Question about Timex T600 Clock Radio
Manual Can't get indigo light to work. What's wrong. Won't come on at all.
I lost my remote for my Tata indigo and I bought a new one. How do I program my new remote?
Hi Nothando, It should work as soon as you put the batteries in.... CHEERS
Mar 31, 2016 | 2007 Tata Indigo 1.4
Where is the thermostat housing on a Tata Indigo station wagon 2006
There can only be two places and they are located on the engine at the upper radiator hose or the lower hose. Some thermostats are built into the waterneck and may not appear like the thermostat. Im sorry I work on so many different vehicles and cant give exact location.
Oct 08, 2015 | 2007 Tata Indigo 1.4
Tata indigo 1.4dsl
Sorry we have no diagrams or manuals.
May 25, 2014 | 2007 Tata Indigo 1.4
Tata diesel 2005 . head light , horn , cabin light , radio and stereo not working
Check whether the battery is working or not,in case it is then check the CONNECTING WIRES of the battery and ALSO ALL FUSES... (Under steering and bonnet)
Sep 01, 2013 | 2005 Tata Indigo
Is cam and crank sensor installed in tata indigo dicor 1.4 or not?
Doesn't work that way
When you have a vehicle problem you may have
a MIL Lamp or Check Lamp on your dash
You check for codes
The codes only direct you to a System,they do not
tell you what is wrong or what to replace
You use Factory Diagnostic & Emission Manuals
to Component or Wire test to find the cause of the fault
Basically your need a repair shop with people who know
how to do the testing
Oct 18, 2012 | 2007 Tata Indigo 1.4
Indigo light doesn't work
It is possible that either that the movement of the watch is not aligned properly after a battery replacement.
Oct 02, 2012 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
How do i reset date after battery change? or where can i cet a pdf file a9no calliber number on case or movement but its a timex perpetual with indigo light approx 30 yers old
to reset the date manually, pull the stem out to the second position to reset TIME; manually continue setting time until the date is on the correct day/date.
I had to do this to get back to the proper date when my timex was off by a week. Nothing else worked. 14 times around (twice per 24 hour day) and each time I passed "midnight" the date advanced.
blessings!
Mar 12, 2011 | Timex Watches
Indigo light is not working properly, battery needed?
Timex suggests that you have a watch repair person change your watch batteries. I think it would be a good idea to try and replace the battery, but if that fails to work, contact Timex for advice. If they suggest that you should replace the entire wath, keep the battery. I have no guarantee that any of that would work, though.
Jun 01, 2009 | Timex Watches
Phones 1-2 has both channels coming out of it
Had the same problem and fixed it today. It is the mute button. Whem you change from 1-2 to 3-4 if the mute button for 1-2 does not activate you will get the sound from 1-2 thru 3-4. Just change the setting and you are away. worked for me.
bruce
Jun 03, 2008 | Echo Indigo DJ Sound Card
Echo indigo io recording problem
dont plug mic into output, it is input
May 24, 2008 | Echo Indigo IO Sound Card
Timex T600 Clock Radio Logo
65 people viewed this question
Top Timex Audio Players & Recorders Experts
Greg Cann
Greg Cann
Gyula Lacz
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
