Question about Lenovo Ideapad S206 11.6 Inch Laptop - Grey Amd Dual Core E2-1800 1.7Ghz, 4Gb Ram, 500Gb Hdd, Wlan, Bt, Webcam, Integrated Graphics, Windows 7 Home Premium 64-Bit
Screen turning blue green
My screen is turning blue green before it was there for like seconds and then disappears but now its always there and can't seem to get it off... the color is bothering me since it affects the colors of the graphics and pics i'm trying to view.
Sounds like the ribbon cable has come loose either on the back of the screen or most likely on the motherboard. To correct either option means taking the laptop apart.
Posted on May 19, 2014
Brand new 55" led Emerson tv has s thin red blue green line(one line)verticle on right side of screen? What to do?
If it does not disappear in a little while, just ask the shop repair or bring a new screen. Must be a guaranty case.
After installing my computer screen, I had vertical lines in the middle, but after some time (In my memory about a few hours) they all disappeared and never came back.
Jan 06, 2015 | Televison & Video
II get sound for about 15 sec. but no picture and then shuts off
kp57ws50_57_in_rear_projection_hd_228277.jpg Problem with Sony KP-57WS520 57 in. Rear Projection
This model is really prone to one problem in particular--screen even briefly comes up bright red, green or blue and set shuts down.
15 seconds from turn on front power light should blink as set checks several things internally---if something wrong it does not let picture show.
Usually after shut down or failure power light will blink a sequence of blinks but not always depending on problem.
Did you see the screen at all go red, green, or blue before?
the more you tell me the better I can help
Mar 28, 2012 | Sony KP-57WS520 57" Rear Projection...
Problem with the Toshiba 50H13 50 in. Rear Projection Television. Green tint
The tubes have aged and the colour balance between the tubes has shifted. You will need to redo it using a black/white test image: first the black (the cutoff point), then the white (the gain) on each tube - always start with the green colour. This is done on the final video amplifier of each tube by adjusting the corresponding semiadjustable resistors.
Jun 02, 2011 | Toshiba Televison & Video
I have a kp65ws500 that turns on for about 5
These sets have a history of bad picture tubes-the tubes are only available on a rebuild basis and very expensive.
there is an option:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} SONY SCREEN ADJUSTMENT:
Here is what you need to do.
1.) You need to remove the entire plastic piece below the front of the screen. You most likely will find 3 screws on either side in back that you have to remove.
2.) The grill will not come out easy, pull from one side and then when it starts to come loose from the other side(there are several plastic pegs that hold it in.) Then from the bottom pull out( most of these sets have square plastic tabs at the top that tuck in.)
3.) With the grill removed locate the inspection plate behind it (it usually has 6 screws.) You will have to tilt the grill to the left and on its side as several cables are connected to it--they are held in place with trash bag like ties that you can release to get some room.
4.) With the inspection plate removed you will see a fairly small (about 3 inch square) BLACK PLASTIC BLOCK WITH SIX CONTROLS-usually they are marked with whiteout so someone can tell if they have been adjusted.
5.) You need to look very close at the block with a flashlight----usually the top three controls are FOCUS--don't touch those.
The lower three are usually marked Screen and if you look very close you will see b, g, r(blue green red)
6.)Usually the GREEN will be in the middle.
7.) Once you locate the green screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Screen control.
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the green screen down until the set stays on and then very slowly turn it up until you see a slightly green screen with or without diagonal trace lines----turn it down slowly until the Blue screen and trace lines just disappear.
Let me know if you get it to work--Like I said if it is shutting down you may have to slowly turn the screen down a few times to get it to stay on.
Regards, SD TECH
Mar 08, 2010 | Sony KP-57WS500 57" Rear Projection...
SONY PROJECTION TV TROUBLE SHOOTING BLUE SCREEN
This was one of several Sony models that had bad picture tubes--the set uses a red, green, and blue tube.
There is something easy you can try that may help you get some more life from the set.
7.) Once you locate the BLUE screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Screen control.
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the Blue screen down until the set stays on and then very slowly turn it up until you see a slightly Blue screen with or without diagonal trace lines----turn it down slowly until the Blue screen and trace lines just disappear.
If it works you may only be buying some time--if the blue tube caused this it may return at some point.
If all this information has helped you rate this solution as I do this here for free.
Regards, SD TECH
Dec 20, 2009 | Sony KP-51HW40 51" Rear Projection...
Picture and sound first turn on before disappearing over and over again.
Symptom shows its weak Lamp problem in TV and you need to replace lamp. Replacement procedure is easy and written in instruction manual of TV.
Always buy Sony Original Lamp from Sony Accessories for longer life of TV.
Apr 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Mar 14, 2009 | Protron PLTV-37 37 in. LCD Television
TV Picture cuts off.
The blue screen means that you have lost signal. If the set don't have signal for so long it turns itself off. "power saver feature" Check all connections or replace cables, If that don't work the signal board may be going bad.
Feb 26, 2008 | Televison & Video
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Lenovo Ideapad S206 11.6 Inch Laptop - Grey Amd Dual Core E2-1800 1.7Ghz, 4Gb Ram, 500Gb Hdd, Wlan, Bt, Webcam, Integrated Graphics, Windows 7 Home Premium 64-Bit Logo
98 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
