Question about Emerson Smartset Clock Radio
Emerson radio gaining time
After a short power outage my clock radio started to gain time..about 25 minutes a hour
SOURCE: smart set clock radio
http://emersonradio.com/owners/SmartSet%20Series/
Perhaps something here will help.
Posted on Jan 08, 2008
SOURCE: My Clock Gains Time
The Clock Is Faulty if you have warranty on it take it back
Posted on Jul 18, 2008
SOURCE: My Emerson Smartset Clock Radio CKS3516
I returned the clock!
Posted on Aug 02, 2008
  • 814 Answers
SOURCE: emerson clock radio cks 3516 military time
You will need to try some combination of the set button and time button to change the time back to normal time. Try hold both the time and set button for a period of 5-10 seconds and see if this will cycle the time to normal. If not try hold the set button alone for 5-10 seconds and see if this works. If not try holding the time time button for 5-10 seconds and see if that works. If none of the fixes work. Call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 9am-5pm CT. Tell them the make and model number of your Clock/Radio and ask them for assistance with your problem of resetting the time back to normal from military time. They will be able to help you. I hope this information helps you solve your problem.
Posted on Jun 13, 2009
  • 814 Answers
SOURCE: I have an Emerson smart clock radio and cannot set the alarm
Sorry it took so long to give you a reply to your problem. [http://www.emersonradio.com/owners/SmartSet%20Series/] Copy this web link and paste it into the address bar of your web browser. The link will take you to the Emerson customer support web page that has pdf copies of the owners manuals for all the Smart Set Clock/Radio's. You will need to have a pdf reader and writer to read and make a copy of the owners manual. Find the make and model number of Your Clock/Radio and open the manual. You will find all the instructions for setting the alarm. If you are still having problems with setting the alarm. Call Emerson Customer Support at this telephone number 1-800-909-1240 between the hours of 8am-4:30pm CT. Tell them the make and model number of you Clock/Radio and ask them for assistance. I hope this information will help you with your problem. Thank you for using FixYa and have a nice day!
Posted on Jun 14, 2009
Cloc gains time
well without the make and model number I can only answer generally , most clock radios use the power line to sync the time base (60 hertz=60 seconds = 1 minute=60 minutes=1 hour) , but they use a internal time base generator when running on battery back-up (that's not so accurate) , I had one some time back that a customer plugged into a switched outlet (unknown to them) in there room and it did exactly the same thing it gained about seven minutes every day , me id check the outlet its plugged into to see if its on all the time (a quick test 4 this is to remove battery back up ) clock will then flash to be reset if you come back later to see it when the power was shut off
Jul 26, 2016 | Audio Players & Recorders
How to set time
Most radios have a button for setting the time, button for hours and then one for minutes. Try checking the clock for buttons that have labels for these.
You often have to hold down one and press the other to change hours and minutes respectively.
Alternatively, if it only has two buttons. Holding one should start cycling through the hours and/or minutes.
If this doesn't help, please post a picture of the clock or the make and model of it.
Thanks!
Nov 04, 2015 | Audio Players & Recorders
My clock is gaining time that is it is gaining about 10 minuts a day. what do I need to do
well if that is an electronic clock this problem might be because of the fact that these clocks use electronic timing circuit which consists of capacitors and resistors which are used to maintain a constant current flow to the timing circuit and if this RC(resistor, Capacitor) combination has some issues the circuit will not function exactly it is meant for and you will either get gain or loss of minutes.
so it is best to see if you can figure it out or just switch the clock.
Jan 06, 2010 | Emerson (B0002HKS0S) Clock Radio
Can my alarm clock be changed to automatically change for the new day light savings times? I have one clock and I bought one just like mine for my mother.
(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.
Apr 05, 2009 | Emerson Smartset Clock Radio
After a power outage, my clock no longer has right time
You need to reset the microprocessor in the Clock/Radio. to do this you must unplug the Clock/ Radio and remove the battery. Let the Clock/Radio set for at least 1 hour to discharge the microprocessor. You can then reinsert the battery and plug in the Clock/Radio. The functions should return to normal. If you are still having a problem, try changing the battery (CR2430) and letting the Clock/Radio set unplugged for a longer period of time. If all this fails, you can call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT and ask them for assistance. I hope this information help you with your problem.
Apr 01, 2009 | Emerson Smartset Clock Radio
Clock is losing time
This is a problem with either the a/c power or the Clock/Radio's internal timing crystal circuitry. The radio depends on the 60 cycle power source as the timing device. If this power is irregular or uneven in its delivery it can cause the timing circuits to lose or gain time. The Clock/Radio has a frequency tuned crystal that operates like the second hand on a clock. When the calibration for whatever reason is lost the crystal will not be able to perform the timing function correctly. The reason this does not happen in all Clock/Radios is that they usually have correction circuits. These circuits keep the crystal from drifting out of calibration during operation. Because of the low production cost of these Clock/Radios, the quality control is almost non existent. The components are variable and sometimes they do not stay within specifications. This problem is usually handled by quality control departments in the manufacturers facilities. They usually test a certain amount of the production run to make sure it meets specification. In higher priced electronics these test are on going during the production run. In lower cost electronics these tests for quality control are usually done before the production run. This is to choose the best and most reliable components for the price level of the product in production. What this means to you, is that the quality of the components and quality control of the production runs are based on cost efficiency to the manufacturer. This is the reason for these type of efficiency variables in the products. The customer support telephone number for Emerson is 1-800-898-9020 between the hours of 9am-5pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information helps you under the problem and reason these problems can occur in the products. Thank you for using FixYa and have a nice day.
Feb 16, 2009 | Emerson Smartset Clock Radio
My Clock Gains Time
Jul 05, 2008 | Emerson CKS2237 Clock Radio
Bose Wave Radio CD clock gaining two hours a day.
I have the opposite problem (110v radio but 220v power). Like to exchange the power supply?
Nov 13, 2006 | Bose Wave Radio
Emerson Smartset Clock Radio Logo
70 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
