Question about ASUS Computers & Internet
Cpu fan replacement - ASUS Computers & Internet
  • 12 Answers
Google the model of Asus Laptop you have for CPU fan replace.
"Replace CPU fan on Asus model xxxx" XXXX being your model.
Look for a U-Tube video on how to do it.
Craig
San Diego, CA
Posted on Nov 28, 2015
I have a vostro 200 large tower with a g33m02 motherboard. The cpu cooling fan is very loud. (not bearing loud, but it seams to try a lot harder than it needs too for what the computer is doing.) the cpu...
Check your BIOS Settings
CPU Configuration
CPU Internal Thermal Control [Auto]
Hyper Threading Function [Enabled]
Intel(R) SpeedStep(tm) Tech [Auto]
Power>Hardware Monitor
CPU Q-Fan Control [Enable]
CPU Fan Ratio [Auto]
CPU Target Temperature [60degC] (lowest setting available)
or you can replace it with Cooler Master XDream
Sep 20, 2011 | Dell Vostro 200 Desktop Computer
CPU fan failure causes system to aromatically shut down..
Without a proper working cpu fan the cpu will overheat and shut the computer down... if not fry the cpu. You will need to replace the cpu fan and hope the overheating didn't mess up the cpu or something on the motherboard.
Jul 06, 2011 | HP Hewlett Packard HP-COMPAQ DX2450 MT...
WANT TO KNOW HOW TO INSTALL A PROCESSOR
First you will need to know what kind of socket you have on your motherboard, so you can purchase the correct CPU for your replacement. Intel and AMD have lots of different socket sizes so don't overlook this point. If you have the CPU that you are going to replace, all you need is a screwdriver, thermal paste, and CPU fan.
1) Open the case cover with screwdriver, and open side panel to locate CPU.
2) Using a screwdriver or sometimes just release clamps to take off the CPU fan.
3) Release lever on the side of the socket to release the CPU.
4) Pull out old CPU and install new CPU, (Be very careful not to bend the pins on the CPU.)
5) Put small amount of thermal paste on top CPU.
6) Replace CPU fan and connect power to the fan, replace cover.
Now in a perfect world this should be it, but if you upgraded you CPU you should go into you BIOS and check the settings for your CPU. To make sure the voltage is correct.
Look here if you need more help.
Jan 27, 2011 | Computers & Internet
A fan is making a horrible noise
hello
if its the CPU fan is making loud screech noises, its time to replace it
if the power supply fan is making the noise, its time to replace power supply , 5188-2859 is HP part number $25-$40
CPU fan = 5188-3722 HP part number , costs about $40-50
please rate my service with 4 thumbs up
Dec 09, 2010 | HP Pavilion Elite m9510f PC Desktop
Cpu in my coputer overheating to 65 c ,and blue screens appear and computer restart , what the reasons
Well your cpu is overheating. The cuase may be the cpu fan. So try to replace the cpu fan.
Regards, polysandy
May 19, 2010 | Intel Motherboard
Blank screen slow coming on md6 model 7700 fan was excesively noisey before pc stopped coming on all together, almost 4years old any ideas please?
It sounds like the CPU fan has failed and is causing the PC to overheat straight away.
To determine if the CPU fan has failed you will have to remove the side panel from the desktop and check the fan.
If the fan is caked in dust try cleaning the fan blades and the metal heat sink with a clean dry paintbrush, then try turning the PC on to see if it makes any difference.
If it still does not come on or it comes on but the fan isn't rotating then the CPU fan will need to be replaced.
If there is still no power to computer then chances are that the CPU itself or the motherboard has blown.
This will mean a new computer or replacement motherboard.
Regards.
Nov 27, 2009 | Medion Computers & Internet
CPU fan not detected
replace ur cpu fan...... if u hv a problem with SMPS the fan which u can see at the back of ur cpu do replace it.. this SMPS provides all the power requorements for ur CPU
Jun 29, 2009 | Computers & Internet
Foxconn CPU fan making noise
It sounds like the fan bearing is shot, I'd recomend not using the computer until fan is replaced.
yes it is possible to replace the fan, i would recomend that you replace it with an aftermarket cooler. all you need is what kind of CPU you have, then find out what kind of socket it is, from there you can find the cooler you would like.
Jan 27, 2009 | Foxconn CPU Cooler Fan CPU Fan
Looking for cpu fan or combo heatsink for a foxconn mother board
CPU heatsink/fans are usually sold as a unit at Newegg.com, tiger.com as well as al other computer supply places. Fan and heatsink are specific and  must match CPU and socket.
Jan 17, 2009 | Coolmax CPU Fans CPU Fan
CPU fan stops, computer shuts down
You must have the CPU fan plugged into the CPU fan power connector or the system can not monitor the fans speed. Your PC will shut down & give you that message. (The fan must be connected to the correct power plug).
If when you did replace the CPU's fan & had to remove the heat sink, which is where the fan screws into & did not clean the old thermal grease off the CPU & heatsink & replace with new thermal grease than your CPU will still overheat. If you add thermal grease over top of old thermal grease your CPU will over heat.
This is all a balancing act. If any one is not correct your system will shut down. (This is better than killing the CPU).
To remove old thermal grease use a clean cloth damped with house hold alcohol & use the same on the bottom of the heatsink. Please allow plenty of time for the alcohol to dry.
Good Luck! Take your time.
Mike
Mar 30, 2008 | HP (P2074-63003) Motherboard
Computers & Internet Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
