Question about Altec Lansing AVS 200 Computer Speakers
Speakers cannot connect to laptop - Altec Lansing AVS 200 Computer Speakers
How do I install Coby speaker system to my laptop
This system takes a 3.5mm headphone jack.... just connect headphone out (Green socket) of laptop to speakers
Nov 20, 2014 | Coby CSMP77 2 Speakers
There is no sound. I have connected it to my new Toshiba laptop
Hello there,
When you plugged it into your laptop, turned it on and increase the volume, do you hear only a humming sound from the speakers? Try to plug the speaker to an mp3 player as well to test if it still doesnt give out any sound. If it still doesnt, then your speaker must have a wiring connection problem inside that needs resoldering. Here I supposed that your laptop's internal speakers is working and is able to work with other audio devices like a headset or an earphone.
Dec 20, 2010 | Insignia 2.0 Speaker System (2-Piece)
I just bought a new Win7 laptop and plugged in my ACS 295 speakers into the headset port and it does not work.
Hi
Do your sounds work without the speakers connected to the laptop?
So the first suspicion is have you connected the speakers together correctly.
Did the speakers work on another machine?
Do I suspect correctly that the two speakers /satellites are connected to the sub woofer and the sub is connected to your pc with one plug.
That should be as simple as that, just make sure its turned on and volume aswell.
now does the laptop react to the speakers in anyway?
Dec 20, 2009 | Altec Lansing Audio Players & Recorders
Connect speakers to laptop
If the speaker you want to connect is from other devices(not a computer speaker )then you need an amplifier .Connect the speaker to the amp. then connect the laptop(output) to amplifier (input)the cable you need is "dual RCA male to 3.5mm male audio" .here is the link to view the cable that you need.
http://www.cablesnmor.com/rca-mini-stereo.html
Jan 30, 2009 | Cyber Acoustics Accent S-3006 Computer...
Connecting SRS-BTM30 bluetooth speakers to my vista laptop
This has also been sending me around the bend. I resolved it by disabling the speakers on my laptop. To do this go into control panel, then hardware and sound, then change system sound. Select your speakers and disable them. This allowed me to play music through the speakers. You can also re-enable the laptop speakers after this.
Jan 17, 2009 | Sony SRS-BTM30 Computer Speakers
External speakers for acer laptop 5220 series
Hi there
On acer laptop you have already speakers. but you want to connect external speakers then please find
that three conector in your laptop and connect you external speakers on one of them. please try each connector and you are able to connect external speaker.
Thanks
Robert
Sep 24, 2008 | Computers & Internet
Connecting creative 4.1 speakers with my HP Compaq 6720s laptop
Go 4 setting of audio device in ur laptop.
n check is there 4.1 speaker system is available r not.
Then u can fix ur 4.1 creative to ur laptop.
Aug 01, 2008 | HP Smart Buy Notebook
Boston Acoustic Speakers from Gateway to Pacer7720-4438 laptop
The laptop should have a speaker output the same size as that plug. This is the size of most small computer speaker systems.
Jan 01, 2008 | Audio Players & Recorders
Altec Lansing AVS 200 Computer Speakers Logo
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
