Question about Lenovo ThinkCentre A57 Desktop - Intel Pentium Dual-Core E2180 2GHz - 1GB DDR2 SDRAM - 160GB - Combo...
I have IBM desktop 3.06 can i change my processor
    Brigadier General:
  • Lenovo Master
  • 3,400 Answers
After i change the processor dual core 1.80ghz on the IBM thinkcentre M 55e 9632 series the monitor only showing, cpu=1processors detected,cores per processors=2 intel pentium dual cpu 2160 1.80ghz 1527...
HI,
I am sharing some general info:-
If you are change processor no problem, some point see you like after change processor any beep sound, processor more hitting.
Second check it *********** board power come or not, your display cheap more hitting or not. Check RAM proper connect, your all cable proper connection. If all things ok then may be your PC not supported processor.
Thanks..
Oct 14, 2013 | Lenovo ThinkCentre M55e 9632 PC Desktop
After i change the processor on the IBM thinkcentre M series the monitor only showing processor product name number config F1 and pause it
possibly you need to flash the bios. there should be options in the post setup menu. be very careful flashing the bios. IT MUST BE DONE RIGHT THE FIRST TIME. if you never have, get someone with experience!!!!!!
Oct 12, 2013 | IBM Lenovo ThinkCentre M55e PC Desktop
What`s the maximum processor upgrade for IBM ThinkCentre M51?
MAXIMUM CPU FOR IBM M51 = Pentium 4 650
3,40 GHZ / 2M CACHE / FSB 800 / HT / SOCKET 775 ( SL7Z7 or SL8Q5 ) they take 84 Watt, by the way, change the power supply,with connections for Pcie x16 graph-cards ,like 800 Watt. HD cards are not supportet, Max.- card is ATI x1950 Pcie x16 512MB. Do not try the ATI 5450 will not work.
Processors:
DO NOT THINK ABAUT THE P4, 651 / 660 / or 661 ,will not work .( multiplier is 17 ) and not supportet by the mainboard and chipset.
Nov 20, 2010 | IBM ThinkCentre M51 PC Desktop
Does the MB support an Intel Prescott 3,06 ghz fsb 800mhz processor?
that is a socket 478 board. it supports northwood and early prescotts. prescotts at 3.06 with the 800mhz fsb were made in both socket 478 and lga 775 forms, so you have to make sure that your processor is indeed a socket 478 model.
Nov 06, 2010 | Abit IC7-G I875P;SOCKET 478;800MHz...
IBM Aptiva E 245 , can you tell me what the processor speed is?
Yes I can tell you its speed
Processor is AMD K-2
Its processor's speed is 401 500.
Please feel free to contact me again.
Thanks.
Have a great day.
Sep 08, 2010 | IBM Aptiva E 245 (2170245) PC Desktop
I can't boot with the 1.5GHz processor. A 3.0Ghz
hello its need minimum 1.6 ghz processor. there no option .
Dec 03, 2009 | IBM NetVista X41 PC Desktop
After i change the processor on the IBM thinkcentre M series the monitor green light just flicer all the time while the pc is on the cd rom green light just flicker on/off all the time the fans are running...
there are two reason for this problem. and the most probably is the first reason below.
1. your motherboard is not supporting the installed processor. although it powered up all the components and parts but the processor dont work at all.
2. even if your motherboard supports the processor and it works fine then there is problem with the VGA.
Finally to check the motherboard and processor whether they are working or not.
please remove RAMs from motherboard and start your computer and now if it gives the beeps sounds then motherboard and processor are working. and if you dint listen any beep sound then the installed processor is not being supported by motherboard.
Please dont forget to RATE my answer.
Sep 09, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
Processor Upgrade For An IBM Netvista 8307-73G...
If the physical size, and numper of pins is the same as your current processor, you can most definately upgrade. Hyper threading is enabled through the bios, but as far as I know it's not neccesary.
Swapping out processors is fairly easy, and when you buy a new one, it should come with extensive instructions and pictures showing you exactly how to do it. Good luck!
Mar 12, 2009 | IBM NETVISTA M42 - P4 2.4GHZ/512KB 256MB...
Need to download updates for IBM Netvista 2gh Processor
to use your computer you need to put back your old cpu in .
then download the upgrade, and apply i.
after your bios is updated, your new plugged processor will be reconized.
Nov 21, 2008 | IBM NetVista A40p PC Desktop
Lenovo ThinkCentre A57 Desktop - Intel Pentium Dual-Core E2180 2GHz - 1GB DDR2 SDRAM - 160GB - Combo...  Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
