Question about Baby Gear
Safety first baby monitor s 8024# the big receiver I charge it and then when done I plug other one up as soon as I do big one dies
3 Suggested Answers
  • 419 Answers
SOURCE: Safety 1st Video baby monitor - replacement wires?
I would suggest that you contact the manufacturers (Dorel UK), the link is below:
http://www.dorel.co.uk/safety-1st/
Posted on Sep 14, 2009
drifterK
  • 4924 Answers
SOURCE: my baby monitor won't charge - it's not even recognizing the charger as plugged in -- the red light doesn't go on any more??
shut it down and restart and see if it takes the charger ..usually there is nothing that makes the camera behave that way but the charger ..either being damaged or the plug does not makes contact well ..check the wire not to be damaged and try another charger with the same specs ..exactly the same ..It is possible to be damaged if you let it in the plug for a long time ..
If it shows out that the charger is not to blame ..than it is a mater of plug need to be changed cause is damaged ..In worse case just open it and hot wire if you can not get a plug to match ..
Posted on Dec 28, 2011
Monitor is not charging from ac adapter
Ours started doing this, what we ended up having to do was using the camera cord to charge the handheld monitor. I hope that works for you!
Jan 31, 2014 | Summer Infant Babies R Us Baby Sight Color...
My baby monitor won't charge - it's not even recognizing the charger as plugged in -- the red light doesn't go on any more??
Dec 28, 2011 | Samsung Wireless Baby Monitor Camera...
Static only
If you have static, more than likely you dont have the monitor on or plugged in. Also, make sure the the channels are set equally on the monitor and receiver, either on channel 1 or 2.
Try not to place the monitor or receiver near tv's, microwaves, radio's, etc. this may interrupt reception.
Hope this is helpful!
Feb 26, 2011 | Safety 1st Baby Monitor
Hi there, I have a Fisher Price Dual Private Connection Monitor about 6 months old - all parts are functioning (have power, are charged, etc) but today neither receiver is picking up sound from the monitor...
I had the same problem.
It turned out the batteries needed to be charged. I left the receivers plugged in for a couple of hours. I don't know if it matters but I had them turned off. They both work now.
I know you said the your monitors were charged so I don't know if this helps or not.
Jan 11, 2011 | Fisher Price Dual Private Connection...
My handheld camera model does not seem to charge. I leave it on charge all day and it only has one bar of power when not plugged in?
ok,just figured it out,the plug that goes into the socket vertically is pretty much useless. As soon as you plug it into the handheld device to charge, it shuts off. I took the plug that goes into the socket horizontally and plugged it into the handheld and it began charging. So to use the product, you need to charge the handheld fully and then use the same plug to plug in the actual video camera that is pointed at baby,then you will be set to go. The company should send 2 horizontal plugs.
Dec 17, 2010 | Summer Infant Slim Secure Handheld Video...
MBP30L: the monitor screen keeps going off but as soon as
Hi Tammyfrancis,
For better assistance you can contact our Baby Monitors specialist.
http://www.motorolacordless.us/
Best Regards,
Katy
Motorola Support
Nov 30, 2010 | Motorola Mobility Mbp30L Digital Video...
Does the monitor that stays in the bedroom need to be plugged in to the power supply at all times cause as per instructions and unplugged it loses charge. this is on the safety 1st digital monitors
Does the monitor that stays in the bedroom have a battery? Many monitors do not have a battery in the base.
Check for a battery: If there is one, it probably needs to be charged for at least 12 hours. If there is no battery, it needs to be plugged in to function.
Oct 15, 2010 | Safety 1st Baby Monitor
Is this crib recalled wm-1633-0
Storkcraft had a recall on some of their cribs.IF it is a Storkcraft you have to call them and give them the model number.
These cribs were made between May 2000 and November 2008.They were sold until Jan.2009.
Even if your's isn't a Storkcraft you should be able to call the manufacturer of your crib and ask them.
Storkcraft,for one,did not post the model numbers that were recalled.
The manufacturing date can be found on the lower right hand corner of the instruction sheet which is glued on the mattress base.
The cribs were sold in various styles and finishes. The manufacture date, model number, crib name, country of origin, and the firm's name, address, and contact information are located on the assembly instruction sheet attached to the mattress support board. The firm's insignia "storkcraft baby" is inscribed on the drop side teething rail of some cribs.For more information, consumers may contact Stork Craft toll-free at 866-361-3321 anytime to order the free replacement kit or log on to the newwindow.gif firms Web site.
These cribs have had recalls as well:
Jenny Lind crib model 6982 with lot numbers 8021, 8024, 8025, 8052, 8053, 8055, 8056, and 8070 and model 6983 with lot numbers 8022, 8023, 8026, 8027, 8031, 8032.
Aspen 3 in 1, Aspen 4 in 1, Nursery-in-a-Box, Crib N Changer Combo, Chelsea and Pooh 4 in 1. The recall also involves the following Simplicity cribs that used the Graco logo: Aspen 3 in 1, Ultra 3 in 1, Ultra 4 in1, Ultra 5 in 1, Whitney and the Trio.
The recalled cribs have one of the following model numbers, which can be found on the envelope attached to the mattress support and on the label attached to the headboard: 4600, 4605, 4705, 5000, 8000, 8324, 8800, 8740, 8910, 8994, 8050, 8750, 8760, and 8996.
13 babies in the US alone died as a result of the Simplicity cribs...in Canada most of them were sold in Zellers...but don't try to take it back there.
pinehurst.jpgLaJobi and CPSC announced two recalls for 4,900 cribs.
First, 2,000 Bonavita "Cabana" cribs were recalled for slat failure -- the slats can come loose and/or break. LaJobi had ten reports of slats coming out of the rails and six reports of slats breaking.
Also, 2,900 Babi Italia "Pinehurst" cribs and Bonavita "Hudson" cribs were recalled for drop side failures.
Step 1 Register your baby crib as soon as you bring it home so you will receive product recalls automatically. Usually manufacturers ask you to register to validate warranty information but this will also register you to receive product recalls.
  • Step 2 Check the U.S. Consumer Product Safety Commission website regularly for recall information. This is a dependable resource that many consumers are not aware of.
  • Step 3 Visit your crib manufacturer's website occasionally and type in your crib name or number under their search option.
  • Step 4 Monitor the recall website www.recalls.gov that constantly updates recall information on all consumer products including baby cribs.
  • Step 5 Stay up to date with current news reports and printed media outlets. They are often the first to announce safety recalls and possible product issues.
  • Sep 22, 2009 | Dorel Alexander
    Baby Gear Logo
    49 people viewed this question
    Top Baby Gear Experts
    Dorel UK
    Dorel UK
    Are you a Baby Gear Expert? Answer questions, earn points and help others
