Question about John Deere L100 Series
My JD L130 has little power going foreard and almost none in reverse.
Everything works going forward slowly. Cannot use on any hills or even mounds.
    New Friend:
I had the same problem on my JD L 130. Later it stopped moving at all and made a loud noise. I found the fan and pulley on top of the transmission had come loose. I replaced the fan, pulley, drive belt and both idle wheels and it has been fine since. The noise it made sounded like the transmission but was fine. The pulley had started to slip around the transmission shaft and that was causing it to loose power.
Posted on Sep 14, 2014
    Scholar:
  • 159 Answers
The forward reverse pedal linkage needs adjustment. Remove mower deck pins and slide out of the way. Pull linkage pin out then turn clockwise one full turn .move brake pedal while looking at it .You should see a small brake disc on side of rearend with a nut bolt going through the disc. Pull rod on back of mower that allows you to push mower freely.set parking brake try to move mower by pushing if it moves with break set tighten bolt that goes through brake disc til mower don't move.release parking brake try to move mower should roll easy.if not losen bolt 1/2 turn til it moves easy.reengauge rod on rear of mower to drive it test and be sure to place cable ties on any thing under mower dragging ground .If test works .reinstall mower deck.
Posted on May 18, 2014
My lt1000 will move slowly in reverse and when going up an incline you have to move the shifter around to make it keep moving ,any ideas on what the problem is?
This may be normal. slow in reverse is normal. Up a hill, if you are talking about keeping forward on the lever, this is normal. If you are talking about moving it fore and aft or left and right to get up a hill, needs adjustment.
May 30, 2014 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Have a JD 300 with front loader. The tractor will not go forward when the tractor is started. It has a reverser and will go backwards immedictely when started. If the weather is real hot it will take...
Hi, don't know if you have checked this but anyway if you hydraulic oil filter is clean there may be another sintered bronze filter in the sump of the hydraulic tank this could be patially blocked> don't know this particular machine but if it is partially blocked it may be that you will clean that or there is air in the hydraulic system. Hope this is of some help.
Steve
Sep 29, 2013 | John Deere Muffler 1010 Diesel Tractors
Zero Turn mower no power in forward - power fine in reverse
yes check for play in linkage bushings the look for a adjustable rod
May 28, 2012 | Garden
Hello my transfer box and lock box on the 4 lo imposible to change the way my truck its a 2001 dodge dakota 3.9 v6
Your bound up. You can usually get it unbound by driving back and forth. If you can't get into reverse then go to a small hill drive up a little ways then coast back down. don't drive in 4 wheel drive unless it is slick out as it can be a little bit hard on the running gear. try going forward very slowly then put on the brakes kinda hard. this may help release the bound up condition
Apr 23, 2011 | 2002 Dodge Dakota Club Cab
Cat backhoe doesnt even go up a hill in forward, reverse is fine
http://www.heavyequipmentforums.com/showthread.php?t=19510
If you go to this site, and join, AFTER you make five posts, ie: comments on any topic anywhere on the site - five times (hit reply button on any post and comment) you can ask any questions concerning any equipment known to man or beast. It's free and a very good site with tons of great info and pictures.
May 29, 2010 | Caterpillar Backhoe Tractor
4 wheel drive on 2005 f150 fx series not working. When going forward slowly like going up a hill, all four wheels are pulling. But when I gas on it the back tires start to spin but the front aren't so it...
I had this exact same model. If you're not positive all 4 wheels are under power when going forward slowly, check the 4x4 electronic switch. The fuse might be blown.
Oct 31, 2017 | 2005 Ford F-150
My jd stx38 riding mower doesn't go forward or reverse after I re
Check the drive belt but if this is a hydro you probly have a bad trans. Best bet get a new mower.
Jul 26, 2009 | Garden
JD Lawn Tractor L130. will not start
They have an auto shutoff for low oil, start there check your fluids. If Ok check for spark. Try full throttle choke off in case it might be flooded. See if any of that works and let me know.
May 10, 2009 | Garden
John Deere L100 Series Logo
212 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
