How to reprogram kambrook rf4471remote to operateas a second remote for the same power points
Remote for my hamton bay ceiling fan 70 inch model DL-4109S-01 won't work. How can I get it to work?
first off see if the remote is working
if it is a point in the fan direction is is probably infred operation. to check turn on the camera of your mobile phone and point the remote at the lens
if it is working then a white light will appear on the screen of the phone when you press on the remote on button and disappear when the off button is pressed
if that works then it will be in the receiver in the fan
Sep 05, 2015 | Hampton Bay Dryers
Kambrook Urn leaking at tap
what is a Toyota, Kambrook. HUH?
URN?
tap?
what URN, what TAP. ????
kambrook heater, GAME, what?
you are on a Car forum, you know that?
Jan 31, 2014 | Toyota Cars & Trucks
Need sequence to program remote control Winplus model #AC51530(TX2)
WinplusUSA quit making these remotes and receivers for the US, but I stumbled across the Aussie version of the same product and the support for programming them. It worked on my receivers, so here is the link for the .pdf file. Use the RF3672 - Indoor Power Point Controller Kit manual for the winplus receivers. http://www.winplus.com.au/kambrook.html Don't forget to save the file for future use, lol.
Dec 02, 2011 | Cars & Trucks
My panasonic dvd recorder / remote control is not working On pressing button on remote I get dvd2 on recorder screen but no other response. I have tried reset without effect
Try reprogramming the remote itself; i.e. point remote at unit (while on), press and hold the [2] and [ENTER/OK] buttons together for 5 - 10 seconds, then release. The remote's command should now match that of the unit (DVD 2) (the unit should now recognise the remote). Failing that, remove batteries from remote, replace with new ones (just in case) and repeat the above suggestion. You should not need to reset the main unit.
Whenever the batteries are replaced in Panasonic remotes, in some cases, a remote command reprogram is often required to ensure that the remote commands the unit fully and correctly. You may find this procedure outlined in your instruction manual. Hope this helps a tad.
Aug 14, 2011 | Televison & Video
The remote control for my liftmaster 1280LM garage door opener does not work. I have changed the battery, made sure the lock feature is off and have tried reprogramming the remote. It does not appear to...
The receiver is going out and will not receive signal from the remotes. try to reset it by unplugging the motor from the power sorce for about 30 seconds and then plug back in. this should reset the logic board. If this doesn't work you will need to replace the board
Sep 26, 2010 | liftmaster Chamberlain Garage Door Opener...
I need help to reprogram this remote. The
Hello, I am sorry i did not get back to you sooner!
I found the manual on the internet, you can just copy and paste into your browser to download a copy for yourself if you like.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&md=rcr4258rcr4358&kw=RCR-4258&st=&ar=&dt=&so=&pg=1&file=others/rca/rcr4358-manual.zip
Here is the simple way of doing it:
0) Turn on TV.
1) Press and hold the TV button, light lights up, continue to hold.
2) Press and hold the power button, light turns off, keep holding both buttons down until light comes back on, release both buttons, light stays on.
3) Point remote towards TV the entire time you are programming.
4) Press and release play button, wait 5 seconds, if TV did not turn off press and release play button again wait 5 seconds. Repeat until TV turns off. (When your TV turns off, it was in the last 10 codes sent).
5) Press and release Reverse button, wait 2 seconds, repeat until TV turns back on.
6) Once the TV turns back on press and release Stop button.
7) Your Remote is now programed! Test it by pressing the power button, volume, mute etc..
Cheers!
Apr 27, 2010 | RCA RCR-4258 Remote Control
Replaced the battery in the remote, but still nothing when I go to lock or unlock my door or set off the alarm, nothing happens.
Your remote needs to be "reprogrammed" after battery replacement. Not sure if yours is done in this manner. This is how my remote is reprogrammed on my 1999 Corvette. Stand beside drivers side door, point remote at the car while holding the Lock and Unlock buttons at the same time. Within 10-15 seconds the horn should beep letting you know the reprogramming was successful.
Dec 23, 2009 | 2003 GMC Yukon XL
Neither of 2 standard fobs works
try
sit in the car
point remote at the mirror ir sensor (1995)
press remote twice and within 30 second
insert key and turn to drive position
if you don't havemirror mounted ir sensors
point at your sensor location
Jul 11, 2009 | 1994 Mercedes-Benz C-Class
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
