Question about Kenmore Ovens
What is a F 31
When I push the bake button and a F 31 error comes up
    Champion:
  • Kenmore Expert
  • 323 Answers
Posted on Feb 02, 2015
Why does only broil come on when i push the bake button?
Bake and broil elements can be tested with an ohm meter for continuity. There is a relay in control / clock for both bake and broil elements. If elements test good, then those relays need to be tested for voltage.
Sep 16, 2017 | Ovens
Why my whirlpool GBD307 double oven top oven will not cut on, but the bottom one will. but after heating up, the oven starts blinking the start? button but it will not cut off, it shows a error code F
that's a bad touch panel or key panel,the number you sent isn't the full model number off of the oven so when you call to order the part you will need that.if you try to fix this yourself make sure the power is off.good luck
Nov 07, 2017 | Whirlpool GBD307PDS Electric Double Oven
Frigidaire PLEB30S8CCA baking element not working
Good Morning Jane, thank you for your post!
From what you have described, it sounds like you possibly have problem with a faulty thermal fuse, power supply board, user interface board or a communication error with the EOC (Electronic Oven Control). This is not a typical do it yourself job. Please reach out to an expert technician to ensure the appropriate replacement part(s) is ordered and is installed correctly to prevent future issues.
Best regards!
Feb 10, 2014 | Frigidaire 30 in. Electric Gallery Series...
Oven gets a "fault" shortly after putting power back on.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^%#TR
May 30, 2010 | Whirlpool GBD307PDS Electric Double Oven
The baking does not work
sounds like the touch pad or main control board could be bad...call for help on checking components....
May 12, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
I was cooking in my Kitchenaid oven and the door locked. It will not unlock
We had the same thing happen
Turn the oven breaker off, then let the oven cool completely. Turn breaker on, there will be an error code appear, push and hold the "bake" button for at least one minute until an error message appears, then press the off button.
This reset the latch on our oven
Nov 02, 2009 | KitchenAid Ovens
Oven will not heat on bake.
does the ignitor glow? if it does and the burner does not fire within 30-60 sec. replace it it is weak .if the ignitor does not come on at all youll need to check for voltage at the ignitor when the bake circut is on.
Sep 16, 2009 | GE JTP86 Electric Double Oven
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
