Question about Jura Capresso Jura / Capresso IMPRESSA J5 Espresso Machine
Jura ena 5 coffee spout needs a clean leaks out of join
2 Suggested Answers
SOURCE: Jura Capressa E9 Leaking
Most likely the 2 spouts have become plugged with crud. Use a toothpick while the machine is dispensing coffee. Stick the toothpick up in each little nozzle and move it around it might take several cups to get this done. I removed the top cover on mine and just poored water in where the coffee normally goes. It is just a gravity feed system. Don't poor too fast and move the toothpick around until the blockage is cleared. Helps to have 2 people for this. Also, once you get it cleared, try the finest grind setting. Mine was set on the coarsest setting and I think that was making making the blockage more likley. I dont think the cracked spout is common though. My machine has made over 8100 cups and is going on 7 years. No cracks are visible in mine.
Posted on Apr 07, 2013
How do I unblock the coffee spout of the jura 5
My Jura 5 was only pouring coffee from one spout, the other was blocked. I fixed it by removing the cover from the spout (see photo) it clips off with pressure applied to the sides on the dimpled part, then removing the brown reservoir inside after disconnecting the brown tube. Right enough, one side of the reservoir was full of coffee residue. I cleaned this with hot water and a tooth brush before re-assembling it all. The machine now pours perfectly from both spouts.
Oct 02, 2014 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
How to open for cleaning jura ena5 coffee machine
The question is, how to open the machine? I found elsewhere one should unscrew the back logo, but it is slippery. Seems like a special tool would be needed, but I did not find it.
May 06, 2012 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
My jura en9 pour spout clogged. How do I disassemble to clean out blockage? It is pour very slow and coffee is leaking out the sides of the spout.
Hi Eric
Can you get a pipe cleaner up the spout and clean?
Otherwise.... Take some photos and start unclipping & unscrewing
Thats how I replaced the Element in mine.
Check YouTube
Nov 08, 2011 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Ena 3 troubleshooting: Right now it appears that the right coffee spout has a weaker flow than the left. Is it clogged? How can I fix it if it is even broken. Thanks!
Got it! It took me two months and the parts diagram to figure it out.
http://www.jura-parts.com/v/vspfiles/diagrams/Jura%20Impressa%20ENA%203,%20ENA%205%20Diagram.pdf
Use a water-flosser... I used like 8 full water tanks and DONE.
The simpler way would be to try to point up the water-flosser through each of the four holes of each spout... It will be a mess but it should work.
The other way:
1.- Take the grey plastic panel out from the front dispenser. Use a small flat screw-driver, start from the top, there are 2 clips, and then 2 other clips on the bottom.
ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-0.jpg ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-2.jpg 2.- You will see the dispenser "inside", a two black tubes with the spouts at the end and an air intake (I guess) on top. Take out the air intake, that will let you have access into the tubes with the water-flosser.
ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-9.jpg 3.- Take your time "flossing" your dispenser, as I said it took me like 8 water tanks... a lot of coffee residual got accumulated (to my surprise).
ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-14.jpg 4.- Voila!
Jan 29, 2011 | Jura Capresso Jura Ena 3 Espresso Machine ...
Jura Capresso Jura / Capresso IMPRESSA J5 Espresso Machine Logo
46 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
