Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
How do I reset the codes so I can smog my 1999 s10
I have a 1999 Chevy S10 2.2L 4Cyl extreme.. EGR?
you're correct the 98's come with an EGR valve and the 99's don't.
Feb 23, 2018 | Cars & Trucks
When does the computer make the evap. test on a 2000 Chevrolet S10 V6
It is an ongoing test, and is in a constant monitor mode. What is the problem you have, system not ready on a smog test?
May 18, 2016 | Chevrolet Cars & Trucks
1999 chevy s10 four wheel drive 4.3v6pickup wont pass smog fault code p1870 they said transmission is bad can someone explain what it is
DIYer? I recommend a repair manual from your auto parts store. It should provide a complete list of all error codes and likely repair methods. Otherwise find a competent repair shop, or your dealer. I googled your error code This is just one of the answers: http://repairpal.com/check-engine-light-with-code-p1870-057
I am sure you can do a better search since you know far more about the issues.
May 07, 2015 | Cars & Trucks
What does code p0785 mean for 1999 gmc yukon 4x4
Your code is a PO785 is a SHIFT TIMING SOLENOID BANK A wich is a transmission code nothing to do with your smog failure so go to your local auto store and buy this product it's called guaranteed to pass this will get u buy the bs emissions test for 10 bucks regards Chris
Mar 03, 2014 | 1999 GMC Yukon
My 1999 kia sephia wont pass smog test
You will need to get it scanned and get the codes for the problem. If it failed the test due to emissions I would almost guarantee it will be your oxygen sensor or cat
Jul 31, 2012 | 1999 Kia Sephia
New 02 sensors but still have codes
massair flow meter or drawing air which confuses 02 sensor cos of wrong air fuel mix
Feb 15, 2012 | 1999 Kia Sportage
Wat do i do 2 make da check engine light on a 98 chevy s10 come off so it can pass smog?
making the light go out will not enable the car to pass smog! it is indicating a problem and this problem will surface when it is checked at smog inspection.
Sep 21, 2011 | Chevrolet S 10 Cars & Trucks
Mil/check engine light smog test failed
If you are a DIY'er you can get a OBDII scan tool that connects to your laptop that can tell you the error code and allow you to reset your check engine light.
Check out http://www.fitityourself.netau.net/OBDII.html
Sometimes the check engine light comes on if you did not fit your gas cap tight enough. You need a code reader to find out the error code to help solve your problem.
If it is something simple (like a gas cap) and you do not want to get a code reader to find out what codes (problems) your vehicle computer is saying there is. You can try disconnecting the negative battery lead for 5 minutes. This should reset your check engine light. Drive and see how long it takes before it comes back on - this may help you pass the smog inspection...
Mar 01, 2010 | 1999 Chevrolet Suburban
Obd code 1627 ,1999 4 cylinder isuzu rodeo
If P1627 is set when there is a problem with the fuel level sending unit, 100% sure on this problem, replace the fuel level sender in the gas tank, about 2.5 hours, very straight forward job
Jun 02, 2009 | 1999 Isuzu Rodeo
Need list of fault codes for deawoo lanos 1999
Not a solution: This is my problem...
I needed to get my car smogged, but the check engine light was on. Took to to a local smog station that had replaced a sensor for me in the past in order to pass smog. They could not fix it. Put car in dealership garage for repairs and to date, the transmission module sensor (computer) went out and the ignition sensor was out also. The mechanic replaced both and now the code P1702 comes up. What does that code mean? My car still won't pass smog....
Aug 06, 2008 | Daewoo Lanos Cars & Trucks
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
24 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
