Question about Electrolux Washing Machines
Remove drum bolt ewf10831 - Electrolux Washing Machines
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I understand you are trying to remove the drum bolt off your Electrolux washer, model# EWF10831. This appears to be an Australian Electrolux dishwasher. Typically this is not a do it yourself repair. I suggest contacting the manufacturer for further assistance. Hope this is helpful.
-Best Regards-
WP
Posted on May 21, 2014
Parts manual ewf10831
I see that you are looking for a parts manual for your Electrolux washer, model# EWF10831. This appears to be an Australian Electrolux dishwasher. I suggest contacting the manufacturer directly for a copy of the parts manual. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Electrolux Washing Machines
Wheel stud
splines? you meant treads?
remove wheel, then drum. no year stated , but some years
have drum bolts, ,
see 2 screw holes in the dump, insert 8mm bolt to hole
screw in both bolts an drum pushes free.
the drum is off, , remove stud , put in new stud.
or if the new stud dont fit, the drum is bad. new drum time.
Sep 28, 2013 | Suzuki Sidekick Cars & Trucks
Remove rear brake drums
Light Duty Models
  1. Raise the vehicle so that the wheel to be worked on is clear of the floor and install jackstands under the vehicle.
  2. Remove the wheel. Remove the three retaining nuts and remove the brake drum. It may be necessary to back off the brake shoe adjustment in order to remove the brake drum. This is because the drum might be grooved or worn from being in service for an extended period of time.
  3. Before installing a new brake drum, be sure to remove any protective coating with brake cleaner or a suitable fast-drying degreaser.
  4. Install the brake drum in the reverse order of removal and adjust the brakes.
Heavy Duty
  1. Raise the vehicle and install jackstands.
  2. Remove the wheel. Loosen the rear brake shoe adjustment.
  3. Remove the rear axle retaining bolts and lockwashers, axle shaft, and gasket.
  4. Remove the wheel bearing locknut, lockwasher, and adjusting nut.
  5. Remove the hub and drum assembly from the axle.
  6. Remove the brake drum-to-hub retaining screws, bolts or bolts and nut. Remove the brake drum from the hub.
To install:
  1. Place the drum on the hub and attach it to the hub with the attaching nuts and bolts.
  2. Place the hub and drum assembly on the axle and start the adjusting nut.
  3. Adjust the wheel bearing nut and install the wheel bearing lockwasher and locknut.
  4. Install the axle shaft with a new gasket and install the axle retaining bolts and lockwashers.
  5. Install the wheel and adjust the brake shoes. Remove the jackstands and lower the vehicle.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 32; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 32; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]>
May 08, 2011 | 1991 Ford F250
How do I remove rear brake drums on 2002 toyota camry
first remove the wheel and this will expose the brake drum. next make sure emergency brake is off. spin drum by hand, if it spins freely you can use a heavy hammer and give it a hard whack and drum should pop loose, if not remove the drum by inserting two bolts into the threaded holes on the drum face and continue driving the two bolts forward evenly which in turn walks drum off. if this was helpful please rate 4 thumbs.
Jan 15, 2011 | 2002 Toyota Camry
How to remove rear brake drums
Hello and welcome. you can use a couple of bolts. here is the instructions
Remove the drum (1) from the axle hub. If the drum cannot be removed by hand, install 2 8 mm bolts (2) into the drum. Tightening the bolts will force the drum off the hub. e605c51.gif
Oct 09, 2010 | 2002 Chevrolet Tracker
How do you rmove rear brake drum 2004 frontier 4x4
Hope this helps.
Good luck,
Removal & Installation
  1. Remove the hub cap and loosen the lug nuts.
  2. Raise the rear of the vehicle and support it on jackstands.
  3. Remove the lug nuts, tire and wheel.
  4. Release the parking brake.
  5. Pull the brake drum from the hub. If difficult to remove try the following:
    1. Strike the face of the drum with a plastic or rubber mallet. This will break free any rust that may develop between the drum and the hub.
    2. Install 2, M8x1.25mm bolts into the holes in the drum and gradually tighten them to pull the drum off the hub.
  6. 0900c152801a5f72.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Install and tighten 2 bolts to remove a stubborn brake drum
To install:
  1. Install the brake drum to the hub.
  2. Install the wheel.
  3. Remove the jackstands and lower the vehicle.
  4. Road-test the vehicle to ensure that the brakes are working properly.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the brake fluid, as necessary.
  3. Release the parking brake.
  4. Raise the vehicle and support safely.
  5. Remove the tire and wheel assembly.
  6. Pull the brake drum from the hub. If difficult to remove try the following:
Oct 23, 2009 | 2004 Nissan Frontier
How do I remove the rear brake drum on the 90 rocky to remove and replace the lug bolts?
after removing the wheels, it should just slide off. If you have a ridge on your drums this might not be possible. You can try to install two bolts into the small bolt holes on the drum. Turn these bolts together as much as possible and it will force the drum off. Like I said though, if you have a ridge on your drums you will have to back off the star adjuster located inside the brake drums. To do this, there is a small inspection hole on the back side of the drum. There should be a small rubber cover shaped like a large horse pill. Oval in shape. Remove this and you will have access to the adjuster. Using a flat blade screwdriver, pry the gear shaped wheel until the shoes of the brakes are adjusted in far enough to bypass the ridge on the drums. This combined with the two bolts should release the drum from the axle. Good luck.
Jun 13, 2009 | 1990 Daihatsu Rocky
Need to remove rear brakes on a 2005 ford focus
Some people will tell you to remove the four bolt behind the drum but i think it is much easier to remove the middle bolt with a 30mm ratchet. But be careful to torque correctly the nut in place. I think it's 140 lbs i'm really not sure. If you do it by the four bolt, be careful with the abs sensor, i break mine lol
Feb 21, 2009 | 2005 Ford Focus
1990 626 Mazda rear drum brakes
This "large nut" you are talking about is holding a drum. Usually over him is a cover. Use big screwdriver and hammer to remove cover, gently strike from all sides, and when you remove it you will approach to a big nut. Pay attention that under the drum is a whole breaks sistem. After you remove the nut gently strike from the rear, from all sides (left, right, up and down). Drum will fall off.
Sep 28, 2008 | 1990 Mazda 626
Replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Aug 29, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
61 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
