Question about IBM ThinkCentre M51 PC Desktop
IBM ThinkCentre S50 8183 Desktop i have to change its processor what can i do
  •  Jon Caldwell
    Jon Caldwell Jun 02, 2014
    Hi Jindri , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Why do you have to change the processor? Is it defective or are you looking to upgrade it?
pagebor
  • 2785 Answers
SOURCE: Computer switches on but does not boot (processor fan can be hear
plz try by resitting the ram
Posted on Nov 19, 2008
vipin_yadav1
  • 80 Answers
SOURCE: IBM THINKCENTRE A51 - WON'T BOOT
Simple dear, I think that you can see the power led and hdd led but it wont boot. Right. So switch the system and than open the cabinet and than remove the RAM , CLEAR THE DUST ON THE SLOT AND RAM. THAN REPLUG IT IN THE SAME WAY. PLEASE DO NOT INSERT IT FORCEFULLY BECAUSE IT WILL GO EASILY IF YOU ARE INSERTING IT IN RIGHT WAY. SO CHECK THE POSITON OF THE NOTCH ON BOTH THE RAM AND SLOT OK
AND THAN START THE SYSTEM. THIS MIGHT DEFINATELY SOLVE YOUR PROBLEM.
APremkumar
  • 564 Answers
SOURCE: i want network driver for IBM Thinkcentre please
http://www-307.ibm.com/pc/support/site.wss/TCTR-MATRIX.html
Here is what you need. Just click the Link Above and select your model. Please Rate My Response! Thanks!
PREM
Posted on Feb 21, 2009
  • 142 Answers
SOURCE: IBM ThinkCentre A51 PC Desktop won't boot
This could still possibly be a bad power supply, even if the fans and drives spin up. If you have a spare try hooking it up.
the list of things that can cause this are:
bad power supply
bad ram
IDE error (optical or hard drive problem)
bad card (modem, video card etc.)
bad processor
bad board
The first thing i would look for in this case is blown capacitors. Those are the little things on the board that look like little soup cans, usually with silver tops. If the tops of any of them are bulging or have junk leaking out of them, you have a bad board. If you are handy with a soldering iron you can try to replace them. Not sure if radio shack still sells caps, but they are easy to find on line. I have about an %80 success rate fixing boards in this way.
If the PS change doesn't work, then try it with different sticks of RAM, if you have more than one, pulling one at a time until it starts or you've tried it with all the ram. If not ram, disconnect the ide cables from the board, these are the wide ones usually connected to the HD's and optical drives. If it still doesnt start then pull all the cards. If it doesnt start then, try swapping processor and if still no joy a new board.
Posted on Sep 05, 2009
SOURCE: Windows 7 i need audio
OK. download it from this link:
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
please Vote
Posted on Jan 12, 2011
After i change the processor dual core 1.80ghz on the IBM thinkcentre M 55e 9632 series the monitor only showing, cpu=1processors detected,cores per processors=2 intel pentium dual cpu 2160 1.80ghz 1527...
HI,
I am sharing some general info:-
If you are change processor no problem, some point see you like after change processor any beep sound, processor more hitting.
Second check it *********** board power come or not, your display cheap more hitting or not. Check RAM proper connect, your all cable proper connection. If all things ok then may be your PC not supported processor.
Thanks..
Oct 14, 2013 | Lenovo ThinkCentre M55e 9632 PC Desktop
After i change the processor on the IBM thinkcentre M series the monitor only showing processor product name number config F1 and pause it
possibly you need to flash the bios. there should be options in the post setup menu. be very careful flashing the bios. IT MUST BE DONE RIGHT THE FIRST TIME. if you never have, get someone with experience!!!!!!
Oct 12, 2013 | IBM Lenovo ThinkCentre M55e PC Desktop
I need ibm m51 8141 drivers .
FAQ
IBM M51 8141,8142,8143
Max. Processor = INTEL P4 670 ( 3.8GHZ) 2M HT = 64 BIT SOC.775
Max. Compat. Graphics = ATI X700 pro/256- 512MB / PCIex16
need no extra Powercable, works with original 310W Powersupply
Jan 21, 2011 | IBM ThinkCentre M51 PC Desktop
What`s the maximum processor upgrade for IBM ThinkCentre M51?
MAXIMUM CPU FOR IBM M51 = Pentium 4 650
3,40 GHZ / 2M CACHE / FSB 800 / HT / SOCKET 775 ( SL7Z7 or SL8Q5 ) they take 84 Watt, by the way, change the power supply,with connections for Pcie x16 graph-cards ,like 800 Watt. HD cards are not supportet, Max.- card is ATI x1950 Pcie x16 512MB. Do not try the ATI 5450 will not work.
Processors:
DO NOT THINK ABAUT THE P4, 651 / 660 / or 661 ,will not work .( multiplier is 17 ) and not supportet by the mainboard and chipset.
Nov 20, 2010 | IBM ThinkCentre M51 PC Desktop
I have an IBM thinkcentre m51 that I am trying to upgrade to a dual core processor. It seems that it won't take it. Is there a setting on the bios that will allow the motherboard to support a dual core...
Most major manufactures use motherboard designed to their specs and upgrades to the processor are limited. You can use software such as Belarc Advisor, to determine what motherboard you have and then you can search the net to determine what processors are compatible with it.
Nov 08, 2009 | IBM ThinkCentre M51 PC Desktop
After i change the processor on the IBM thinkcentre M series the monitor green light just flicer all the time while the pc is on the cd rom green light just flicker on/off all the time the fans are running...
there are two reason for this problem. and the most probably is the first reason below.
1. your motherboard is not supporting the installed processor. although it powered up all the components and parts but the processor dont work at all.
2. even if your motherboard supports the processor and it works fine then there is problem with the VGA.
Finally to check the motherboard and processor whether they are working or not.
please remove RAMs from motherboard and start your computer and now if it gives the beeps sounds then motherboard and processor are working. and if you dint listen any beep sound then the installed processor is not being supported by motherboard.
Please dont forget to RATE my answer.
Sep 09, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
IBM ThinkCentre M51 PC Desktop Logo
23 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
