Question about iPhone Apps
Bt tv wont connect goes up to nearly there but no further
How to on Bluetooth on my samsung 2011 tv
Hiya!
Can you access the TVs set up menu?
It will be in there, if the TV has blue tooth (BT)
Turn BT on in the TV menu, then in the device you wish to use
BT needs to "pair" or match with devices, so you may have a wait while the TV BT searches for your device
There may also be a code or password displayed on the TV that will have to be matched with the device
Match the codes and you should be good
If asked for the device's code, look at it's manual. Some default to 0000 (four zeroes) or 1234
Good luck and let me know how it goes
Nov 19, 2016 | Samsung Televison & Video
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
Dec 14, 2015 | Toshiba Televison & Video
Hoe do I connect a sonytv KDL26EX302 to bt tv
In order to connect your TV - any sort - you need:-
1. A BT broadband package.
2. A BT YouView box.
3. A network connection to your HomeHub or other router.
If one of these is missing (or if your broadband connection is too slow) you will not be able to connect to BT TV.
If you have all 3, then on the TV select the signal source to the socket that the YouView box is connected to and it will be installed automatically.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Televison & Video
Ido not understand how bt tv actually connects to my tv
Hello Mate
Is your KLV-32U300A have PCMCIA Card so you can connects easily your BT Tv. but if your TV don`t have that slot so sorry dear you have to upgrade your Tv. And I am surpizse that model is almost 4 to 5 years old, And its still works. (Nop its don`t have the PCMCIA CARD SLTS). Share with me you BT TV model or Device #.
Dec 11, 2014 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
How do i connect my iohone to pioneer Avic Bt
is your radio bt capable, if so all should have to do is turn bt on from mobile device and scan radio should be on and near the pairing device at that time. 2_18_2014_5_23_08_pm.jpg
Feb 03, 2014 | Car Audio & Video
Hi there! I have a 19" Beko Tv about 4 years old. The sound has gone altogether. Picture good though. We have it attached to a freeview top box. Husband saying its the topbox that's faulty. ...
I assume that you have attached it via SCART cable...since SCART plugs have 21 pins, and carry video, audio and switching signals ,sometimes a bad connection on either TV side or Top Box side ,the sound goes off first..Make sure your SCART plugs securely fit to either side.
If it does not help pls visit the URL below for further advise before going to blame the Top Box....
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Set-top Box Connection Advisor This page is designed to help you with connecting your Freeview, BT Vision, Virgin Cable, Freesat or Sky satellite set-top box to your home TV system. http://www.radioandtelly.co.uk/connecthelp.php
Feb 02, 2011 | Beko 324250WN 28" TV
I have had my fujitsu siemens for nearly 4 years. When I first go it I had huge problems connecting wirelessly. BT did however seem to sort the problem. It was fine for 2 years, but again I'm having to use...
Yes if it's just Bluetooth you're trying to get to work by a new BT dongle. If wireless and BT are on the same card buy a new BT/wireless card This one Desktop 802 11ac Wifi Bluetooth 4 0 Dual band 1300M Wireless AC PCI... Works great. Try to stay away from Intel I had to replace two of them in the last six months. The link above uses Broadcom and works fantastic.
Jun 28, 2017 | Fujitsu Siemens Computers & Internet
New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Nov 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
H700 wont connect to lg rumor
after pair successful highlight the headset and hit connect
Jan 07, 2009 | Motorola Mobility H700 Wireless Headset
iPhone Apps Logo
67 people viewed this question
Top Apps Experts
ray gallant
Are you an App Expert? Answer questions, earn points and help others
