On the HP System, you'll need to press the escape key as the system is starting up, and then hit F9 to get to Boot Device Options. Once there, you can set the boot order. After you've set the boot order, you'll also need to make sure that you have bootable files in the device that you've selected as the first boot device.
For example, if you've set the first boot device as CD-ROM drive, and the second is the Hard Disk Drive, then you'll have to make sure that there's a bootable CD/DVD in the drive when you start the system. If no bootable files are found on the first boot device, it'll automatically check the next boot device, which is the Hard disk and start booting from the Hard disk.
GuruAid
it looks like your hard drive has crashed but before i confirm you need to try these steps first.1:remove the hard drive if its a SATA make sure the connectors on the drive and laptop are clean, if not clean it. if its an IDE check for any bent or broken pins.2: connect your hard drive to another pc or laptop using an external cable and if it is detected try and retrieve as much information from it as possible and format it with the quick format option deselected.3:if you dont have an external cable to connect it after you have physically cleaned the hard drive, mount it back in the laptop and check to see if it still gives the error. if it does run a windows installation setup from a disk and see if it recognises your hard drive. you can then format it from there and reinstall the operating system on it. 4: if non of the above methods dont work you should consider replacing your hard drive.
