Question about Water Heaters
HEATER FIRES UP AND SHUTS DOWN AFTER 5 MINUTES
  • gary miller
    gary miller May 11, 2010
    you need to give a little more info,, what kind of heater, what the name brand is, if possible the year does it have electronic ignitor, or standing piliot, there is to much open in this question,, is it tankless or direct vent or power vent or conventinal water heater,,but from what it has up there I would have to say th gas valve or the flue,, the gas valve could be shutting down, or if the flue pipe is blocked it could cause the gas valve to shut down, this would turn the unit off,, need more info
  • 115 Answers
Try turning up temp control if that doesnt help, your thermo coupling is probably bad replace that first. also check gas line the shut off valve may have gotten partilaly closed the stem on the valve should be in a line with pipe not perpendicular
Posted on Jul 08, 2009
My gas was turned off for 4 days. after being turned back on the pilot will light and the burner fires up but shuts of in 10 minutes
If heater has a sealed front door the air intake filter is probably clogged. Remove the door and vacuum out all the dust and debris in the inside. Then use an air compressor to blow down thru the filter and force out any dust caught in the underside of the filter. Reinstall assemble heater and relite. If problem continues replace the gas control. If unit does not have sealed door just replace the gas control
Jan 01, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
Heater fires up but won't keep heating water
Sounds like the sensor is not working shutting down too early
Jan 06, 2018 | RTO Atwood Water Heater - 6 Gal LP
My Paloma 42PVN shuts down and shows code IL. The manual says it's Lime deposits. How do I remove these deposits. The unit has been running fine for over 1 year but now it only runs intermittently and...
You need a 5 gallon bucket and a small sump pump that connects to a garden hose. The hose connects to the inlet of the water heater and and then run a second hose from the hot water outlet into the bucket. Pour in about a gallon of white distilled vinegar. Turn the pump on and let the vinegar run through the heater for 15 minutes. Reverse the hoses and run another 15 minutes. reconnect the heater and test the water flow. You may need to repeat these steps several times to remove enough debris and buildup.
Installing a water softener treatment system will prevent the buildup from occurring so fast, if ever again.
Oct 15, 2010 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Rheem powervent ignites then goes out, electronic ignition.
Sounds like a bad thermocouple. This part sends a millivolt signal to keep the gas valve open but shuts it off when it cools - or if something goes wrong with the ignighter - to prevent fires. It's easy to replace and not super expensive. See your local Rheem dealer.
Aug 13, 2009 | Water Heaters
Hot water tank shuts down after 5 minutes pilot is on water is luke warm
turn up the thermostat,, if that don't work, you need to replace the thermocoupling
Jul 12, 2009 | RTO Atwood Water Heater - 6 Gal LP
Pilot fires then quickly shuts off how do I pull a code on a Takagi T-K2?
Pilot must heat the thermocoupler a couple of minutes before letting go of the button. The coupler controls the main valve.
Jun 12, 2009 | Ultra Max Takagi Flash TH-1 Ultra High...
Water Heaters Logo
112 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
