Question about Aprilaire 8444 Single Heat/Cool Stage Dual Powered Non-Programmable Thermostat
Why did my Aprilaire Thermostat 8444 blinked then shut down?
We changed the batteries and reset the unit but nothing comes on
3 Suggested Answers
  • 8 Answers
SOURCE: aprilaire humdiifier not working
Does your humidistat have any dip switches or a small jumper wire? if it does try switching positions of the jumper or change dip switch. hope this helps
Posted on Feb 04, 2009
heatman101
  • 43501 Answers
SOURCE: I have an Aprilaire Model
The solenoid valve has gone bad and is not closing properly...
here is the part you need
http://www.aprilaireparts.com/4040-solenoid-valve-assembly.html
It really should not be hard to replace.and will only require a few hand tools to do it...
heatman101
Posted on Jan 16, 2011
System wont ignite. chgd filter & batteries in thermostat
Does the igniter get hot? If it does, then there is a problem with the gas control, that is, the gas won't come on for some reason. Generally, the gas won't come on if the igniter fails (for safety reasons), so are you sure there is gas flowing? You would hear the cycle start, that is the lighter, and even air flow, but if the gas doesn't come on during that time, the system shuts down in a few seconds.
Nov 30, 2015 | Heating & Cooling
Water filter on aprilaire model 700 light keeps flashing
You need to reset by turning thermostat dial all the way to test reset. It will reset itself, then go back to your setting.
Mar 05, 2014 | Aprilaire 700 120V Power Fan Humidifier...
Furnace has begun to fail to cycle on when shuts off but if switches on base of furnace are switched off and back on will cycle on until desired temp. is reached but will not come back on unless switches...
This sounds like it may be a control board issue. If the thermostat has been changed, and the unit operates correctly after it has been reset, then I am thinking the circuit board in the unit is faulty. When the unit stops working, check for a blinking or steady red light on the circuit board. Alot of the time this will be on or blinking and there will be a legend that tells you what each light stands for. This can help you troubleshoot the issue.
Mar 01, 2011 | Intertherm Heating & Cooling
We noticed the humidity went down to 30% and I adjusted the rate to increase Now our Aprilaire 400 says to change the filter. I did that, and it still says to change the filter. The furnace runs fine....
If your humidifier is equipped with a Digital Humidifier Control with Water
Panel change indicator, after replacing the Water Panel, turn the control
knob to the "Test/Reset" position until the "Humidifier On" light blinks to
reset its timer. (Blower must be operating and HVAC calling for heat.) Be sure
to turn the control knob back to it's original setting. If the "Humidifier On"
light continues to blink, your humidifier is in Test mode. DO NOT LEAVE THE
CONTROL IN TEST MODE OR HUMIDIFIER WILL NOT OPERATE.
Jan 27, 2011 | Aprilaire 400 Humidifier
We have an old Aprilaire humidifier (Manual adjust)and having problems trying to figure out how to shut it off-for the summer.
close the by pass air flow valve. shut off the water supply and finally flow the thermostat wire to the transformer or the controller and shut off or disconnect. Unit should be serviced before winter. Cell may need to be replaced
Aug 10, 2009 | Aprilaire 550 Humidifier
Aprilaire humdiifier not working
Jan 29, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 water panel light won't reset
the solinid may be stuck or the humistat is wired wrong
Jan 16, 2009 | Aprilaire 700 Humidifier
Changed out a Honeywell Thermostat with an Aprilaire Thermostat
The smell is usually dust on the wires for electric resistance heat.The thermostat shouldnt have anything to do with it.
Nov 19, 2008 | Heating & Cooling
Aprilaire 600 - change water panel light stays on
Turn the control knob to the test/reset position untill the change water panel light blinks to reset the change panel timer. Make shure the furnace is running calling for heat.Turn control knob to prior setting after resetting timer. Hope this helps.
Feb 16, 2008 | Aprilaire 600 Humidifier
Aprilaire 8444 Single Heat/Cool Stage Dual Powered Non-Programmable Thermostat Logo
87 people viewed this question
Top Aprilaire Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you an Aprilaire Heating and Cooling Expert? Answer questions, earn points and help others
