Question about Westinghouse 22" LCM-22w3 DVI/VGA LCD Monitor Black
How do I turn my Westinghouse 22" LCM-22w3 DVI/VGA LCD Monitor into an HDTV?
I'm trying to turn my Westinghouse 22" LCM-22w3 DVI/VGA LCD Monitor into an HDTV, but I need more information regarding exactly how to convert this LCD Monitor into a TV. Plz Help!
PyroPCMan
  • 405 Answers
SOURCE: Connecting to Dish Network receiver/tuner
Yes!
Posted on Jun 27, 2008
  • 13 Answers
SOURCE: Can't remove cover of Westinghouse LCM-22w2 monitor
Hey Ed,
I hope I can help, It doesn't open from the back, it opens from the front.... carefully! There are four support screws, which hold the LCD screen to the desk stand,after removing all the support screws (4) on the back under the support stand cover.(which pull up to remove) (Remember! the whole case and face frame is plastic, so take your time). Work to separate the black face frame around the LCD from the silver case. Its held together by small plastic clips on the face frame to the wall on the LCD case. Start at one of the corners and slowly pry the face frame and silver case apart. (separate it inch by inch, work your way around the case carefully. If one corner doesn't give, go to another side.
Putting back together works reverse, the face frame and the case snap back together, Carefully! And replace screws (4).
Russell
P.S. I have three LCD models from Westinghouse, LCM-22w2, L2210NW and the L1916HW. They all open the same way.
Posted on Jan 03, 2009
SOURCE: Dismantling of a Westinghouse LCM-22w3
Make sure that all three screws are removed from the back of the display. This is in addition to the four that hold the stand on.
Posted on Feb 20, 2009
SOURCE: Westinghouse LCM-19V7 powers on, but picture only stays for a sec
It's probably bad capacitors on the power supply board. These monitors are notorious for having the electrolytic capacitors blow out; cheap components! I would suggest replacing the two 1000 mfd capacitors and the three 220 mfd capacitors with 35 volt components from Radio Shack. That fixed one of my LCM-19V7s but not a second one which seems to have some other power supply problem.
Posted on Apr 11, 2009
  • 1684 Answers
SOURCE: need power cable for a westinghouse lcm-19v1 sl
We carry the power cords for this model at our web site at:
www.ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Dec 29, 2009
How do I convert a Westinghouse 22" LCM-22w3 DVI/VGA LCD Monitor into an HDTV?
Dear Amy,
Normally, monitors do not have tuning electronics for capturing TV signals.
Therefore, consider the monitor as a "dumb" unit that only displays information coming from your computer. Also, this unit does not have a HDMI input, but only VGA.
So, you are fated to have this monitor connected to your computer, always.
Now, you may find good software that will "tune" the TV signals from streaming at the Internet and show whatever is being broadcast. The same way you can access YouTube and watch videos these TV tuners will get the streaming signals the TV stations send via Internet (not all do that) and watch the channel in your PC/monitor
Since I do not have additional information about the computer you use I cannot give you other ideas
I hope I have helped you.
May 18, 2014 | Westinghouse 22" LCM-22w3 DVI/VGA LCD...
Can a westinghouse lcm-22w3 be used as a tv
Yes, you will just need to have the right output on your cable box with some conversion. (eg. if you have RGB out of the back of the box you will have to get a break out cable that goes from that to VGA for the back of your monitor.
Apr 28, 2014 | Westinghouse Electric LCM-22W3 22 inch LCD...
My westinghouse LCD LCM22w3 is not turning on. The switch light will turn on for a few seconds but then turns off. I have no imput signal
Helo,
This is a very common problem with the LCM-22W3 monitors. The problem is caused by a failure of the filter capacitors in the power supply board. Here is a link to a repair guide that shows how to open the unit and what to look for and replace to repair the monitor. This is a very easy repair.
http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-22w3/
Jan 26, 2013 | Westinghouse Computers & Internet
Not turning on
Check the capacitors on the power supply board in the unit. This is a very common problem with this unit but it is easy to repair. Here is a link to a repair guide that shows how to open the monitor and what to look for.
I hope this helps.
May 20, 2012 | Westinghouse Electric LCM-22W3 22 inch LCD...
My Westinghouse LCM 22w3 was working great with full res at 19xx x 16xx. Now it is no longer recognized by my Windows Vista system. In Device manager, the monitor shows as a General PnP 17" with res...
I suggest you test your computer by using a different known good monitor. If it works ok you will know your Westinghouse has a fault and if it doesn't you will know there is a problem with your computer (video card maybe?)..
Sep 29, 2017 | Westinghouse Electric LCM-22W3 22 inch LCD...
Westinghouse LCM 22W3 22" has electric service, but no response
I did not fix the problem, but found out it probably is a power supply which is a very common problem with this design of this make of monitor. I think I need to get to get it fixed by a professional.
thank you Ann Moctezuma
Nov 19, 2009 | Westinghouse Computers & Internet
LCM-22w3 monitor suddenly changed colors. All
Try adjusting the monitor cable that goes from your monitor to the back of your computer.
Jul 10, 2009 | Westinghouse Electric LCM-22W2 Monitor
My monitor will shut itself off randomly
The power supply on this model has a know issue. We just posted the repair guide on our web site at: www.ccl-la.com It gives a step by step repair guide for the Westinghouse LCM-22W3 monitor. If you don't want to do the repair yourself do do offer a repair service for $35 plus return shipping. If youhave any questions just let us know through our web site.
I hope this helps,If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 06, 2009 | Westinghouse LCM-22w2 Television
Feb 12, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Westinghouse 22" LCM-22w3 DVI/VGA LCD Monitor Black Logo
16 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Dudeman321
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
