Question about Mitsubishi WD-92742 92" 3D DLP 1080p Home Cinema HDTV with StreamTV In
How to remove the screen on a 92 in mitsubishi tv
Random liquid on corner in between screen
My tv want come on at all but it was working fine this morning
Mitsubishi WD-92840 92-Inch 1080p 3D Projection TV
amazon.com/dp/B004ZL2O9U/?tag=80e1-20
Amazon.com, Inc.Amazon.com: Mitsubishi WD-92840 92-Inch 1080p 3D Projection TV (2011 Model): Electronics. ... The Federal Trade Commission (FTC) wants you to know that the ... It is in fact much brighter than my 82" set which also has a 180 watt lamp. ... any lightcoming in; it will cause rather bothersome reflections off the TV screen.
Mitsubishi WD-92840 92-Inch 1080p 3D Projection TV ...
Dec 26, 2015 | Mitsubishi WD-92840 92-Inch 1080p 3D...
I have a big screen tv and little tiny white specks are starting to come behind the screen. What is causing this?
There is a fault with the light engine.one of the chips in it is faulty .there is a you tube video showing the fix.unfortunately the chips cost around 150 pound.
Oct 19, 2014 | MITSUBISHI DIGITAL ELECTRONICS MITSUBISHI...
I have a 60 inch tv and i have white dots on the screen
that is what we call dead pixel, you can remove this by following the steps below.
  1. Turn off your tv.
  2. Get yourself a damp cloth, so that you don't scratch your screen.
  3. Apply pressure to the area where the dead pixel is. Do not put pressure anywhere else, as this may make more dead pixels.
  4. While applying pressure, turn on your tv screen.
  5. Remove pressure and the dead pixel should be gone. This works as the liquid in the liquid crystal has not spread into each little pixel. This liquid is used with the backlight on your monitor, allowing different amounts of light through which give off different colours.
    Hope this helps.
May 28, 2011 | Mitsubishi Televison & Video
Mitsubishi TV Screen Water Stain Problem
You can use warm water and a soft cloth to try and clean it, but it will probably leave some evidence that liquid existed between the two layers at some point. Mitsubishi will deal screens directly to their customers if you ask nice enough and are willing to install yourself.
Jul 05, 2010 | Mitsubishi WD-62525 62" Rear Projection...
The liquid in my mitsubishi rear projection tv just came out of no where once i started to unscrew one of the color tubes...... does this sound right or make any sense??
Yes it does, you should not unscrew the red screws only the gold ones in the corners of the tube.
What is the symptom of the problem that you are having.
You will need to ensure that all of the liquid is off of the circuit boards as soon as possible as it will wick under the IC's on the board and quickly ruin them.
Please let me know if you need more help or assistance.
asnowman
Nov 28, 2009 | Mitsubishi WS-65905 65" Rear Projection...
I have a Mitsubishi 57" projection tv, Model# WD-Y57. There appears to be some type of liquid betweent the 2 screens. Is there a way to clean this, or do I need to buy a new screen?
Remove the 2 screens and clean then wirth only micro fiber cloth and mild cleaning solution dry and reassemble. be sure to put back screens in same ostions.
Feb 18, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Model WD57731 Plastic Cover on Screen Cracked
take it to home depot and have the cut one to the same dimensions you will have to paint the board on it but its still cheaper than one from mits it just clips off you have to remove the corners on the top of screen
Jan 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Colors off
I have the same problem, would like an answer.
Aug 06, 2008 | Mitsubishi WS48511 48" Rear Projection...
45" mitsubishi TV with gray/black "water stains" on screen
If the plastic screen has not been damaged by chemical properties in the liquids, the screen does not separate. Time will tell.
Apr 04, 2017 | Televison & Video
Mitsubishi WD-92742 92" 3D DLP 1080p Home Cinema HDTV with StreamTV In Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
