/Dryer
Display panel (cont.)
hi there try pressing and holding the start button for about eight seconds
Oct 10, 2007 | Hotpoint Aquarius WD640 Front Load...
Electrolux EIMED55IIW 8-0 cu- ft- Electric Steam Dryer - IQ-Touch Cont Logo
Top Electrolux Dryers Experts
John Tripp
John Tripp
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
