Question about Behringer B912neo 12" Pa Speaker W/ Built-in Mix Powered Full Range Speaker
Why burn the MOSFET
You have any upgrade to stop burn the mosfet IXTQ22N50P
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Behringer Expert
  • 232 Answers
Buy another brand..
Posted on Sep 20, 2014
What causes the rf MOSFET to go on a cobra 200gtl
mosfets are seemingly very unstable the culprit probably is too high of dead key on the radio back it down a little and no there is no upgrade also on that radio if someone is real close to you and keys up it can give you what is called front end overload and it will have no receive and will require a trip to the cb shop to correct this problem also if you use the extra channels in it they are hard to understand just what channel you are actually on .........I had one of these radios and I did NOT like it or the cobra 150 . they seem to be very fragile radios............good luck !!!!!
Mar 23, 2014 | Cobra Radio Communications
What causes the rf MOSFET to blow on cobra 200?
They blow for all kinds of reason. Just replace them an check resistors around them. Caps should be checked as well. Just replacing mosfet is not usually enough. They have a way of taking other components out to.
Reebok T3.2 treadmill stop after couple of minutes
7 amps wth no load is kind of high for this.. be looking at the surface that the belt is on.. and the rollers for excess drag..this should completely freewheel when no one is on it..
Jan 19, 2014 | Reebok Exercise & Fitness
SIR, I have a samsung lcd using mosfet
No,get the same mosfet IC.Mosfet dosen't function like a capacitor,capacitors up a litte voltage it no problems.
Mar 17, 2010 | Samsung SPN4235 42 in. Plasma HDTV
A ups mosfet ckt one mosfet burnt out og 16 can i replace only one
Usually the mating one has been degraded or damaged as well. Replace as a pair, or all of them that are in the same function.
OFTEN driver transistors and drive diodes are also damaged. Carefully check all associated components to avoid burning out freshly replaced ones.
Mar 14, 2010 | Vector VEC 024 400-Watt Power Inverter...
HI I have a FSP200-61GT SPI switching power supply with a burned out Mosfet on the high voltage side. There is a (I think)a .5 or 1 watt resistor on both sides of the mosfet. But they test good, my problem...
Please give motr of the devices fixed on same heat sink. Search for SMPS IC like FPS or similar, search their application notes and the datasheet of the nMOS. then you can get idea. without those data Solution is impossible.
Jan 27, 2010 | HP and Compaq Pavilion Replacement 200w...
I think it's usually about 820 - 1K Ohms... It;s the emitter resistor.In saying that we generally don't repair these SMPSU's anymore as they are so inexpensive these days like NZ$45.00 for a 350 Watter. Also 80% of the time the repaired supplies fail again shortly after due to the stress put on the other components, by the initial problem.Good luck.
Jan 27, 2010 | Computers & Internet
Mosfet check
1. Switch your multimeter to the Diode test position.
The following steps are for an N-Channel MOSFET.
Hold the Black lead to the MOSFET's source terminal.
2. Touch the GATE terminal momentarily with the Red lead.
3. Then touch the DRAIN terminal with the Red lead without touching the GATE terminal with your fingers.
The multimeter should show a low reading now. (The MOSFET is now ON)
4. With the RED and BLACK leads still connected to the DRAIN and Source terminals of the MOSFET, now touch the GATE terminal with your finger. The Multimeter should immediately show an open cct. (The MOSFET is now OFF)
This is a very simple way to test a MOSFET.
Jan 13, 2010 | Epson >>> IM800 DARK GRAY 733 MHZ CPU...
Motherbord mosfet burning frequently
repair your motherboard again then have your power supply unit replaced... there may be something wrong with your power supply output voltage..
Aug 01, 2008 | ASUS P4GE-MX Motherboard
Behringer B912neo 12" Pa Speaker W/ Built-in Mix Powered Full Range Speaker Logo
74 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
